Question about Epson Office Equipment & Supplies
What does user intervention required mean? - Epson Office Equipment & Supplies
IrishDruid
  • 2712 Answers
SOURCE: My printer doesn't work
http://h20000.www2.hp.com/bizsupport/Tec...
The link above may help you. It applies to HP printers,but
might solve your problem with your Canon printer.
Posted on Jun 16, 2008
yboyandrei
  • 828 Answers
SOURCE: User intervention required
at your printer options or your canon pixma, check your ports setting in his properties...
Posted on Jun 18, 2009
SOURCE: Epson printer TM U220 (User Intervention Required)
I spent a good week trying to find an answer to this problem... and finally I HAVE THE SOLUTION!!
it's to do with the Port settings.
go to BIOS and change the port settings on your computer.
there are a number of different options that can be selected, just try them one by one, the one that worked for me was "Normal" try that one first, but it may be differnet depending on the printer.
if your LPT port is using it's own driver (not using BIOS to run) you cant change the settings using the BIOS. see if you can change it useing the settings for the dirver. if not try updating the driver. if that doesn't work, and nothing else works, reinstall Windows, that should fix the problem as a last resort.
good luck.
Posted on Jul 23, 2009
anantakumarj
  • 330 Answers
SOURCE: user intervention required
check the connection and restart the printer .........
if not working means reinstall the printer driver ..........
Posted on Oct 30, 2009
MUKHTAR
  • 2017 Answers
SOURCE: mp250 canon user intervention required problem
Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Mar 17, 2010
How can I fix the issue when my printer says "User intervention required?"
I'd guess you have a paper jam, maybe even tiny piece.
Check error message on printer's panel. try turn off for 10min.
turn back on. Users manual on software install CD may help understand message.
Mar 08, 2015 | HP Office Equipment & Supplies
I cant print it keep sayin user intervention required what does that mean
check to make sure there is no paper jam
the print job which you have sent to printer, is it the correct paper size / PAGE LAYOUT?... i.e. A4?
is this a local printer or a networked?
Lastly... if all fails Restart the printer
Mar 08, 2011 | Computers & Internet
Says: fault error:116-325 whats this mean pls?
fault error:116 325 A failure of the Controller Fan has been detected. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
Hope this helps. Thanks
Mar 06, 2011 | Office Equipment & Supplies
Oct 30, 2009 | Canon PIXMA iP1300 Printer
This message is displayed on the printer's status
Hi
Thanks for using FixYa. It means that more than one printer is being used through LAN or WAN and printer has not been shared with both the computers. You'll need to share the printers being used and the issue will be resolved.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 09, 2009 | Sharp Office Equipment & Supplies
install the driver n check by replacing the u.s.b cable n switching it on different ports
Aug 04, 2009 | Sharp AR-5320 Black and White Copier
Jun 18, 2009 | Office Equipment & Supplies
User Intervention Required Message Epson TMU375 receipt printer
Got to start/settings/printers and faxes .saelect epson 220 printer go to properties and select ports.Change ESDLPT1 port to lpt1 port and uncheck enable bi directional option .Apply and o.k.printer will work fine
Dec 30, 2008 | Epson TM-U220 Matrix Printer
User Intervention required on Epson TM-U220PD
I had the same problem with the user intervention required status on the printer. I tries reinstalling it several times through the Epson Driver Utility but got the same message each time. I got it to work after making two change but do not know which one (if either) got it to work. First i uninstalled the printer driver through Add/Remove Programs and not through the Driver Utility. I also set Dip switch 1-1 to on which enables auto line feed with parallel interface, with other interfaces this switch changes other things.
Dec 02, 2008 | Epson TM-U220PD Matrix Printer
Jun 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
