Question about Lobster 700TV Cellular Phone
Disassemble My lobster will not charge, how can I disassemble it to fix the charging point please?
  • 580 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Nov 02, 2012
  • Graham Nov 02, 2012
    Hello there. Thank you, I know that the issue is the charging socket as I already tried another USB cable and it is very loose. This was why I was asking if anyone had instructions to be able to open up the Lobster to be able to see if I can fix the socket in place and reconnect it up.
CHARGING POINT KAHA HAI
lava model no-ARC1 there is only one charging point so you have to fix your charging point and charge you phone again
May 17, 2017 | Cell Phones
Satellite M205 S4804 Problem
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Jan 27, 2013 | Toshiba Satellite Computers & Internet
Sony ericsson mw600 blutooth swith not working and charged
Hello People!
I Fixed my MW600... :D
WHAT HAPPEND?
- I was listening music and it fell from my arm for the chair, about 30cm height and after that, it not power again...
HOW I FIXED IT?
- I had to disassembled it. I had to remove its battery, spinning a little the battery and put its back. I pushed the power button and it worked... :D
Follow this video, step by step, for disassembly the mw600.
https://www.youtube.com/watch?v=UyEC33sUS_4
Please, be careful!!!
Good Look!
Mar 03, 2012 | Sony Ericsson MW600 Stereo Bluetooth...
My NV5378u stopped charging, thought it was the charger wasn't,bought new battery, again does not charge, why
1)How to disassemble a Gateway NV52, NV53
http://youtu.be/ab0tt7LflHw
2)Gateway NV Laptop Repair Fix Disassembly Tutorial
http://youtu.be/f65ohS_EfdI
Dec 09, 2011 | Gateway NV5378u Notebook
After changing the alternator 3 or 4 times. the battery 1 time i found that its not charging. each time i changed the alternator i had the charging system checked. they told me it was charging fine. then...
Your alternator can be rebuilt with parts from honda. At this point a new one would have been the way to go. It is possible you are having a problem with the wiring harness( broken wire, bad fuse block,etc.) You may even have a problem with the contact base of your ignition switch (dirty or broken). It snaps on to the bottom of the key switch. Mine stranded me at Mount Rushmore. I was able to take it the ignition switch, put in the on position, remove the contact base, disassemble it,scrape the contacts clean , put it back together, and drive away. Hope this idea helps with the problem.
May 23, 2010 | 1992 Honda GL 1500 Aspencade Gold Wing
Nokia 6600 ''not charging''
you should try a new battery
Nov 23, 2008 | Nokia 6600
CHARGING PROBLEM
Please explain what you need to do and what is happening. I do not understand what you are telling me.
Apr 15, 2008 | Sendo X Handheld
Lobster 320 Network Unlocking
http://www.unlockthatmobile.co.uk/questions/question5.php
Using the link above, just follow the instructions
Apr 09, 2008 | Cell Phones
Net unlock code LOBSTER 320
i also have same problem, My name is Eddie, Email Address is nsyeddie@gmail.com IME : 354127010311655 AND IME 354127016694617
Jan 22, 2008 | Lands Phones
Lobster 700TV Cellular Phone Logo
42 people viewed this question
Top Lobster Cell Phones Experts
Computer Repairing
Computer Repairing
Joey Gammon
Are you a Lobster Cell Phone Expert? Answer questions, earn points and help others
