Question about Health & Beauty
How can open the motor body - Health & Beauty
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
Screws are under stickers or rubber plugs ect. and some are glued
and cant be
Posted on Nov 01, 2012
Where is the Engine Throttle Position Sensor located in my 2007 Cadillac DTS
It is located in the throttle body assembly . Your vehicle has electronic throttle control .
Throttle Body Assembly
The throttle body assembly contains the following components:
The throttle blade
The throttle actuator motor
The throttle position (TP) sensor 1 and 2
The throttle body functions are similar to a conventional throttle body with the following exceptions:
An electric motor opens and closes the throttle valve.
The throttle blade is spring loaded in both directions and the default position is slightly open.
There are 2 individual TP sensors within the throttle body assembly.
Oh yea it has two TPS - throttle position sensors ! An you have to replace the whole assembly !
Oct 19, 2015 | Cadillac Cars & Trucks
Throttle body not working
if you have fuel pressure at throttle body make sure you have power to (nodes) at top of throttle body that opens to let fuel into motor
Sep 23, 2014 | Cars & Trucks
Throttle body
Cleaning the throttle body often fixes this problem otherwise you will likely need to replace the throttle control motor. At the throttle control motor monitor the clutch operation. Check to see if the computer is supplying the clutch circuit with a 12 volt square wave pulse signal. With the key in the on position, check to see if the throttle motor makes a buzzing noise as the throttle is opened and closed. With the key off, push the throttle plate open with your finger and allow it to close. The throttle plate should open and close smoothly.
Aug 16, 2013 | 2000 Toyota Tundra
2001 Acura mdx abs light stays on. Code reads 04?
I think you pulled the code incorrectly, or are reading it wrong. To get code:
1. Jump pins 4 & 9 on OD2 connector.
2. Turn key 2 clicks.
3. ABS light should blink to give you code. (long blinks for first digit, short ones for second. Example: One long blink and three short blinks would be 13).
Honda ABS trouble codes list :
11= Right front wheel sensor (open/short to body ground/short to power)
12= Faulty right front wheel sensor pulse signal
13= Left front wheel sensor (open/short to body ground/short to power)
14= Faulty left front wheel sensor pulse signal
15= Right rear wheel sensor (open/short to body ground/short to power)
16= Faulty right rear wheel sensor pulse signal
17= Left rear wheel sensor (open/short to body ground/short to power)
18= Faulty left rear wheel sensor pulse signal
21= Continous Operation (chipped pulser)
31-38 are all the same: "solenoid"
51= Motor lock
52= Motor stuck off
53= Motor stuck on
54= Main realy stuck off
61= Ignition voltage
81= CPU (central processing unit)
Jul 03, 2013 | Cars & Trucks
Trouble code p2104 & p2112 for 2005 ford explorer xlt
There is a motor on the throttle body that opens it
It is called a Throttle Actuator Control Motor (TACM)
Those are the codes you got
DO NOT replace the throttle body
Spray the throttle plate with- CRC Throttle Body Cleaner
You should also have COP Ignition Coil-- Codes
A bad coil may be spiking the PCM,coming back
on the TPS and setting thoses codes
Mar 09, 2011 | Ford Explorer Cars & Trucks
My service engine light is on. and I took it too autozone to be checked and got the results: Large vacuum leak on engine, 2. throttle body condition-dirty and faulty IAC valve/throttle. what does this...
These are all things that can affect your gas mileage and engine performance.
To check for vacuum leak, look for unhooked hoses on top of engine. If OK, use starter fluid and spray along intake manifold gaskets with engine running. If engine speeds up, there is a leaking gasket.
IAC deals with idle. Does the car idle smoothly? If not, remove IAC to see if it's dirty. I will paste instructions below for the IAC valve.
Throttle body dirty--what code is this? never heard of such a code, but you can clean the throttle body wioth carb cleaner. I will paste instructions below.
IAC valve info:
Operation The amount of air taken in during idling is regulated by the opening and closing of the servo valve located in the air passage that bypasses the throttle valve. The servo valve is opened or closed by the activation of the stepper motor (incorporated within the idle air control motor in the forward or reverse direction. Battery positive voltage is supplied, by way of the MFI relay, to the coil of the stepper motor. The engine control module switches ON the power transistors (located within the engine control module) in sequential order, and, when current flows to the stepper motor coil, the stepper motor is activated in the forward or reverse direction.
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Detach the electrical connector at the sensor.
  3. Remove the sensor from the throttle body.
To install:
  1. Install the sensor in the opening in the throttle body and tighten the sensor.
  2. Attach the electrical connector to the sensor.
  3. Connect the negative battery cable.
Testing
Checking Coil Resistance
  1. Disconnect the idle air control motor connector and connect the jumper (test harness).
  2. Measure the resistance between terminal (2) of the connector at the idle air control motor side and terminal (1) or terminal (3). Standard value: 28-33 ohms at 68°F
  3. Measure the resistance between terminal (5) of the connector at the idle air control motor side and terminal (6) or terminal (4). Standard value: 28-33 ohms at 68°F
  4. If not within specifications, replace the IAC Valve.
  5. If within specifications, check connectors and wiring between the sensor and ECM/PCM.
Checking Operation Sound
  1. Check that the operating sound of the stepper motor can be heard over the idle air control motor when the ignition switch is turned to the ON position (without starting the engine).
  2. If no operating sound can be heard, check the stepper motor drive circuit. (If the circuit is good, a defective stepper motor or engine control module is suspected.)
    IAC picture--mounted on top side of engine.
      Throttle body--loosten clamp to right of throttle body and pull hose off. Use electric parts cleaner or carb cleaner--spray on dirt with engine running. don't touch any sensors inside throttle body--sensors are delicate.
    Oct 11, 2010 | 2005 Mitsubishi Endeavor
    Turn on ac and the motor dies
    Sounds like the throttle body is going out or just dirty. It has an electronic throttle body that controls the idle. I would remove the air tube that comes from the air cleaner from the throttle body. Prop the throttle blade open, clean it and the throttle body with carb. cleaner, rags, and a toothbrush. If this doesn't take care of it I would replace the throttle body.
    Dec 11, 2009 | 2004 Chevrolet TrailBlazer
    Engine sometimes stops during traffic. only happens when the aircon is open what do you think the problem? is there anything to do with my fuel pump or compressor or the engine?
    I'd remove & clean your idle speed motor first. Referred to as a.i.s. , or i.a.c. motor, but they are same thing. It controls idle under load, for example when AC is on, turning, electric fans kick on etc. Get some throttle body cleaner(spray) and do inside throttle body opening too.
    Jul 16, 2008 | 1992 Nissan Sentra 4 Door
    Health & Beauty Logo
    16 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
