Question about Car Audio & Video
Thermal switch or possibly a stressed amplifier module?
My sub is also sucking in when reconnected to amp. It started smoking a while back. and then it worked fine again. When the sound was turned up too loud it would shut off the sub. I got new subs and the amp's led light is on but the subs wont work. How could i fix a thermal switch or stressed amplifier module inside the amp? That was ur solution earlier, and I want to know how much it will cost to fix this problem. thanks
  • 44 Answers
I would make shure the Plus and negitive are right. Also if it was smoking you probly blew the power supply out of amp. From to many ohms loads. Hope this helps you out
Posted on Jan 13, 2009
I installed a MTX Thunder 3401 with a PA sub. after turning the car oh every things works great. After about 2 mins of play, the thermal light begins flashing red and it will shut off the amp. After the...
You are def overheating, If the ohms rating of the subwoofer is too low it will cause this same thermal over heat. If you have 2ohms in sub and a 4 ohms stable amp, you will overheat. Check the ohms rating of the sub to make sure this is not the problem
Jan 31, 2011 | MTX Thunder 3401 Car Audio Amplifier
Tip
Jl 1000/1 amp problem
i tried switching my lanzar amp to my jl 1000/1 amp myself last night and as i plugged in the ground.. some smoke came up from where the ground and 12v cords meet the sub.. it wasnt much smoke, just a little. so i plugged my lanzar back in and today at lunch went to get it installed and it seemed to be hittin when i left the car audio place.. but its not hitting like it should. the lanzar hits harder. what went wrong? what does that smoke mean? how do i fix it? thanks. i am worried sick. those amps arent cheap.
on Jul 26, 2008 | Jl Audio 1000/1 Car Audio Amplifier
My power pyramid sub is smoking i think its the jl 1000/1
If the sub is new, they need to be broken in.
All sub woofers need a break in period of about 5 to 6 hours at medium volume.
The reason is because the glue needs to be cured. This is done by the heat from working.
If you are giving it too much volume too soon, you are burning the glue.
Back off the subs and only play them at medium volume for about a week.
Nov 22, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Power pyramid subs smoking i think the jl 1000/1 is tuned wrong..
Subs and amp dont work
His amp probably blew your fuse. Check that you have 12V at the power connections. If you don't, then find the fuse in your positive wiring to the amp. If you do have 12V to the amp, check your remote power up also has 12V between that and the negative line when your head unit is on. If it doesn't, then it's probably an internal fuse in your remote switch on line inside your head unit caused by a fault in your friends amp. This is normally accessible at the back of the head unit.
Oct 06, 2009 | Legacy Audio LA370 Car Audio Amplifier
Mtx jh600 feed back in subs light on amp the bolt is blinking
check that the ground wire is bolted tightly to the chassis of the vehicle.
Aug 08, 2009 | MTX JackHammer JH600 Car Audio Amplifier
Amp voltage
Well this is interesting, Let me start by saying if you have a 2 ohm load and your system is set for 4 ohms you are going to overdrive your load and burn up your amplifier, maybe not right away, but sooner or later it will fail due to electrical and thermal stress bought on by power dissipation issues.
Yes you can get 2000 watts out of your amps, but the correct way is to bridge your amplifiers if you can, and terminate them into the proper load.
Thank you,
Shuttle83
Apr 21, 2008 | Jl Audio 1000/1 Car Audio Amplifier
LED Light is on, but no sound from sub at all.. Have double backed on all wires but still nothing! HELP!!
If you've overheated it a number of times, it's possible that you've damaged the amp and it's trying to protect itself even though it's too late. Try disconnecting the sub from the amp. If there's no change, then there's a problem within the amp. It could be a thermal switch or possibly a stressed amplifier module.
Hope this helps. Good Luck!!
Mar 21, 2008 | Car Audio & Video
Amplifier On - No Sub Sound
Are you certain you put the wires back on the amp the exact way they came off. I am not familiar with this amp but most amps if you look at the terminals where the speakers hook up there will be a plus and a minus. And generally there are four terminals. hence stereo plus and minus left and right. Some even have eight for, four channels. Since the amp is on, not getting hot and you tried two different audio inputs I would suspect speaker wiring or maybe the stuff you put in your trunk bumped a switch on the amplifier. I know this is not the exact answer you are probaly looking for but it is at least a place to start
Jan 11, 2007 | Sony XM-DS1300P5 Car Audio Amplifier
Car Audio & Video Logo
169 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
