Question about Haier HNSE05 4.6 Cu. Ft. Refrigerator Freezer - White
Relay keeps kicking in and out - Haier HNSE05 4.6 Cu. Ft. Refrigerator Freezer - White
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
Take everything out and defrost it for a day with doors open if you can
cleaning up the coolong fins on the bottem of it 2
Posted on Nov 01, 2012
Model# 253.61821014 compressor keeps kicking off
Feel the top of the compressor is it hot? Usually when a compressor will start and stop this is called short cycling and it is caused by a defective start relay, overload and capacitor. Sometimes it it cause by a defective fan which when this happens all parts including a new fan must be replaced
241941004 Start Relay
218909913 Run Capacitor and a
242018301 Condenser Fan Motor
APPLIANCE911
It is not stuck in defrost mode with those symptoms
Apr 30, 2016 | Kenmore Refrigerators
Ac compressed not kicking on put a new relay and still not kicking on
2 things if its not above 45 degrees it wont come on , and did u check Freon level with gauge keep in mind while system is off it show a reading like its over filled so shoot some Freon in see if kicks on while engine is running
Feb 22, 2015 | 2000 Oldsmobile Intrigue
2008 v star 1100 silverado does it have a stator or any relay switches that could keep this bike from starting
Kick stand switch may be the problem, if the kick stand is down and clutch out it wont start, sometime this switch will play up and it can be bypassed.
Apr 25, 2014 | Yamaha V Star 1100 Custom Motorcycles
2002 Chevy Trailblazer 4X4 Kicks Out
solenoid may be getting intermitent power ..either broken /bad wire or connector or relay may be at fault.. parts store can give locations..
Dec 24, 2013 | Chevrolet Cars & Trucks
Refrigerator model bx21vl does not cool. I can hear the compressor kick in but it kicks out in 5-10 seconds. Then after about 102 to one minute it kicks in and out again,
Compressor is tripping on overload. You may just need the overload and relay replaced due to a bad compressor relay. The relay is what switches the compressor from it's start winding to it's run winding. If you pull the relay off, shake it to see if you hear lots of rattling inside, that's a sure sign of a bad relay. I would replace both of them.
Here is the overload relay to order.
Here is the start relay to order.
Nov 27, 2012 | Refrigerators
My refrigerator keep tring to kick on but acts like it can't. I unplug it and wait a few seconds then plug it back in and it works fine.
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 09, 2011 | Kenmore Side by Side Refrigerator
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
My copressor won't start. relay works fine in
HAVE YOU TRY A 3-N-1 COMPRESSOR BOOSTER|? YOUR LOCAL APPLIANCE PARTS STORE SHOULD HAVE THEM. TELL THEM THE SIZE OF YOUR FRIDGE AND COMPRESSOR AND THEY SHOULD BE ABLE GIVE YOU THE RIGHT ONE. FOLLOW THE INSTRUCTIONS ON THE 3-N-1 AND CONNECT TO THE COMPRESSORS. BUT CONNECT THE TWO BLACK WIRES TO A EXTERNAL POWER(GET AN EXTENSION CORD AND CUT IT, WIRE NUT THE TWO WIRES TOGETHER). PLUG IT IN, IF THE COMPRESSOR KICKS OFF, YOU HAVE A BAD COMPRESSOR. IF IT RUNS WITHOUT KICKING OFF, THAT MEANS YOU ARE NOT GETTING POWER TO THE OVERLOAD RELAY TO TURN KICK ON COMPRESSOR. CHECK YOUR TEMP CONTROL INSIDE FRIDGE, AND THE DEFROST TIMER(MIGHT BE STUCK IN DEFROST)
Jan 24, 2010 | Amana Freezers
91 Camaro
In reply: if its not the maf there are 2 relays in the relay box i belive its underhood, 1 primes the fuelline to 32psi the second kicks in after it starts, and keeps it running and varies the psi. if the primer relay isnt kicking in then it wont start due to no fuel
THX
Don :)
Jul 26, 2008 | 1991 Chevrolet Camaro
Roper REX4634KQ
That should be just a push to start switch. The start switch is inside the motor. When the motor turns fast enough it trips an internal switch to keep the motor running. It sounds like you have a motor on the way out.
Apr 24, 2008 | Roper REX4634KQ Electric Dryer
Haier HNSE05 4.6 Cu. Ft. Refrigerator Freezer - White Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
