Question about Revell Toys
65 Chevy Stepside short box under box sill (manual) loactions for mounting box onto frame
2 Suggested Answers
  • 701 Answers
SOURCE: 2001 chevy s10 ,4.3 liter I
Hello poppylambert: My name is Roger and I will help you. The fuel pump relay is located under the hood. Locate the fuse box on the left fender. Remove the cover and turn it over. You will find a listing and location of all fuses and relays on the inside of the cover. The relay is not under the vehicle. The fuel pump how ever is located inside of the fuel tank. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Posted on Jun 22, 2011
Is the cross member under the load
cross members are the chassis members that tie the side frame rails together. There will be one at the front and another at the centre of the chassis and one at the rear . There is a bolt in cross member at the rear of the gear box (rear engine mount). Most modern cars are uni-construction (that is the body is complete and the front section will have a front cross member and the sub-frame rails will be bolted under the body around the front door pillars and onto the fire wall.. IN heavy vehicles there is a front cross member the carries the front engine mount another after the gear box to carry the cabin mounts and then a member every 3-4 feet to the end of the chassis rails . Their only purpose is to tie the chassis rails together.
May 03, 2014 | 1989 Chevrolet G20
How to change mounts
place a trolley jack under the body sill / floor ( use a piece of board so the you do not dent the panel). Un do the body bolts through the insulators and lift clear of the chassis enough to push out the rubber insulator . Fit new insulator ( soapy water will help) and lower the cabin onto the rubbers and install the body bolts tight.
Apr 11, 2014 | 1994 Ford F150 Styleside Supercab
Install instructions
I'm not sure if you have the stepside or box but go here for instructions.
http://www.extang.com/how.html#blackmax
Nov 25, 2013 | Blackmax Tonneau Cover 2004-2012 Chevy...
Have 2009 Galaxy, cannot find the "jacking points" where I could put a sissor jack. Do not have indentations in sill to indicate jacking position, can you advise?
Big problem on all vehicles
You don't have a manual or you
wouldn't be asking
This I will tell you
Do not use the sills or rocker panels
even though you see that in the service bays
You only can jack on the sub frame members, next
to any suspension mounting points. Then you have no
where to put your jack stands. This is a real problem
Just have to be real slow and careful and use common
sense not to bend something. I 'am trying to help,sort of
Feb 26, 2011 | Ford Grand C-Max Cars & Trucks
Can anyone tell me what the capacity of the side saddle tanks are in the 87 chevy V10 stepside eiyh s 5.7? Need to replace fuel pumps and can only find 31 and 40 gallon capacity...
Inside the glove box is a label with codes printed on it
Most start with a letter then numbers following it
The tank size is determined by the code
This code chart is a production chart of what is installed upon building this vehicle
On the web you can determine what you have by these codes
Look at this chart by clicking onto the link below to find your size tank you have in yours
http://eogld.ecomm.gm.com/images/mediumduty/techspecs/fueltank.pdf
Dec 26, 2010 | 1987 Chevrolet V10
1997 mercury tracer gas filter loaction
It's under the hood, driver side, rear engine area, passenger side of brake booster, mounted on firewall, about half way down.
May 13, 2010 | 1997 Mercury Tracer
Cant locate fuel filter for my 96 chevy blazer
Under vehicle, driver side, below seating area, driver side of transmission, mounted on frame rail in fuel line .
hope this helped
thank you
jm
Jul 29, 2009 | 1996 Chevrolet Blazer
License plate light does not work
you have a fuse box under the hood and in the in side the fuse you are looking for is in the in side that should take care of it if not you have a bad ground
Jul 07, 2008 | 2003 Chevrolet S-10
Toys Logo
26 people viewed this question
Top Revell Toys Experts
ray gallant
Are you a Revell Toy Expert? Answer questions, earn points and help others
