Question about HP DeskJet 3650 InkJet Printer
Printer will not print
I the same problem, deskjet 3650 will not print. Light blinks and message is paper jam, however, there no paper jam and I have openned the back and checked for paper jam but found none.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
I am unable to print because of a "paper jam". I have removed the paper from the printer, unhooked the printer from the computer, etc. and continue to get this message. Can you help?
A "paper jam" means that there is some paper or a piece of paper somewhere inside the printer, in the paper rollers. Turn the printer OFF. Open the printer and carefully look for a piece of paper or a paper page half-folded inside. SLOWLY pull the paper out. Replace the cover and turn on again.
Apr 01, 2010 | HP DeskJet 3650 InkJet Printer
The print keeps giving me a message saying it is out of paper and won't print, the printer has plenty of paper
There is a "micro-switch" that should be triggered by the weight of paper, i.e., no paper in the tray triggers the switch, and the printer reports "tray empty".
So, either the paper is not correctly inserted, so that it does not touch the micro-switch, or the micro-switch is "jammed" into the "no paper" position.
Jan 05, 2010 | HP DeskJet 3650 InkJet Printer
Middle light blinking message says paper
Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
Sep 22, 2009 | HP DeskJet 550c InkJet Printer
Printer mechnical error
Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
  • Change the printers print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
There is a paper jam Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the Power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Sep 10, 2009 | HP DeskJet 3650 InkJet Printer
One of my members has an HP Deskjet 3650 and it
See this article to resolve the blinking lights. Then see this article and possibly this one to clear the print queue. You may have to cancel an active print job to remove it, or reboot the computer. Here is the home support page for that model printer, should anyone have further questions or need more information.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 25, 2009 | HP DeskJet 3650 InkJet Printer
My printer always jams paper?
go to manufactures website and reset your printer
Mar 11, 2008 | HP DeskJet 5550 InkJet Printer
Paper jam?
There is most likely some paper jammed inside the printer. You just have to carefully look everywhere you can see to see if there might be a little bit of paper stuck somewhere.
Often blowing gently (and dryly) into the printer will dislodge whatever is stuck.
Jan 13, 2008 | HP DeskJet 3650 InkJet Printer
Printer jams when using Kodak Picture Paper
Check the HP support pages, but as HP inkjets turn the paper over internally it means their weight limit is likely lower than others. Also check you have loaded paper face down so it is glossy side UP as it turns over for printing. Their site quotes a max weight of 200GSM for thick stock http://h10025.www1.hp.com/ewfrf/wc/docum... Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum...
May 05, 2007 | HP DeskJet 3650 InkJet Printer
HP DeskJet 3650 InkJet Printer Logo
320 people viewed this question
Ben Johnson
