Question about Dell Latitude D600 Notebook
Latitude D600 beeps twice
Most times when I boot up it beeps twice and it will then give me a screen saying press F1 to continue. It then it boots, or I just get a blank black screen and I have to hold ctrl+alt+del for it to boot up.
  • gmlcinc Jan 04, 2009
    I also have trouble with the network adapter. Sometimes when windows boots up it will tell me it has found new hardware and show that the Intel Pro Wireless LAN 2100 3A Mini PCI Adapter needs installed. Usually the first time I start the pc for the day it will work fine, but after it gets warmed up if I restart it will come up saying that and I can't use the internet. I have tried reseating the memory, hard drive, and getting new drivers, but no change.
  • gmlcinc Jan 05, 2009
    Thanks for the input. I ran the tests as far as I could until it asked for the "dell drivers and whatever" disk, which I don't have. Also disassembled and cleaned it, this seemed to help.
  • 56 Answers
That may be because of a bad connection with the harddrive thats easy to fix you just take the harddrive out and blow the connecting surface clean then it should behave normaly agian:)
Posted on Jan 04, 2009
  • Christoffer Petterson Jan 04, 2009
    that may be because of there is maybe lot's of dust in the in it,i think it may be smart to take covers over the keyboard of or some thing i`m not sure on dells laptops but you got to get the mother board revealed and clean out all the dust between the contacts, but bye, it like 7 in the morning here in Norway so good night my friend=)
    Novelist:
  • 176 Answers
Sounds like you have a video card problem.
To run the Dell diagnostics perform the following steps:
  1. Shutdown the computer.
  2. Press and hold the <Fn> key (next to the <Ctrl> key), then press and release the power button.
    Release the <Fn> key when:
    • The keyboard lock symbol lights begin to flash AND/OR
    • In the upper left corner of the screen shows Diagnostic boot selected
  3. The diagnostics testing automatically begins.
    It may take a few minutes before any alert tones are heard.
  4. Watch the screen for images such as the Dell logo, progress bars,or lines of text and/or listen for beep tones that sound similar toMorse code.
  5. If the screen does show an image, write down the codes that appearon the screen. If the screen does not show an image, write down thebeep tones that you are hearing.
    • Before going further, please click the link to listen to an example of a beep code. Sample Beep Code
    • The beep codes will begin with a quick series of high pitched beep tones, then a pause, then 3 sets of beep codes.
      Write down the 3 sets of beep codes that you hear.
    • If an error code is recieved, scroll back to the top to "Choose an option"and choose "A beep code is heard or an error code is seen. The beep code is not 3-3-3 or 3-3-4."
    • If there is no error code, continue with step 7.
  6. After approximately 2 minutes the system produces a single alert tone and should display colored bars with the prompt Were color bars displayed? (y/n).
    The alert tone is repeated 6 times, once every five seconds for 30 seconds, then the second test automatically begins.
    Press the <N> key on the keyboard to skip the timeout and immediately start the second test.
  • mercrls674 Jan 22, 2011
    i have a d800 with the same double beep problem, i got in the bios and discovered a section that says, enable this warning for an underpowered ac adapter. i disabled it, the beep went away and i replaced my ac adapter. fixed!!!!!!!
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
HP Pavilion ze2308wm laptop won't boot up
It could be the memory modules (RAM). Get the information from those RAM sticks (manufacturer) and replace them with new ones to see if that solves the issue, if not then maybe the hard drive, and if it's neither of those, I hate to say it, but it sounds like a bad motherboard :(
Mar 14, 2010 | HP Pavilion ze2000 Notebook
HP Pavilion ze2308wm won't boot up
Have you tried an external keyboard, either PS2 or USB depending on what ports are available?
Ihave changed my dell d600 power suppl and it works ,but the problem is how to configure in set up while it says press f1-x to set up ,but once you press it says that it is docked,you need to undock, so...
am I to understand that when you boot it is sending you in Bios to set time and date ...by pressing F1 ...the thing you can try is to press f 10 while in bios even if it says its docked...and than confirm ..this will make it believe that it is set ..and will reboot and enter windows...after that you will set the time and tah date in windows and when connect to the insternet you can sync it with windows server..
Nov 15, 2009 | Dell Latitude D600 Notebook
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN
Place a Windows XP disk in to a drive and just after pressing power button keep pressing F10 or F12 to get to the boot menu then choose cd/dvd drive and follow procedures from the screen to repair or install system. ANother way is by pressing F1 or F2 or Del just after pressing power button to get to BIOS the go to Boot options and set firs cd/dvd drive then press F10 and enter.
Jul 20, 2009 | Dell Latitude D600 Notebook
Dell latitude 120l CD boot problem
Hmm,I've seen this before & unfortunately I think the cd drive went poop.
Jun 26, 2009 | Dell Latitude 120L Notebook
Booting up my d600 laptop
This problem can be caused by two reasons:
1) The CMOS battery is damaged or displaced ( apart from the external battery, there is a small battery which is connected to the motherboard)
2) One of the RAM modules is displaced.
First make sure that the laptop displays the amount of RAM correctly. You do this by opening Control Panel -> System and noticing the amount of RAM.
If it is okay then press F2 when your computer starts of to enter bios. Make sure that the date and time displayed are okay, if not change them accordingly. Then Save the CMOS and exit.
If nothing changes then let me know
Nov 24, 2008 | Dell Latitude D600 Notebook
Dell latitude C610
From the Bios, load all the default settings and then check the bios SATA port settings. If it is set to AHCI, change it to IDE to boot from Hard Drive. This should solve the problem
Oct 01, 2008 | Dell Latitude D600 Notebook
Dell d600 video problem
Forget the non-sense.
  1. Remove the battery
  2. Open the RTC Battery compartment
  3. unplug the RTC battery
  4. Press the power button to dissipate stray voltage
  5. Re-install RTC battery and cover
  6. re-install main battery
  7. Re-boot and enter set-up to change date time etc.
Apr 17, 2008 | Dell Latitude D600 Notebook
Dell latitude d600 not booting/blank screen
well what you have on your computer is the computer does not find your hard drive where you have the operative system thats why is asking you to boot from cd because the computer wants to instal a operative system may be your hard drive is damage ok lets do a test turn on your computer by presing the power botton and then press the key to boot on bios page can be (delete ,F1, F10 ) any of those every time you try to do the boot up if does not go to bios you have repit the same operation so when you get bios system display on you computer look for the hard drive and the boot order if there is no hard drive so your hard drive is damege and you have to reolace for a good one and instal the operative system
Dec 29, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
2,607 people viewed this question
Alun Cox
