Question about Tools & Hardware - Others
What size battery for vanguard 13 HP engine starter
4 Suggested Answers
SOURCE: New Vanguard starter only spins slowly even when
Did you ever get an answer? Mine is doing the same. I think the starter is toast. I bought a new battery, but spins just as slow. Thanks Ken
Posted on May 05, 2010
Vanny Man
  • 4 Answers
SOURCE: I have a 23 hp Briggs vanguard engine-V Twin Model
It will probally be your valve setting might be off so pull the valve covers off and try setting your valve lash
Heres the factory settings
.006 on Intake
.008 on Exhaust
Posted on Oct 26, 2010
Vanny Man
  • 4 Answers
SOURCE: 18 hp vanguard 165lbs and 180 lbs compression have
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Starter not turn over 35 hp
check that the engine is not seized. have a load test done on the battery as it may be flat or have a dead cell
Dec 02, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Ihave a vanguard 20 hp v twin on my snapper mower you turn the key and get like a kluk sounds like its coming from starter
Does it do it every time? First try and turn your engine by hand counter clockwise and try to start..sometimes the engine stops on a compression stroke and Is Under too much pressure for the initial start,..happened to my cub cadet laast week...,,if it turns and still gets a click...test or charge your battery..if it is ok you either have a bad solenoid or starter...first find the solenoid and croosing the two big post..it should spin the engine..if it spins it is your solenoid if not the starter is bad...not a hard job for either...both can be purchased at your local mower place...giid luck
Oct 24, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Battery hookup for a 35 hp vanguard
Follow the wires from the solenoid its wires go from the battery to the starter, a small wire on it comes from the switch it would be the wire from the switch that is the furtherest on the switch "starting " blade on the switch..the heavy wire to the starter should be red the small wires black..good luck
Apr 21, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Engine won't stsrt as starter won't wind over past compression stroke. starter and battery good
check your valve adjustments, quite common for this to happen when the valves go too far out of adjustment.....it will work better with them adjusted too
Jan 27, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Running a Vanguard 23 Hp on my Mud Motor.\r\nQ1: developing a hard starting problem, seems like starting on 1 cylinder, after the first tank of fuel this fall. Fuel filter, spark, and plug OK. Looking at...
It sounds like your valves are out of adjustment. Your starter will bog down if it is out of adjustment and stop at the compression release.
So just take your valve covers off and set your valve lash to
.006 intake
.008 exhaust
Oct 04, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 23 hp Briggs vanguard engine-V Twin Model 380447/type 76-E1 code 4241. The engine is less than two mowing seasons. The engine will not turn over properly and I have used another start I have and...
.006 on Intake
.008 on Exhaust
Sep 05, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and Stratton Vanguard 23Hp starter issues
take the starter off and give the bendix a realy good clean up and then splash some oil on it,,,they get very dry and sticky at times,,,you can test the starter uasing some jump leads stand on it though, dont hold it in your hands as it will spin out of your grip
hook the black lead to the caseing and tuch the red lead on the starter battery stud,,,it should spin up and strow the bendix out as soon as you take the lead off the bendix should slid back in if it dont oil it till dose also check the starter relay it could be sticking on holding the starter in
Jun 06, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Jan 30, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
