Question about Pentax PocketJet 3 Plus Thermal Printer
Printer not working
Power and data lights will not go off
Yellow light flashing saying replace cartridge that is flashing when I replace it the yellow light is still flashing
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Install the print head and ink tanks correctly iP4500
Reseat the Print Head and ink tanks iP4500
Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Jan 17, 2011 | Canon Pixma iP4500 InkJet Printer
We have a Zebra 105SL thermal printer. When I print to it with any application, the data light comes on, but it doesn't print. It has ribbon, media, calibrated, no error lights
The data light indicates that the printer is receiving data. Hold the cancel key for 10 seconds while powering on. This will print printer configuration. Use to troubleshoot. If the data or format is wrong it will not print as you send data. Make sure you are using the 105SL printer driver. To test the printer functionality you can go to www.teklynx.com and download a demo copy of labelveiw, select the 105SL printer and try to print a simple label. If you can print with labelveiw then it is not a printer problem. Double check your driver and label format.
Nov 12, 2010 | Zebra 105SL Thermal Label Printer
Power light lit Pause light lit data light flashing and display saying printer idle , ribbon out
Press the pause button to take the printer off pause...
The data light is flashing because it has labels to print...
Check to be sure your ribbon is loaded properly.
Jun 20, 2010 | Zebra 203DPI Printer
How do I reset printer after putting ink cartridge in
To Reset the Canon Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Please rate my rsponse!!
Jan 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Dell 1700n Ready/Data light blinking (secondary fault)
Ok, try this--1.power off printer 2. open front door 3. press and hold continue and cancel buttons 4. power back on 5. wait until light sequence stops om error 6. power off and back on.
this resets factory defaults on the printer..
Nov 11, 2008 | Dell 1700n Laser Printer
Reset ink level meter after refilling bj-w9000
At this stage we have found 2 ways that might work but not guaranteed to work with all machines.
Method #1
  1. POWER off printer
  2. Hold RESUME button then press and hold POWER, the beeper will sound once
  3. Hold POWER and release RESUME
  4. Press RESUME twice
  5. Release POWER button
  6. When the indicator light is steady press RESUME three (3) times. Indicator light should be orange
  7. Press POWER to set data
Oct 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jamed message
I had the same problem and resetting the printer worked. From the Canon website:
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
Jul 20, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon i965 flashing amber light
Hi nnub1,
You might try unplugging the printer from electrical source and try unplugging your data cable from the computer. Shut down your computer and disconnect the data cable. Start your computer and then reconnect the data cable. This is assuming you have a usb data connector.
What you want to do is to try to get the printer back to its default settings. The amber light flashing is trying to tell you something. You should also unload any pending documents to try to get the printer back to its default state, but disconnecting data cables and or power connection is going to be required.
Respectfully,
Terry
Jun 10, 2008 | Canon BubleJet i965 InkJet Printer
Printer
Try re-setting:
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
6: Press Power to set data
Mar 31, 2008 | Canon MultiPASS F80 All-In-One InkJet...
Printer will not print
Below are instructions for resetting the printer. However, if they don't work, you may have to have the unit serviced - if it's still under Canon's 1 yr warranty, go through them... if it's not, I would weigh the cost of repair to what it would cost to replace the unit altogether.
  3. Unplug the printer's power cord for approximately 10 minutes, power down your computer as well -- and unplug the USB cable (from the printer) from your computer,.and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer and computer back on.
Good Luck!
Maggie B
Feb 24, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Pentax PocketJet 3 Plus Thermal Printer Logo
20 people viewed this question
Top Pentax Office Equipment & Supplies Experts
Johnny Massengill
Johnny Massengill
Abdul Mannan
Abdul Mannan
Are you a Pentax Office Equipment and Supply Expert? Answer questions, earn points and help others
