Question about Car Audio & Video
Anbotek shuts off when in motion - Car Audio & Video
GMOS-04 wiring kit for 2005 YUKON DENALI XL
You need to talk to the experts on auto sound issues like this one.
www.crutchfield.com
Jul 05, 2016 | 2005 GMC Yukon Denali
I was wondering how u turn it off
How to Enable (or Disable) Motion & Fitness Tracking with ...
osxdaily.com/2015/04/05/toggle-motion-fitness-tracking-iphone/
Apr 5, 2015 - If you turn this off, the pedometer feature and all related fitness activity monitoring functions on iPhone will cease, whether you read that data in ...
iPod & iTunes For Dummies, Book + DVD Bundle
https://books.google.com/books?isbn=047059070X
Tony Bove - 2010 - ‚ÄéComputers
After the iPod shuts itself off or you turn it off, the preference for the Sleep ... Apedometer counts each step you take by detecting the motion, measuring your ...
Jan 08, 2016 | Exercise & Fitness
Refuses to start when hot after driving,and stalls switches off in motion when trying to acceerate
Well, if it's overheated it won't start. It's shutting off while in motion because it's over heating. An engine wasn't meant to run under these conditions. Fix your overheating problem first, then you'll not have a problem.
Sep 25, 2014 | Cars & Trucks
Why when washing hands, faucet keeps shutting off.
Motion sensing technology is a great feature but has some limitations. The motion sensing is limited for one main reason if it senses motion to far away from the faucet the faucet would come on when you walk by so the motion sensor is very restrictive in it's distance and angle of sensing. When you first start washing your hands you probably bring them in close to start the faucet but then lower them or bring them further away from the faucet. This in turn takes your movement away from the sensing eye and the sensor stops sensing movement and shuts the faucet off. Try finding out what distances the sensors movement to see where it stops recognizing that there is someone using the faucet. this will give you an idea of where you have to stay when using the faucet to keep it sensing correctly. I know this seems like a loto f work to use something so intelligent but in fact the faucet is very dump and has a limited function pattern.
One thing to also check if the faucet was working fine but then just started to malfunction is that the sensing eye is not dirty, covered in mineral deposits or the lens is not scratch badly. All the above problems can cause the sensor to miss read motion or have trouble sensing motion. Since this is a moen they are usually very good about replacement parts.
Jun 10, 2014 | Moen One Handle High Arc Pulldown Kitchen...
Installed dual DVD headrests, they both get power to them because the buttons light up...one screen flashes white then turns black, the other screen stays white. None of the buttons do anything, not e
Sorry I can't help you but maybe you can help me. I also ordered a set of these Anbotek DVD headrest players on ebay a few months back and trying to figure out how to install them in the minivan. Did you get any instructions? If so how did you get power to them so they work? Any help would be appreciated. thanks
Jan 19, 2014 | TMI Products Vizualogic Headrest Pair...
Motion sensor outdoor light won't go off
How long has this been going on? Has this light fixture been updated recently? Has the lite switch been changed that operates this fixture?
Feb 23, 2013 | Cooper Lighting regent light BRZ Motion...
Installation instructions for a Cooper Wiring Devices OS310U-W-K Motion-Activated Occupancy Sensor Wall Switch, White
LED bulbs with leaking motion sensors tend to flicker as well, more so than CFL. I switched to Cooper style - but now my Cooper OS310u will sense motion - and keep sensing motion almost all the time. If it's in test mode - it will shut off but otherwise it keeps sensing it. This is in a garage - and door open or closed does not seem to affect it. I have the same unit working in my basement just fine.
suggestion - don't try LEDs to solve the problem and yes - it will burn out your CFLs real fast.
Jan 12, 2012 | Electrical Supplies
Heat goes off after a min. in use. Whirlpool Model # LGR4634JQ2. Took apart back and cleaned exhaust.
if it's gas it could be that the pilot is not close enough to the gas sensor and when the drier is in motion the extra air motion shuts it off.
if its elect it could be that one of the fuses are not set shut both fuses down and turn them BOTH back on
Gas clean the elect pilot and be sure it is close to the sensor that looks like a little tube
Apr 22, 2009 | Dryers
Car Audio & Video Logo
117 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
