Question about Ruud Heating & Cooling
Fuse location on the 62-24136-01 Rheem IFC
Where is the fuse location on the 62-24136-01? Is it pushbutton or automotive?
  • Matt JS Nov 01, 2012
    Resolved - there is an inline 2A fuse on one of the red wires leading into the circuit board. There is a small black casing breaking the red wire that can be unscrewed, the fuse is inside.
3 Suggested Answers
  • 3 Answers
SOURCE: automotive wire in line fuse keep blowing fuses
sounds like eithor over draw or short
yes you can over draw the wires
Posted on Jan 12, 2010
  • 1033 Answers
SOURCE: How can I tell if my IFC board is bad or my thermostat is not working properly on a Rheem furnace model UGDG-12EARJR
Hello, just jump the R and w wires on your thermostat subbase, if the unit comes on then the thermostat is bad, if not most likely the board.
Posted on Nov 14, 2011
Fuse diagram for poulan model: po17542lt size of fuse and the location of fuse
20 amp automotive-type plug-in fuse. The fuse holder is located behind the dash.
Feb 12, 2015 | Husqvarna Outdoor Poulan PO17542LT Lawn...
Blowing fuses on rheem rtgh 84dv
Call service technician
Check polarity of 120 volt outlet
Call Rheem for new PC board
If the 3A glass fuse located on PC board is blowing, then something is drawing too much current or shorted on board... problem is probably bad PC board
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
Oct 12, 2014 | Rheem RTGH-84DVN Indoor Direct Vent...
Where is the fuse located on my Ridgid miter saw?
Most AC voltage saws do not have a fuse. They usually have a built-in breaker or a resettable thermal overload. Look for a pushbutton near the motor.
Dec 05, 2013 | Ridgid 10inch Compound Miter Saw With...
No power to unit
Copy following link for tankless troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#fuse
Tankless are not protected from surge, but there is a 3-5 amp glass fuse located on circuit board.
Check outlet with circuit analyzer, and multimeter
Apr 28, 2013 | Rheem RTG-95DVLP Low Nox Direct Vent...
Icp/bfc acc fuse keeps blowing
Robert,
Stop changing fuses. There is an overloaded / short circuit connected to the fuse that is blowing. You must locate and clear the source of the fault before continuing. Repeated fuse changing only causes more damage - especially if you increase the size of the fuse. I don't know what "icp/bfc" stands for - but you should contact an automotive electric specialist or purchase the wiring diagram for your car at an automotive supplier to assist you with following / tracing the wire(s) to find the fault.
Mar 26, 2013 | Pontiac 96 97 98 99 00 01 Grand Am Cd...
Where are the control board fuses for a Rheem RGVH-10EBRJR. Fan will not start at thermosat but will start with thermostat red and green wires jumppered.
Two possible locations, one would be a small glass fuse or automotive type fuse located on the PC board. The second would be in-line of some of the wiring. The wiring diagram will indicate where it is. Make sure you have the proper wires leading up to the thermostat in order to turn the fan on. You will need a minimum of 3 for heating (R, W and G terminals).
Mar 12, 2011 | Heating & Cooling
Ruud IFC Furnace Blower comes on and stays running, never lites
Check on the circuit board for an automotive type fuse that is probably blown. These fuses blow because of a short in the control wiring. If the fuse is blown a lot of furnaces run the fan all the time as a diagnostic. You will have to find the short or it will just blow again.
Oct 04, 2009 | Heating & Cooling
Heating & Cooling Logo
87 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
