Question about Crosley CR249TA Turntable
Tone Arm skips past first song
I just got a Crosley CR-249 USB-enabled Turntable for Christmas, and went out and bought a whole bunch of albums, but when I tried to play the first one, the tone arm skipped about 2/3 of the way past the first song. When I place the arm on the edge of the album, it rips across about a quarter of an inch into the album, instead of starting right at the edge.
I think the cause of this is the auto-turn-on feature for the motor. The arm "clicks" after I start to swing it over to the album, thus turning on the motor and causing the album to spin. BUT, that little click is what pushes the arm over too far.
Is this just a problem with the CR-249 (along with the fact that the case itself is TOO SMALL to be able to close the lid while an album is on the turntable... sad...), OR is there some fix to this?
Thanks!!
  • stephenjlind Jan 08, 2009
    Thanks Lovesmesumca :) I didn't try to close it after the first "oops" (fortunately nothing broke!).
    There is a cue lever, and I have been using that, but with or without it, the tone arm does the same thing. I saw on the Cosby Show tonight that Cliff had to put a quarter on his tone arm to keep it from sliding over. That extra weight solves the problem 1/4 of the time.
  • i1234 Mar 17, 2009
    i have the same problem! did you ever fix it? I tried taping a nickel and that actually works but you have to place it really carefully at the beginning. it's natural positioning places 2/3 into the song. it's kinda annoying. i called crosley but couldn't get thru
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Posted on Jan 08, 2009
The tone-arm on my turntable automatically stops too early. Is there any way to fix this?
Yes. you need to set the travel on your arm. I don't know your specific model but they are all the same concept. On the back by the pivot point there should be a small screw that you can adjust the travel before it returns.
Dec 31, 2015 | Audio Players & Recorders
Crosley CR6019A turntable skips
Hi
Being a portable model, it is very easy not to have the turntable level. It is very important that it is level as a tilt can lead to the head "skipping", amongst other things.
You can get a full User Guide here
http://0bee184f253cf7f48610-d2b1caba160808a264f409f8f32a9b54.r0.cf3.rackcdn.com/Crosley%20CR6019A%20%20Executive%20Turntable.pdf
Another possible problem is that the balance has become upset by being moved around. The correct balance is achieved b the positioning of a weight on the tone arm on the opposite end to the needle. This can usually be moved short distances to balance the tone arm so that the needle is held in the record groove, by the minimum necessary weight on the needle.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 26, 2014 | Audio Players & Recorders
Why is my brand new crosley turntable keepsake hunter skipping tracks?
The turntable may not be level. Also, the stylus could be damaged or defective. The stylus pressure may not have been set correctly in production or may have been affected by shipping.
May 05, 2014 | Crosley Keepsake USB Turntable
Jensen JTA 450 turntable skips?
Try moving the arm up to the end of the vinyl, if it does go till the end of the vinyl then try adjusting your counter weights, a penny will do, if it doesn't go till the end of your vinyl then there's a mechanical problem check any obstruction at the botton of your arm.
Jun 09, 2010 | Audiovox Jensen JTA450 Turntable
My brandnew Songwriter is not playing records properly. When a quarter is placed on the tone arm, it plays fine. Is there an adjustment I can make??? Marilyn
http://www.crosleyradio.com/Manuals/CR248_Manual.pdf
I didn't see the tone arm balance adjustment in the user manual, however that is what needs to be done. At the rear of item #39, on page 10, is there a dial with numbers from 0 to 4 or 5? If so, set the dial to "0" to see if the tone arm will "balance" (like a see saw) If not, the dial assembly (which is a weight) needs to be slid either forward or backwards to achieve balance. After balancing, turn the dial to a number higher than 0 to increase tracking force..keep increasing the tracking force until it stops skipping, but no more than necessairy. To much force causes wear/damage to albums. If there is no tracking force adjustment on the tone arm, I would suggest contacting Crosley @ http://www.crosleyradio.com/Support.aspx
Hope this helps.
Aug 18, 2009 | Crosley CR248 Turntable
Tone arm retracts before recording is complete (CR-245)
actual old units (not sure about modern nostalgics) sometimes had a lever that said 7 or 12 inches for 45's or 33's this would tell the mechanism when to set down the arm. If your unit does not have something like this then it sounds like an internal failure that would require it being opened by a tech or sent in for warranty repair.
Feb 10, 2009 | Crosley CR249TA Turntable
Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Jan 03, 2009 | ION Audio iTTUSB Turntable
Got crosley CR-249 for xmas. no cd in box to install
You have a warranty? I would call the company you bought it from and tell them that you had no CD. They will probably replace it.
Dec 28, 2008 | Computers & Internet
Crosley CR249TA Turntable Logo
1,091 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
