Question about Samsung Computers & Internet
Samsung mmcre28g5mxp error
I am looking for a utility to test my sdd hard drive. it shows a read error when I run a hd test utility so I am looking for a specific tool to test sdd. and if possible, a tool to do a 'disk repair'
  • Samsung Master
  • 27,725 Answers
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive
hope this helps
Posted on Nov 03, 2012
  • Sandra Files Nov 05, 2012
    thanks for this information but I have heard that chkdsk on SSD doesn't provide any useful information. I am waitng to hear from the manufacturer of the drive to see what utilites they offer
  • Brian Sullivan
    Brian Sullivan Nov 05, 2012
    chkdsk will not provide any useful information its use is to attempt repair and recovery of bad sectors and files on a hard drive
  • 119 Answers
SOURCE: Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
Posted on May 19, 2008
SOURCE: mac not able to read drive
disconnect mybook from the computer then disconnect the power cable to turn the mybook off completely. Plug it back in after a few seconds and then reconnect to the computer. Worked for me and didn't lose any data.
Posted on Jun 27, 2008
babygenius55
  • 96 Answers
SOURCE: My hard drive cannot be
It sounds as though the master slave relationship may be in conflict, or that your drive is not formatted. Note--these are all steps for a pc, but since this is hardware the same process should hold true for apple products.
Please make sure your tower is powered down before removing the cover. In order to corect a master slave problem you must make sure that the jumper pin/s on the back of the drive are configured properly according to your motherboard specifications. generally, if the hdd in question is the second device on an ide cable, then you have to arrange the jumper (connector) so that the drive is seen as a slave device by your motherboard. if that doesn't work, then both devices on the ide cable will probably have to be set to the cable select (cs) position.
Posted on Nov 27, 2008
SOURCE: trouble seeing my lacie drive possible mounting issue
Not sure if this is the exact same issue, but I couldn't get the drive to mount with different connections, etc. The problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Posted on Jan 22, 2009
  • 60 Answers
SOURCE: External HD is not detected by laptop Windows XP
A common issue...I'm sure your hard drive is working fine, Windows is just not giving it an unused drive letter.
1. Insert the device (camera or usb drive)
2. Right-click "My Computer" and select "Manage".
3. Click on "Disk Management"
4. Right-click the item in the list that looks like your camera or usb drive, and then click "Change Drive Letter and Paths."
5. Click "Change".
6. Give it a drive letter that is not being used.
7. Click OK.
The device should work instantly after that.
Posted on Feb 10, 2010
This device is write protected error
Is it a brand new drive and does not have any data? If it contains valuable data, then please be careful (you can try to read it using another computers).
If it does not contain any data, then you can do:
1. Disk Management (check it if it is readable):
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management. Is this hard drive info exist in this screen? If it is, then the hard drive is not dead.
2. Test and fix it using Norton Utilities (download and run it):
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Mar 03, 2014 | SanDisk SDCZ50008GB35 8GB Cruzer Blade...
I have a 30 GB Zune (Model 1089) that keeps encountering problems (Headphone Jack, etc.) I also have an iPod Classic 80 GB (w/ a broken hard drive). Is there any way that I can put the hard drive from my...
You would probably encounter less problems just replacing your iPod's HD with a new one.
RapidRepair sells them for $110 for an 80g, and their instructions are pretty good.
http://www.rapidrepair.com/shop/1817-80gb-hard-drive-ipod-classic.html
Here's the Toshiba version of the iPod Drive-
http://sdd.toshiba.com/main.aspx?Path=StorageSolutions/1.8-inchHardDiskDrives/MK8022GAA/MK8022GAASpecifications
And here's the Toshiba version of the Zune drive-
http://sdd.toshiba.com/main.aspx?Path=StorageSolutions/1.8-inchHardDiskDrives/MK3008GAL/MK3008GALSpecifications
It looks like they might actually be interchangable, but in my experience 1st Gen Zunes have a lot of problems, especially with the batteries and HD's.
Sep 09, 2011 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Hi, I have a HP Pavilion dv7-4295us product, which has the Toshiba HD MK1059GSM. The problem I'm experiencing is that the entire system becomes slow while using it. Running the diagnostics tool of the...
