Question about Toshiba 32A33 32" TV
My 32"toshiba keeps changing from tv ,to video 1, to video 2
Its been almost over 7 hours since this started,,,changed the batterys on remote and its still doing the same thing
  • 1 more comment
  • juancarlos73 Jan 04, 2009
    no. the remote does not help. if i manually go to the tv and change the channel it will change to tv but briefly
  • jason May 11, 2010
    it will need testing , can you do it or do you need a repair center?
    does it stop when the battery's are taken out of the remote?
  • 934 Answers
It's one or more tactile switches are leaking...
Bill
Posted on Jan 04, 2009
My toshiba tv won't turn on
1. Verify the circuit it's plugged into is powered.
2. Change the batteries in your remote control. It requires (2) AAA's.
3. Unplug the TV for several minutes, then try again.
Apr 15, 2014 | Toshiba 32C100U 32 in. TV
I have a toshiba 32a32 32" tv, the problem im having is all of a sudden the channels started switching by itself and the volume keeps going up to 100. when i set a channel it stays there for a minute then...
The problem is either from the remote or the television, there has been so much heat on the control panel of the television, so it has melted some lead off a part of the control panel and bridging it to another part, so it is increasing both the volume and changing the channel in an upward direction.
The solution is to change the control panel of the television or correct it by using a soldering iron to melt off the lead from where leads meet.
If you remove the battery from the remote and it still does the same, then it is confirmed that it is the televisions control panel. But if after removing the battery it stops scrolling up, then the problem is from the remote and the solution is for you to replace the remote with a new one.
Take care and good luck
Oct 23, 2010 | Toshiba 32A32 32" TV
I do not have the original remote and have no Idea how to change to video 1 or video 2 channels
Do it with the buttons on your TV scroll down through your channels after the channels run out keep pressing channel Video 1 should appear if u you need Video 2 press the channel button again.
Aug 14, 2010 | Toshiba 32A35 32" TV
The remote control stopped working on my toshiba flat screen i changed the batteries and only the volume works with the remote still can't turn on/off or change channels
Make sure the mode switch is set correctly for the device (TV, Cable, Video recorder, etc) that you are trying to control.
Apr 28, 2010 | Toshiba CZ36V61 TV
All buttons control tv/video, remote stopped working
Unplugged it for an hour.... buttons changed.....Unplugged it for four hours and everything worked......Left it plugged in overnight and back to original problem....
Oct 02, 2009 | Toshiba 32A33 32" TV
Tv will not stay on just tv
Look at the IR emmiter "eye" on your remote thru your Cell phone camera. You can tell if the remote is constantly emitting a signal.
Jan 27, 2009 | Toshiba 32AF43 32" TV
Tv problems
Have you tried taking the batteries out of the remote? Sometimes the buttons can stick.
Sep 12, 2008 | Televison & Video
Switching from video1, video2, tv
First check for a button which is stuck down (activated) on the TV & remote. I have seen a stuck button on a remote box continually sending a command to the TV. Also, try unplugging the set so the microprocessor will reset. Other contributors might have seen this exact problem, and provide an exact solution.
Sep 13, 2007 | Toshiba 32A35 32" TV
Tv problems
There are a number of things that can cause this.
If you have a compact flourescent lamp in the room, this can cause some models of TV sets to go nuts, or not respond to the remote. These compact flourescent lamps use a frequency band that is close to the data carrier freqency of the remote.
Excellent article about compact flourescent lamps interfering with appliance IR remotes:
http://www.neptunlight.com/files/IR-and-CFLs.pdf
The other thing that can be wrong is there may be a fault in the keypad assembly on the TV set, or a fault condition with the uPC.
Jerry G.
Jul 02, 2007 | Toshiba 32A43 32" TV
Toshiba 32A33 32" TV Logo
117 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
