Question about Apple iPhone 4S
1 key not working on iphone 4s keypad
When i try to press the 1 key when prompted while on a call it won't let me
I have a i phone 3gs.the phone key pad R ,D or slider do not work .either of that every things work properly.
please tell me how do i solve this problem.
Posted on Dec 02, 2012
  • 580 Answers
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Posted on Nov 02, 2012
3 Suggested Answers
SOURCE: opening the sim slot
there should be a little hole by the slot you can use a pin\ needle push in and it should just slide out
Posted on Jul 16, 2012
  • 10 Answers
SOURCE: I recently bought the new iPhone 5 and it already has much more scratches than I had on my iPhone 4S. I'd like to return my phone. Is this possible?
The good news about Apple's return policy is that if you are unsatisfied with your phone, you can return it within 30 days and ask for a new iPhone 5. You can also ask for a full refund, which is probably the best option for you right now because there's a high chance that the new iPhone they'll give you will scratch just as easily.
Posted on Sep 24, 2012
Dock mode
Corrupted software
It isn't often that Apple gives specific directions about how to fix your problem! Restoring the iPhone 4S will erase everything on it, so make sure everything on the iPhone 4S is stored elsewhere prior to restoring. To restore, connect your iPhone 4S to a computer with iTunes installed. Click "Restore" on the iPhone 4S summary page (click on your iPhone icon on the left menu to find this page). Follow the directions to restore. If your iPhone 4S displays the text "Please wait. Very Low Battery," leave it plugged in. This charges the iPhone 4S enough to be able to restore. If the iPhone 4S hangs on this screen for long periods of time, you may need a new battery.
Force restore mode
If your iPhone 4S is hanging with an Apple logo, or exhibiting some other software problem that prevents iTunes from recognizing it, you can force it into recovery/restore mode and then use iTunes to restore the software.
If the device is powered off, plug one end of your USB cable into the iPhone 4S and leave the other end disconnected. Press down on the Home button, and keep holding it down while you plug the USB cable into your computer. After 5-10 seconds, you should see a "Please Connect to iTunes" image on the iPhone 4S, and iTunes should prompt you to restore the software; follow the prompts and the instructions given above.
If the device is powered on, hold down both the power and home buttons until the device reboots and displays the "Connect to iTunes" image (generally, 5-15 seconds).
God bless you
May 24, 2013 | HTC Cell Phones
Gigaware Hd fm tuner
God bless you
May 13, 2013 | Cell Phones
IPhone 4S won't turn on
Try holding down your Home Button and your Lock Button at the same time for about 10 seconds or until you see the apple logo. This will restart your phone and should resolve your problem!
May 01, 2013 | Apple iPhone Cell Phones
Pair iPhone 4s with 2006 BMW x5
Key-in, Ignition On (but don't need to start the engine)Press the R/T button on the steering wheel. "Activate Phone" should display on the radio. On the iPhone search the BT device. Select your car and enter the passkey when prompt on the iphone. Make sure there is no other BT phone near-by or the old one that has paired with the car previously. There is also the maximum number of devices you can have in the BMW BT sharing. If you reach the max, you may have to clear the car BT pairing memory by removing the power to the BT unit (by removing a fuse in the rear fuse box). The info is in the manual and inside the fuse box (which tell you which fuse is for the BT.)
Feb 06, 2013 | BMW X Series & X5 1997 >2006
I was updating my iphone 4s and decided to turn it off in the process of updating as the internet connection was too slow. When i tried to turn it back on, it just wouldn't load. What should i do?
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 31, 2012 | Apple iPhone 4S
Iphone 4s stopped working on B & O stereo - It USED to work when plugged in to the iPhone adapter, and then one day stopped. Wife's iphone still works fine!
Have you tried to see if it is working with another stereo or sound system when connected? Try this, if issue persists, I would try a full back up and restore via iTunes on your computer. Please make sure you do the back up before restoring to prevent any data loss. After restoring the iPhone, it'll give you 2 options:
1. Setup as new device OR
2. Restore from a backup
At this point, you would want to set it up as a new device to see if we can determine a hardware or software issue with the iPhone. If the issue persists, then it's a hardware issue and if the iPhone itself is still within its hardware warranty you can take it into an Apple Retail Store, or call AppleCare Technical Support and they can get it replaced for you.
You would have to make an appointment to take it into an Apple Retail Store before taking it in though, but this is definitely the quickest way to get your replacement as you'll get it on the spot.
If you choose to get the replacement through the Technical Support team, they can make that appointment for you, otherwise they have a few mail-in options available to you as well.
Hope this helps!
Oct 30, 2012 | Apple iPhone 4S
My iphone 4s cannot charge or start
5.Wait 10 seconds.
Step
Thanks
Jul 28, 2012 | Computers & Internet
The solutions to my microwave prolem (keypad reading commands but keys won't work)didn't help. Do you have a manual I could download?
Try:
1) Unplugging power and plugging back in
or
2) Press Cancel twice while door open (works on my Whirlpool).
Dec 23, 2011 | Microwave Ovens
I cannot find my samsung t404g's voice recorder and I would really like to use it but I also cannot find my manual: HELP
Hello.
You can view and download the manual by clicking here:
T404g
1. In Idle mode, press Menu ? Games & Apps ? Voice Recorder.
2. Press the Record soft key to begin recording.
3. Record a memo by speaking into the phone's microphone.
The display simultaneously shows the elapsed time and the total
time allowed.
4. Press the Stop soft key when you are finished recording.
Please rate my answer.
Aug 05, 2011 | Cell Phones
Buttons won't work. Just returned from a 6 day golf trip where the SkyCaddie SG4 worked perfectly for the first 5 days. I recharged it in a wll outlet overnight, then on the next day the buttons...
Power On/Off and Key Lock/Unlock - Press the Power button located at the top right
of the Sky Caddie to power on/off or to lock/unlock the keypad. Upon pressing
the Power button you are prompted to choose either "Off" (Left Soft Key) to power
off the device or "Lock" (Right Soft Key) to lock the keypad. To unlock the keypad,
select 'Unlock" by pressing the Right Soft Key, then choose "Yes".
Jul 02, 2011 | SkyCaddie SG 4 Handheld GPS Receiver
Apple iPhone 4S Logo
287 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
