Question about Acer Power S290 PC Desktop
How to connect front panel to acer power s290 motherboard
What is the pin layout to connect power button, speaker, led.
  • Acer Master
  • 5,660 Answers
Http://www.ascendtech.us/acer-aspire-sa90-mbs7109002-motherboard_i_mbacembs7109002.aspx
The front of your computer is the Front Panel.
The area of pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Looking at the Front Panel header it is parallel to the outside edge on the bottom/right of the motherboard.
13 pin header.
6 across the Top row with 1 pin missing, 7 across the Bottom row.
Top row is numbered EVEN
Starting on LEFT side coming across to the Right, Top row;
Pins 2, 4, 6, 8, No Pin, 12, and 14.
Pins 2 and 4 have a Green area
Pins 6 and 8 have a Red area
No Pin 10.
Pins 12, and 14 have a Yellow area
Bottom row is numbered ODD.
Starting on LEFT side coming across to the Right, Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
No Pin 10.
Pins 12 and 14 have a Green area.
A) Pins 2 and 4 in the Green area (Top left) are for the Power On LED
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
B) Pins 6 and 8 in the Red area are for the Power On switch.
C) Pins 12 and 14 are N/C. Not Connected
D) Pins 1 and 3 in the Yellow area, are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
E) Pins 5 and 7 in the Purple area, are for a Reset switch, IF a Reset switch is used.
F) Pins 9, 11, and 13 are N/C.
(Pin 9 is 5 Volts DC. Used by the factory for testing)
Regards,
joecoolvette
(I thought the internal speaker was that round little 'buzzer', below the bottom white PCI slot, (PCI 2), and close to the edge of the motherboard )
Posted on Nov 02, 2012
leecom72
  • 4806 Answers
SOURCE: mismatch connection,plug vs pin after swithing motherboard
Hi there.
On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW.
Have a look at these pictures for an idea >>>>>>
Good luck and thanks for using FixYa!!
Posted on May 19, 2009
Benimur
  • 6966 Answers
SOURCE: Dead Acer desktop
Hi, "No fan, no hard drive, no noise" means the motherboard is not getting any power which is kinda out of sync because you are getting a power on light indicator. To confirm if your power supply is ok, check if the fan inside the power supply is working. you can look at the back of the casing, if it is turning then psu is ok. Try to reseat the power connector from the psu to the motherboard, some of the pins may not be in perfect contact but others are that's why the led lights up, but the mb is still dead. Please let me know how it works out for you. Regards.
Posted on Apr 11, 2007
  • 349 Answers
SOURCE: Pin settings for Acer Veriton 5600g motherboard
go to this site download vt5600.pdf file when downloaded sellect point 4 upgrading you computer,\system boards\mainboard layout\veriton 5600g mainboard layout.
http://www.acerpanam.com/synapse/data/7117/documents/vt5600.pdf
good luck
terry
Posted on Feb 20, 2008
tbirdfan1
  • 3051 Answers
SOURCE: acer motherboard diagram needed
hello there here is a weblink that will get you going in the right direction
i know you have the acer motherboard but the pins will generally be the same ok?
here is a pdf downloadable flile that will help you.
best regards michael
  1. [PDF] A7V133-VM3051k - Adobe PDF2.gif - View as htmlSupports Socket A-based AMD. Athlon™/Duron™ processors. North Bridge ... p.37 System Power LED Lead (3 pin) 22) RESET (PANEL) p.37 Reset Switch Lead (2 pin) ...dlsvr03.asus.com/pub/ASUS/mb/socka/km133a/a7v133-vm/e698_A7V133-VM.pdf
Posted on Sep 16, 2009
rasengan79
  • 138 Answers
SOURCE: connector diagram to acer ms 6772 motherboard needed
most motherboards have labels wherein you should connect the power button. facing the motherboard, try looking for it on the lower right.
How do i connect the front panel (Powerbutton etc.) with my acer m7721 motherboard?
