Question about Garmin KVH TV/SAT Switch SATELLITE RECEIVER
Splitting satellite signal
I have two LNB's from one dish which havwe 4 cables running into a switch. From this switch there are 4 cables supplying signal for my HD tv (2 cables) and two regular tvs (1 cable each) My problem now is trrying to supply a signal to a 3rd reg TV Can this be done with a splitter of some kind?
    New Friend:
  • 132 Answers
Standard spitter can be used for regular TVs. If the signal degrades, it can be boosted with an distribution amp, and could go to 100 TVs on channel 3 (for instance).
Posted on Jan 23, 2010
No signal on my starview s2828+ box
Three things here the unit the cable or the LNB.
Simple things first Cable
1.cable
Check the satellite plugs on Both ends are correctly fitted and there is no shorting of the core central cable and the shield. Check the cable with a meter put a loop( connect core to shield at one end) on the other end and check resistance.
2. Unit
Check your unit with a know good setup a friends perhaps.
3. LNB the unit on the arm of the dish
You should be able to get a signal from the LNB with a alignment meter. or replace with known good to test
hope that helps
Dec 06, 2013 | Televison & Video
Dish 722 not acquiring signal
doktourtv,
That's great to hear that you've been provided the appropriate resolution for the issue you've experienced and I do apologize for the delay! If you need help with anything else, please let me know so that I may provide further assistance. My email address is michael.lemar@dish.com and I hope you enjoy your service!
Jun 02, 2012 | DISH Network ViP622 DVR DTV Receiver /...
Dish 722 not acquiring signal on boot up. must disconnect antenna cable and reconnet then works fine. Dish Tech support is useless and my contract is up in 1 month, so I am considering canceling. Any
If you can monitor the supply to the LNB, you may find it is low, unplugging it when the decoder is powered up allows for more power. I would change the power supply capacitors if more than a couple of years old.
Feb 28, 2017 | DISH Network ViP622 DVR DTV Receiver /...
My satellite is on 129 and 119 and I want 119 and 110. I have move skew, height , and azimith with no luck. I can always get back to 129 and 119. Does the satellite default to these numbers once check...
How many coax cables are you using from your dish, 1 or 2? Do you have a switch between the dish and receivers? I am assuming your have a 1000.2 dish since you say you have the 129, 119, 110. On the LNB you have 4 coax ports. Facing the LNB, the port on the far left is for 119, the next is 110, then 129, and that last on the far right is for an additional dish. If you want to get 119 and 110, just use the 2 ports on the left. Once connected, run your check switch. I hope this helps.
Jun 27, 2011 | RCA DISH Network(r) 311 Satellite System
HOW TO HOOK UP TWO SATELLITE RECIVERS THAT I HAVE LIKE MODEL 4000 DISHJNETWORK RECIVER I FOUND IN MY CLOSET AND MY NEW DISH NETWORK RENTED DVR 625 RECIVER HOW TOO HOOK BOTH OF THEM UP TO THE 3 CABLES AND...
Ok since you have A 625 it uses different technology than the 4000 in a sense but I will assume that whomever connected the 625 use a Dish Pro Plus LNB. You can verify this by going out to the dish and looking at the LNB which is the eyes if you will on the dish. The cover facing you will read DP Plus, or Dish Pro, Dish Network, or you may have nothing at all on the housing. You will want it to say DP Plus for the easiest install.
On this LNB there are three ports. You will only need the two on the left if looking at it so you can not read the housing. One of the ports will be connected to a line running to the 625 and the other to the 4000. The line going to the 4000 should not contain any breaks in it after the ground block if one was used. Once inside the house connect the line from the lnb for the 4000 to the back of the receiver. Conect the receiver to the TV and run a check switch. This receiver will go into a test of 1 of 38 if all connections are good. A 1 of 50 indicates a loss of signal somewher on that side of the install.
The 625 can utilize di plexers but that type of install is to detailed to go into straight away so we will connect it using a straight feed to TV2. Run the cable from the LNB into th room with the 625. Inside connect that line to a siver device called a seperator that came with the receiver and connect the two leads from it to the sat in ports on the back of the receiver. Connect a line to the Home distribution port on the back of the receiver and run it to the room with the second tv you want to have DVR in such as a mater bedroom etc.Connect the cable from the tv out port on the receiver to the tv. Power all devices on and run a check switch. This test should read 1 of 3 if all connections are good. A bad connection will read 1 of 38 on the receiver. A total absence of signal will stay at 1 of 1 for a longt ime brfore going to 1 of 38.
You will need to call dish and activate the 4000 rx since it has not been on the account for some time and will need a software update that they will send to it via satellite.
Other obstacles could arise and if they do let me know. Thanks for using Fix Ya.
Feb 28, 2010 | DISH Network DVR-625 DTV Receiver /...
Changed from single to twin LNB, no signal
HELLO
Here is a suggestion! Try SKEWING the LNB around a few degrees. Looking at the front of the dish, turn your LNB to the LEFT slightly (that is anti-clockwise).
Sometimes it's the little things that matter most where installation is concerned. It is also possible that due to the weight of the new LNB, the alignment may be out.
Nov 21, 2009 | Fortec Star Lifetime ULTRA
Dish Network - Dish 500 Satellite 110 is not being recognized
You will need a DP or Legacy twin or quad, or DPP twin without using an external switch. If you use Legacy Duals, or DP Duals you will need a switch. USUALLY a SW21 is used to combine the signals but you may have a different one in use if at all.
The primary thing to remember when using a switch is that you must use the same type of LNB as switch e.g. Legacy switches with Legacy LNB's and Dish Pro switches with Dish Pro LNB's.
Check your LNB type. Legacy LNB's have only a Dish Network Logo on them, Dish Pro has DP on them and DPP have DP PLUS on them.
One of three things could be the cause:
1. Line of site. Must be clear of all obstructions to ensure adequate signal.
2. You have a faulty switch, or conflicting LNB and switch, or no switch at all.
3 you may have a bad port on the LNB.
As a fail safe check that your mount is level and plumb. You also may have the dish pointed directly at 119. Check the Skew and elevation settings as well. If LOS IS THE ISSUE YOU MAY NEED TO RELOCATE THE DISH OR REMOVE THE OBSTRUCTION.
In some extreme cases microwave towers and High Voltage lines also pose a problem but doubt this is the case for you.
Sep 04, 2008 | DISH Network 301 DTV Receiver
I have a Dish Network system with two receivers. One of them is a two room DVR. All is received thru one satellite dish that's been wired up with lots of splitters. The problem appears to be a...
There might few possibilities:
Loose cable from the receiver to the diplexers, switches and LNB.
Defective LNB.
I would suggest to try swapping the receivers to isolate the possibility that one the receivers might defective as well.
Hope this helps.
Apr 30, 2008 | Televison & Video
Satellite dish receiver error LNB Drift detected
that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
Apr 22, 2008 | DISH Network 301 DTV Receiver
Hi. I need help finding 119!
I looks like you are picking 110W with the LNB on your left if you are facing the dish.
Try to get 119W first if you connect the cable to the 119 LNB, once you find 119W that way, you will also have 110W.
Good Luck.
Feb 24, 2008 | RCA DISH Network(r) 311 Satellite System
Garmin KVH TV/SAT Switch SATELLITE RECEIVER Logo
77 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