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive)))
then click start all programs accessories system tools defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have
to check the details on your computer
click start all programs accessories system tools system imformation you will see all of your computers imformation from there another way of doing this
click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer if you see something running that you don
Jun 15, 2011 | Toshiba (MK1059GSM) 1 TB Hard Drive
I did a self test on my hp compaq nc6400 and got a read failure message.is this my hard drive.does it need to be replaced
First thing, back up all of the files that you want to keep onto either an external drive/stick/disc etc as read failures relate to hard disc drive read/write errors within specific clusters or sectors. You may get away with replacing the drive for the moment but your best bet is to run CHKDSK which will require a reboot as its a DOS utility and then run disk defragmenter which can be found in the system tools folder within Windows Vista. This will take quite a long time depending on the size of the drive but it should find any damaged clusters/sectors and quarantine them so that the installed applications don't write any files to these areas. If the however the drive starts clicking and excessively whirring
Apr 12, 2011 | HP Laptop Keyboard for HP Compaq NC6400...
What is an HDD/SDD Alert? I have two error messages. One says "Unable to get disk info cannot use alert function. The other says "error has occured in Toshiba eco utility it will exit application. When I...
Under Programs in the My Toshiba folder there is a Toshiba Application Installer. Open(click) that and then re-install the HDD/SDD Alert Monitor. My Toshiba did the same thing and that's how I fixed it.
Dec 11, 2009 | Toshiba Satellite L505-S5966 Notebook
Hd hard error
  • HI
  • TO TEST THE HARD DRIVE ON THE COMPUTER
  • Run the Windows Check Disk utility. This utility will check and repair system file errors (logical structure), and examine the physical structure (the integrity of the disk surface) as well. Close all applications, browsers, and utilities.Open My ComputerRight-click your hard drive (C:)Click Properties, then click Tools TabUnder Error-Checking, click Check NowClick check box for "Automatically fix file system errors"Click check box for "Scan for and attempt recovery of bad sectors"Click Start to run the utility
  • Download and run the freeware diagnostic tool "HD Tune". This terrific tool will run a complete benchmark analysis of your hard drive, check for structural errors, examine overall health issues item by item, and more.
  • Download and run the freeware diagnostic scanning tool "Emsa DiskCheck". This tool is a dual purpose utility for disk checking (pre-scan and full disk reading) and benchmarking.
  • THANK YOU
  • Sep 13, 2009 | Dell Latitude D600 Notebook
    External Hard drive wont show files or name
    Even though you may hear the motor turning in your external drive the drive may not be able to read the information on the platter(s) because the arm isn't working. This cannot be fixed; you'll have to buy another external drive.
    There are services that can retrieve the data on the broken drive. Google "data recovery services" and prepare to spend big bucks.
    Jul 09, 2009 | Western Digital Passport WDXML800UE...
    DELL XP
    This error code refers to "bad Sectors "on your harddrive ....and they cannot be accessed ......meaning your drive is probably toast or close to it .....there are HD diagnostics test you can download and run from the HD manufactuer....
    May 27, 2008 | Dell Dimension XPS PC Desktop
    Transfer Rate is LOW!
    If you?re getting odd noises coming from the hard drive you may be suffering from read errors. Windows has a utility called chkdsk that can test the hard drive readability and perform repairs in some cases. -Click on Start, then Run. -In the Open field enter ?chkdsk /f /r? and click the OK button. -You will be prompted by and error that chkdsk cannot run but will ask if you want to schedule it to run the next time the system restarts. Enter ?Y? . -Restart your computer, -Chkdsk should run after your system reboots. It will check the integrity of your hard drive and ?repair? any spots on your hard drive it can?t read. Actually what it does is move the data in the spots it can?t read and then marks the spot so that Windows does not use them in the future. The process should take a couple of hours, depending on how much information is stored on it. Let us know what you find and don?t forget to rate this posting.
    Mar 04, 2007 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
    Computers & Internet Logo
    53 people viewed this question
    Top Samsung Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