If you have knowledge of computer hardware and also have a tool for open the computer cabinet, look at the 9 pin on motherboard one is shot out of ten pin, in the pin panel there is market some word to connect the panel Like Pw bt -Power button, Rst-Reset, Pwr-Led-Display Led, HDD-Hard disk Led, and SPK-Speaker Button. Inser all cable acordingly which is allready marking with coat sign
Sep 23, 2014 | Acer Aspire 7720 Notebook
N68s3+ panel connection
PANEL1: Front Panel Header for Biostar N68S3+ from
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dl
This 16-pin connector includes Power-on, Reset, HDD LED, Power LED, and speaker connection. It allows user to connect the PC case's front panel switch functions. Pin #1 has a black square on the motherboard and the pins are oriented from 1-8, left to right, bottom row and 9-16, left to right, top row. You will notice that there is no #11 pin.
pin #'s
1-2-3-4 Speaker (1+, 4-)
5-6 hard drive LED (5+, 6-)
7-8 reset switch (7-, 8+)
9-10-11 N/A (not used)
12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **
13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **
15-16 power button (15+, 16-)
Did this solve your problem?
Dec 22, 2012 | PC Chips Computers & Internet
How to connect panel 1 of n68s3+
pin #'s
Dec 22, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
I need help with hooking up the front panel wires from a acer veriton 460 on to a asus p5g41t-m lx plus mother board
I don't think it's gonna' fit.
Acer Veriton L460 computer Case Dimension specifications,
http://support.acer.com/acerpanam/desktop/0000/Acer/VeritonL460/VeritonL460sp2.shtml
Chassis: 2.5 inches Wide (63.55mm) x 10 inches Long (254mm) x 8 inches High (203.2mm).
Asus P5G41T-M LX motherboard is 9.6 inches LONG, (244mm), and 7.9 inches High (201mm).
http://www.asus.com/Motherboards/Intel_Socket_775/P5G41TM_LX/#specifications
However,...........
If you do not know what the Power On switch, Power On LED light, and Harddrive activity LED light wires are, then remove the Front Panel, and trace them back.
(Side Panel then Front)
Click on the Download tab.
(Overview / Specifications / Download / etc)
http://www.asus.com/Motherboards/Intel_Socket_775/P5G41TM_LX/#download
Click on any O/S. They will all get you to the Manual download.
Click on the + sign to the left of Manual (12)
Scroll the inside blue bar down until you come to -
Version E7096 -
P5G41T-M LX User's Manual (English)
Click on the blue - Global
A small window will come up on the right -
Opening E7096_P5G41T-M_LX.zip
[This is a Zip file. A Zip file is used to send large amounts of information, more easily. A Zip file is a Compressed file. It needs to be uncompressed after downloading, or can be stated as 'unzipped'.
If WinZip is no good on your computer, then just download the free 7-Zip ]
Make sure there is a Green dot in the small circle, to the left of Save File.
If there is no Green dot; left-click in the small empty circle to the left, of Save File.
Now go below in the small window, and click on OK.
A small window will come up on the left.
Allow the file to fully download in this window.
Then DOUBLE-click right on the file name.
On the left side in the next window, click on - Extract all files.
At the bottom of the next three small windows, click on -
Next, Next, and Finish.
In the last small window DOUBLE-click on the file name -
E7096_P5G41T-M LX, next to the red Adobe PDF icon.
Page 1-6 (16 of 62) shows the Motherboard Layout.
The area of contact pins on the motherboard, that the main wires from the Front panel connect to, is the Front Panel header.
Motherboard installed in computer case; Processor to Top, Ram Memory slots to the Right, white PCI slots to the Bottom;
the Front Panel header is below the bottom white PCI slot, and next to the bottom edge of the motherboard.
F_PANEL
4 pins across the Top row, (Then no pin)
5 pins across the Bottom row.
