Question about Ovens
The generator won't start we think it has to do with the pull rope not pulling and winding up.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Spring inside what controls the cord can fail,you can take alook inside ,any good lawn mower shop will sort you out with parts and spring back coil
Posted on Nov 01, 2012
Whirpool Electric Double Oven
1-800-269-2609 call them and they can www.repairclinic.com
Dec 23, 2007 | Ovens
How do i put a screw back into a wallowed out hole
Use a larger self-tapping screw. Drill out the hole the screw goes thru the same diameter as the larger screw.
Jun 02, 2015 | Ovens
I.have a sears weedwhacker 316731970 that has no resistance when using pull starter
If the engine has no compression(resistance), it may have a bad head gasket or piston/cylinder damage. If you remove the exhaust muffler on the engine, you can see the piston thru the exhaust port to see if it has damage. Remove the spark plug from the engine and pull the starter rope slowly while looking into the exhaust hole (the area that the muffler was just removed from). If the piston is good it should look like just a round piece of clean aluminum with a few piston rings on it. It the piston is bad it will probably have many vertical scratch like lines on the lower half of the piston. The piston may also have multiple metal looking colors other than aluminum on the lower piston. It is common for many to damage the engine by mixing the fuel/oil mixture with to little oil or even the incorrect oil type.
Jul 22, 2014 | Ovens
Help it lights up but no heat.
Dont use it! You need to pull the cooktop and see what is wrong. There is a chance that the circuit for the surface light is the only standing circuit left because the heating element is bad or loose
May 20, 2013 | Ovens
Have a microwave oven Litchenaid model # KEMC307. The light bulb doesn't go on anymore and we would like to replace it. I assume it is a halogen with 2 prongs that pulls out but it is very hard to get a...
Ok, pull the oven out, remove the 2 screws on side trim of oven, remove the screws from trim under oven, now above the oven, remove the other 2 screws behind the grill. This should give you enough room to pull the unit forward. The bulb is on top. Hope this helps.
Jan 04, 2011 | KitchenAid KEMC307 Electric Double Oven
My oven won't heat up properly
wire brush the oven pilot light orifix flame may be lessened due to carbon buildup then when oven lights its convextion pulls the pilot flame away from thermal coupling with shuts off gas (in case wind blows it out, it will STOP the GAS FLOWING. if the pilot full size (near 3/4 inch tall) then just try to position the thermal coupling nearer the flame (not right on it)
Nov 22, 2009 | Ovens
Hot steam from oven
your oven does not generate steam, only pulls moisture out of what you you place inside of it, poultry being the highest moisture content, i would look into what you are cooking
Nov 18, 2008 | GE JGRP17 Gas Single Oven
BM - After Self-Clean Problem -- 30
Brain, check your thermal fuse first. You can do this at the board. lower oven, p26-2 orange or p26-4 red wire to red wire at the terminal block. Should show closed circuit. Upper oven, p18-4 red or p18-1 red to red wire at terminal block. Should read closed circuit. If open, there is your problem. Control transformer is as follows, primary windings, P16-5 red to p16-7 red, 75 to 95 ohms. Secondary windings, p16-2 blue to p16-3 blue , 2 to 4 ohms. I do believe your problem is in the thermal fuse on the back. Post back, Catriver
Jan 29, 2008 | Whirlpool GBD307PDS Electric Double Oven
Door is locked- F53 Error
OK...you need to replace the lock, but first you need to get the darn think open. I looked at it, couldn't figure out how, and left it. My 14 yr old starting looking at it (after the kids had their TV, Ipod, etc taken away from him for the weekend.....) and he took a coat hanger from the side to pull the latch open.
The rest is straightforward sheet metal disassembly except for the front panel...label the connectors with a piece of tape before you pull the cables connecting the front panel (unless you are able to read a schematic). You can buy the part from AppliancePartsPros.com
AP2836100 (486324) Latch, door (microwave)
for about $100....next day delivery, and your ready to cook your Christmas goose!
Aug 22, 2007 | Thermador C302U Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
