Question about Health & Beauty
Can't locate hole on charger for house current
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
More info please
Posted on Nov 01, 2012
The iPad doesn't charge with USB connection to the computer?
usb at computer have too weak current to charge ipad, you need wall charger.
Mar 26, 2015 | Tablets & eReaders
Will not charge/stay charged
you charger wire connection is loss so you have to use wiretap properly or you have to buy a new charger
Jun 09, 2017 | HTC Rezound
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Red and green flashing lights on 18v lxt charger
Batteries don't always look degraded but if they've been in use for a while or have a bad cell, they will show up bad on the charger and it won't charge them. The only way to test the batteries is to try to charge them on another charger. If the batteries show defective on another charger, they are bad and you'll have to replace them. Also try to charge some batteries you know to be good on your charger to see if it's the problem. If your batteries charge on another charger, your current charger is bad and they don't have any replaceable parts in them so you'd be looking at replacing it.
Feb 21, 2012 | Makita Tools & Hardware - Others
Any idea where I get a replacement charger for a Metz60CT4
EBay, if that's what you want. The metz "chargers" are just 7 volt ac transformers - they supply 7 volts to the battery pack which has the actual charging circuit in it. I haven't pulled one apart yet, but I'm guessing they're very rudimentary chargers. Depending on what you're using for a battery you might want to use a modern external smart charger. I use $20 AGM batteries from batteries plus (instead of the $80 metz batteries) and use an external charger from WallMart on them. It's quick, lets me see the current charge state, won't overcharge the battery, and works on my car and boat batteries too.
Jan 24, 2012 | Metz Mecablitz 60CT4 TTL Flash
On what part of the helicopter do i connect the remote charger to, I can't find it?
When the helicopter is sitting upright, locate the on/off power switch located on one side of the helicopter. The charging port is located on the opposite side and will look like a tiny square hole/plug (usually white or beige).
Note: The charging cable can only be plugged in one way, because it's notched / keyed so that it can only be plugged in one way. If it does not seem to be going in smoothly one way, flip it over, and try gently plugging it in again.
Dec 26, 2011 | SYMA Toys industrial New Syma S107 Radio...
When I plug in my Jet 3 Ultra 4500, it seems to charge - the charging lights come on - but it never charges. In fact, I can't get it to move at all, even when plugged in. I think I am using the...
when you plug in the charger do you get any amp reading on the meter located at the rear of the chair near where the charger cord plugs into the chair. When you plug in the cord the meter should deflect and read 6 amps or so. If you aren't getting any deflection of the amp meter then either the batteries are dead or the charger is bad. If you have a voltmeter you can set it to 200 volts dc and plug the leads into the charger port located under the front of the joystick Plug the leads into the 2 outter holes of the port with the charger plugged into the wall you should be reading 27-30 volts. Unplug the charger and you will be reading the battery voltage and fully charged they should read 25-27+ volts. If you aren't reading 25-27 volts without the charger plugged in you will need new batteries( anything less than 10 volts will not let the chair turn on) if you aren't getting 27-30 volts with the charger plugged in then the charger is bad and you can get or borrow an off-board charger and charge the chair thru the joystick port Hope this helps
May 07, 2011 | Jet 3 Ultra Power Chair
WILL NOT CHARGE I HAVE TRIED TO CHAGE IT BUT IT WILL NOT CHAGRE
well if it won't charge then it could be the batteries are too low for the charger to pick up or the charger is not working. If you have a voltmeter set it on 200 vdcand plug it into the 2 outter holes of the charger port located under the front of the joystick. Without the charger plugged in you will read the battery voltage and it should read 25-27 volts fully charged Now plug in the charger and the meter will be reading the charge voltage and it shoud be 27-30 volts. If you are reading 27-30 volts with the charger plugged in then the charger is working Hope this helps you
Apr 22, 2011 | Jet 3 Ultra Power Chair
Pheonix plus batery flat,charged up,now it is mobile but all i have on dial is single red flashing led.
John the red flashing light indicates a low battery When you charge the battery your charger should be showing a red light for power and a yellow light. When the batteries are fully charged you should show a red and green light on the charger. Now if you have a voltmeter plug the leads into the two outter holes of the charger port located under the front of the joystick.Without the charger plugged in you will be reading the battery voltage. Fully charged it should read 27-30 volts if you are only reading 20-24 volts then the batteries are low. If you have an onboard charger plug it in and you should read the charger voltage of 29-32 + volts If you aren't getting that voltage then you have a bad charger if you are getting the charger voltage then you have bad batteries and they need to be replaced Hope this helps you
Apr 18, 2011 | Health & Beauty
Will not charge. amp meter does not move. has current all over the chair when pluged into ac
Midway if you hava power when the charger is plugged in and you aren't getting anything when unplugged I would say you have a battery problem. If you have or can get ahold of a digital voltmeter set it to 200 volts dc and plug the leads into the two outter plug holes in the charger port located under the front of the joystick. Without the charger plugged in you will read the battery voltage. It should be 24-27+ volts fully charged. Now plug in the on-board charger and you should read 27-34 volts indicating the charger is working. Hope this helps
Nov 08, 2010 | Jet 3 Ultra Power Chair
Health & Beauty Logo
21 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