1.10.2 Internal Connector section - Page 1-26 (36 of 62)
8. System panel connector (10-1 pin PANEL)
Pins aren't numbered, I'm going to number them;
Pins across the Top row are numbered EVEN.
Pins across the Bottom row are numbered ODD.
Starting on the LEFT side going towards the Right; Top row,
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the Left side going towards the Right; Bottom row,
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. 5 Volt power reserved for the factory.
D) Pins 2 and 4 are for the Power On LED. (Light)
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10. Just a flat spot.
The small 4-pin header immediately to the LEFT, is for an internal speaker. Used to hear BIOS Beep Codes. The computer's way of telling you something is wrong, and an area to look into for it.
The Front Panel USB header is listed, and Firewire ports. (1394a)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 14, 2012 | Acer Power S290 PC Desktop
Power front panel conectors on acer 915m08
This Foxconn 915M08-G-8KS motherboard made for Acer Veriton desktop computers?
http://www.sella.co.nz/general/computers/components/motherboards/other-motherboards/b1jnj6/
Do not know what the Front Panel header pinout is.
(Front plastic part of computer tower is the Front Panel.
Area of contact pins on the motherboard, that the wires (Cables) from the Front Panel connect to, is the Front Panel header )
CAN see by clicking on - View full size image - that the Front Panel header is to the Top Left corner of the motherboard, by the CMOS battery.
(View of mobo is upside down, in relation to how it actually sits in the computer tower case)
Shows me it is just the normal two rows of contact pins used in a LOT of desktop computer mobo's. (MOtherBOard)
If it were I, I would use one of the LED lights connected to two wires, and touch across each two sets of pins.
Looking at the motherboard as it sits in the computer case, there is a row of pins on Top, and a row of pins on Bottom.
In your mind start at the LEFT side of the pins at the TOP.
Number them from Left to Right.
Example, Pins 1, 3, 5, 7, and 9.
Now number the pins on the Bottom, from Left to Right,
Pins 2, 4, 6, 8, and 10.
Computer plugged into power, touch the two wires of the LED light, to Pins 1 and 2.
Computer doesn't start? (Power Supply turns on)
Go to the next set of pins.
I am willing to bet Pins 5 and 6 turn the Power Supply on.
No? Keep experimenting.
What will happen if you touch the WRONG pins?
N-O-T-H-I-N-G
You will NOT hurt the motherboard.
When you get to the correct pins, the Power Supply will turn on.
These pins are for the Power On switch.
Now go back through the pins with the Power Supply on, but DO NOT touch the pins that turned the Power Supply on.
When the LED light STAYS on, you have the pins for the Power On LED light.
If the LED light BLINKS, you have the HarDDrive activity LED light.
If Windows starts to load, and you touch the Restart switch pins, the computer will restart over again, and Windows will load again.
(IF this computer has a Restart switch. I do NOT use one, even for the older computers. Just press CTRL, ALT, and DELete keys at the SAME TIME, to restart the computer, or use the Task Manager option)
One pin left all by itself? That is for 5 Volts, and only used by the factory. Leave it unconnected.
There may also be a blank spot on the Front Panel header, where it looks like a pin is missing. This is the KEY pin, and is not used.
It is just to orient where the other pins are.
Worried about getting shocked?
There may be a small spark, as you connect the wires, I will gramnt you that.
But the voltage is 5 VOLTS DC.
In comparison two D cell flashlight batteries produce 3 VOLTS DC.
The harmful AC voltage is contained in the metal enclosure, of the Power Supply. Can't get you unless you pour water on it close up, or stick a metal rod through one of the ventilation holes, in the Power Supply enclosure.
Regards,
joecoolvette
By the by. You could be a lot of people's hero, if you came back, and posted the pins for what they do. Post in a Comment.
Jun 08, 2012 | Acer MB.V1509.002 VERITON 7700G VT7700G...
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
Hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Input, comments are welcomed.
Mike
Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
Acer Power S290  PC Desktop Logo
1,759 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
