Stihl chainsaw stalls after warm up
Can sometimes keep it going by rapidly goosing throttle
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
Sounds like fuel line cloged or the someone played around
fuel mixture screw normaly if the screw has been turned
3 half turns out is a good place to start out from
Posted on Nov 01, 2012
My Stihl chainsaw will idle but when I go use it to cut wood it shuts off
Carburetor problem. It is running on the idle jet, but when you press the throttle and the main jet is supposed to take over, it stalls because you have too much air and not enough gasoline. Strip the bottom of the carb and remove the main jet. You will find something blocking it.
Mar 11, 2018 | Stihl Garden
Cold start stall, and stalling after warm.
is the check engine light on? If so, have an auto parts store retrieve the codes.
Oct 01, 2017 | Ford Taurus Cars & Trucks
Stalls and shudders warm and cold
Mass air flow sensor. Can be cleaned before you buy a new one
Jan 24, 2014 | Ford Taurus Cars & Trucks
Ts410 stihl saw stopped working
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
I also have a stihl chainsaw model home light 240. I just had it sharpened and a new spark plug put in by the repair guy. I used it for 30 mins and it kept stopping until I couldn't start it again
(cold starting)
Place saw on floor (flat clear surface).
Make sure chain break is on.
Place right foot in the flat of the rear handle.
Place left hand on top handle.
Pull starter handle again untilsawfires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
Warm starting is performed by holding the rear handle between the thighs rather than on the floor.
Nov 14, 2012 | Stihl Garden
Stihl BG55 blower idles fine but when you give it throttle it starts to rev up but then dies?
first you need to let it warm up. one minute. it is 2 stroke. most common issue is too much oil in fuel. mix ratio exact. make sure no water in fuel
Nov 08, 2012 | Stihl Genuine 4229 120 0606 C1q-S68d Carb
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Washing Machines Logo
Top Washing Machines Experts
