Question about Home Security
Have safe bolted to wall cannot find istructions to remove from wall
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
Normaly its bolted from the inside to the outside look for screws with
everything out and look for screw covers you open up to acess the screw or bolt
Posted on Nov 01, 2012
What are the advantages of gun safes?
children are denied access to fire arms
the fire arms are stored in one place under lock and key
the safe is mounted by bolts to a wall and cannot be easily stolen
it is a requirement under law to have the fire arms controlled
being under lock and key , it acts as a deterrent so that people with anger management problems have no legal claim to say it was an "involuntary act" when removal of life is committed
Dec 12, 2015 | Locks & Locksmithing
Do you have a service center in Mindanao, Philippines
I am not part of any manufacturer or service group. However there are a couple of common problems that are easily fixed. One very big one is some debris or fire proofing falling out of the door or frame getting trapped in the way so the door doesnt seal. Also it can fall into the holes if there are any and block the bolts. First will it lock when in the open postion?? This may require locating the door bolt stop inside the door hinge. It stops bolt travel if the door is open. Pushing it into the safe will move the stop and the handle to be free to through the bolt or bolts. If the handle does move and lock and you can turn the dial then it will be the issue i described above.
If you cannot lock the door in the open position with the retainer pushed in then it is inside the door mechanism. I would refer you to your local locksmith who is also a safeman. You could open the back plate and explore if you have mechanical skills and feel comfortable. However i recommend a safeman. Good luck!
Oct 13, 2014 | Sentry Fireproof Safe
I haved a Sentry "Professional
Bolts can be found at any hardware store, just make sure you get the right type for the flooring it's to be bolted to, and leave the wheels on. Desiccant packs can be found at shooting supply places, but a longer term solution comes in the form of a rod that you plug into the wall which will keep the temperature in the safe a few degrees warmer than outside, thus preventing condensation.
Sep 09, 2011 | Garden
I can not locate the key for my Gary safe and the batteries are dead. Can I open it without the key to change them?
No, the key is the only way to open the safe should the batteries fail or you forget the combination.
Aug 04, 2011 | Safe International Gary Gary Personal Safe...
I have broken two of the bolt fittings on the back of the t.v trying to attach a wall mount bracket. two of the four bolt fittings have fallen into the t.v now ??? How do i safely get them out and fix...
UNPLUG SET. Lay set flat on a blanket and remove all the cabinet screws. The back will come off and you can search for the nuts. If they won't go back in place then at least don't leave them in the set. A strip of duct tape will hold them in place and shouldn't interfere with the bolt.
Jun 17, 2010 | Televison & Video
I work at a retirement community where one of the residents had left a safe. It's bolted to a wall and needs to be removed. Somehow the door was closed and now we have now way to open it. We have a 'key...
I know Bunker Hill are sold through Harbor Freight I would contact them for information:
http://www.harborfreight.com
They are a cheap safe and should not be too difficult to break into if you have to get a safe cracker involved.
Hope this helps,
Thanks
Jan 20, 2010 | Sentry Floor Safe
I forgot combo'
If you have lost the combination, and the safe is closed, you will need to contact Sentry to get an emergencey access code. Sentry charges $12 to release emergency access code.
Here is the unloack page.
If the safe is open, then you can also try istructions here:Lost combination or keys WARNING
Jun 26, 2009 | Sentry Fireproof Safe
Taking the base off
Please tell me what TV it is and give me a model number, once i know that I can be of easy help.
Have a great day
Jun 04, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
