Question about Maytag Bravos MTW6600T Top Load Washer
Washer Senses one time then the lid lock blinks and the lid unlocks! It won't start or fill
MVWX600XW0
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Here is the service manual for your machine. Look at 6-4 for diagnostic mode.
Posted on Nov 02, 2012
kel1guy2002
  • 3740 Answers
SOURCE: WASHER STOPPED
Hi and welcome to FixYa. I am Kelly
Just as you raise or close the lid you should hear an audible click from the lid switch. It will be faint but audible. If you do not hear a click then there is a problem with the lid switch. See item 18 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47786&diagram_id=675654#d675654
1. Unplug the washer.
You gain access to the lid switch by removing the 2 screws in the lower front panel then pull the bottom of the front panel toward you / outward then off. After that you will remove the 2 bolts (Item 20 of link above) and tip the top straight up from the front. The lid switch will be in the center of the back of the lid area inside the top panel.
If there is water in the unit select SPIN on the timer.
You can remove the 2 wires from the lid switch and jumper them together to see if the machine works. If it works the lid switch is bad.
Reassemble in reverse order....
If you still have problems after trying this just respond here and I will get back to you asap.
Kelly
Posted on Apr 18, 2010
dh1200s
  • 335 Answers
SOURCE: maytag neptune washer stops after filling
Hello n8mtsn,
I would pull the 120VAC power cord to the washer for 10 seconds then power back up.
See if you can get into service mode. To enter Service Mode press and hold he Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”. If you can’t get into Service Mode I feel you have a Control Board issue/failure.
If you can get into Service Mode then go to page 15 of the SM and we want to try a Quick Service Cycle test. Follow the instructions to enter the Quick Service Cycle test and let us know the results. If the test will run it will take about 10 minutes.
Link to Service Manual for reference. Sears Parts Direct for reference.
Rich
Posted on May 30, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: my maytag neptune washer model#FAV9800AWQ keeps
I’m an owner of the FAV6800A LED console display version. You have the LCD console.
This issue could be related to a failed Control Board a failed Motor Controller. It could be related to loss of signaling to and from the lid locks.
What is your skill set level can you use a DVM to measure D.C. voltages in the machine?
If not I would recommend a knowledgeable repair service to help resolve the issue and that may be a challenge. But read on and maybe we can get you to look at the Left Hand Lid Lock,
You can raise the washer lid from the base to remove your clothes from the wash basket with this process and the Service Manual . Don’t break the Left Hand Lid Lock latche if you do you will need to replace the Left Hand Lid Lock. The machine only needs that Lid Lock to operate as designed.
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
Diag code 4 for both machines = The lid fails to lock. Look on page 25 for the error code description in then points you to this “”Go to "Will not unlock" Troubleshooting Section””. Confusing right?
I think you could have corrosion issues with the Left Hand lid lock. If you want to DIY this part of the machine see this post for Left Hand Lid Lock Troubleshooting.
Take a look and see what direction you want to go…..Rich
Posted on Dec 31, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: filled with water and won't drain
You’re in the FAV6800a/FAV9800A forum so I’ll assume it’s one of those models. You can do this from Service Mode the method I prefer less messy, just follow this process it’s in the SM but I typed out for ya.
To pump out the excess tub water while failing to complete spin cycle.
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with the off button or hit the Presoak key.
Sorry to hear about the over fill. May be you have a stuck water valve or stuck pressure switch. If you want some help just verify the Model type…..Rich
The Service Manual for reference. Sears Parts Direct for reference.
Posted on Apr 25, 2010
  • 251 Answers
SOURCE: The door on the washer
HI - UNDER THE CORNER OF THE SOAP UNIT YOU WILL FIND A GREENISH YELLOW NYLON - PULL ON THAT TO UNLOCK THE DOOR.
Posted on Jun 24, 2011
Spins basket once then won`t start blinks 7 times
Check switch under the top of the lid it will not be working feel around under the lid located usually on either side
Apr 30, 2015 | Whirlpool Washing Machines
I have a Whirlpool Cbrio top load washer. it won't start it's cycle. Once it senses the load, the lock lid light flashes and it does nothing. can this be fixed?
I would say that the lock has failed. Either the lock itself or maybe the pin or latch that fits into it when you close the door may have cracked / broken. If the machine thinks the door / lid is still open, it wont let you start it.
Jan 03, 2015 | Whirlpool Washing Machines
Unlocking your washer so it actually works.
If the green cycle light is flashing on then off, this usually means the cycle is paused. The lid lock should unlock when in pause mode, if not you will need to press and hold the "Pause/Play" button to clear the cycle completely, if there is water in the unit, it will drain first, then unlock the lid and be on standby to start a new cycle. Pleazer Appliance...
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
The lid lock light won't stop blinking.
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
734 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
