Question about Royal Office Equipment & Supplies
The correction tape on my Royal 503 plus typewriter will not spin/move as letters are corrected.
The correction ribbon goes onto a gear, but the gear is no moving on its own. We have to physically twist the ribbon for each letter we are correcting.
SOURCE: Correction function not working
I've found that if I don't use the machine for a few weeks the correction tape that is exposed to the air becomes ineffective. I make a bunch of corrections in a row until fresh tape comes off the roll and the correcting function starts to work again.
Posted on Oct 09, 2007
  • 14 Answers
SOURCE: the correctional tape
Hello. I had a similar problem, and Upstatoes helped me. Mine started with striker stuck forward, and then went to working for a few days, but sticking forward again And it was caused by the spring not being in the right place. But the correction tape housing is pushed up and pulled down by the white, adjustable piece on the right side, that has the screw holding it into the adjustment place. If you take off the ink ribbon, push the carriage to middle, and turn on the typewriter, there will be a switch at the top left of the keyboard, on the underside, you will need to flick with your finger, one time, as the carriage moves to the left. This is the reference switch, and you will be tricking the typewriter into thinking it is now in the left side start position. After this, you can see the white adjuster piece on the right side of the carriage, and, as you type a letter, also see if it is holding down the correction tape housing. Then when you hit the erase key, see if the cam on the inside (looking through the small holes in the correction tape housing) turns and pushes up this housing? It may be the tab in the white adjuster is not inside the grove of this cam. Either way, at that point, you may be able to see if something else is not as it should be? My problem was the long side of the spring was not underneth the white adjuster. (I had been putting it under the housing, and it was not helping ot push everything up like it should be.) Aparently this cam with the white adjuster tab in the groove holds everything down, easily, as you type, but has to have the spring help to push up when you use the earse key.
Posted on Sep 18, 2008
  • 3594 Answers
SOURCE: warning sound, didn't move
Check to be sure the correction tape isn't tangled in the print wheel. If it is or was check the wheel to be sure it isn't damaged,
Then try it without the correction tape.
DickyO
Posted on May 04, 2009
M2Tech1
  • 313 Answers
SOURCE: Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Posted on Jun 12, 2009
SOURCE: We have a Brother GX-9500 typewriter/word
I called a local dealer for instructions. Apparently I accidentally released the daisy wheel when installing the new correction ribbon. Thank you.
Posted on Sep 03, 2009
My vintage Royal manual ribbon cartridge does not advance when typing., stuck in same position.
Usually lubriction, there are small pawls or teeth that move gears and pegs that fit into the ribbon. make sure you have the correct ribbon.
Oct 07, 2014 | Royal Office Equipment & Supplies
The correction tape doesn't advance. Works for few words then just gets stuck
Remove the ribbon and correction tape, type a few words make corrections check the gear that drives the correction tape to be sure it is moving (you might mark it with a dab of white out) If it moves then your L/O tape is bad. I've found that some generic ones don't fully engage the drive gear.
DickyO
Jun 19, 2014 | IBM Q27 Lexmark 6781-025 Typewriter...
The correction tape is not woring
Take ribbon out type a small amount of charaters then do a correction and see if the wheel goes around, if it does motor is Ok the it could be a bad ribbon cassette.
Apr 09, 2014 | IBM Wheelwriter 30 Typewriter
The lift-off tape is to low
1. Use the SPACEBAR or BACKSPACE to move the carrier to the center of the typewriter, then turn off the typewriter and unplug the unit from the AC outlet.
2. Open the Top Cover and remove the cassette ribbon, if installed.
3. Pull off both spools by holding the correction tape taut between the spools; bring the correction tape to a position parallel with the platen and lift up and out.
4. Pass the new tape through left guide, behind the ribbon guide and out through the right guide. The rough (sticky) side of the tape should face the platen.
5. Attach the feeder spool to the pin on the left.
6. Attach the take up spool to the pin on the right. Turn the take up spool counter-clockwise until a small amount of white tape has wound around it.
7. Replace the cassette ribbon and close the top cover, plug in the AC cord to the AC outlet, and turn on the typewriter.
May 20, 2013 | Brother GX-6750 Typewriter
I put in a new wheel and new ribbon with correction tape; was working fine but all of a sudden, it won't print correctly. It prints on the very top edge of the ribbon and the letters do not print...
On the older WW's there is a large black plastic gear on the R. side of the printer they do get tooth for tooth. try wiggling it to free it up, with the power off it should move easily.
DickyO
Oct 13, 2010 | IBM Wheelwriter 6 Typewriter
I have an old Royal 501Plus typewriter. Correction tape will not correct. I took typing wheel out and will not type correct letters now. Please help!
check if typing wheel is the correct one for this machine.
you have to make sure the bright side of he correction has to face you
unaasp192
Apr 01, 2010 | Royal PowerWriter Typewriter
TA Royal 503 typewriter with a print wheel that is not aligned
Hi - there a many reasons why this happens. Try these first. Replace the ribbon. This might have become tight (faulty) and make this happen. Next clean the main rod that the carriage goes back and forth on, it sometimes get very sticky. Then place a couple of drips of oil on. This should work wonders? Best John ex OEM trained mechanic
Jul 09, 2009 | Royal Office Equipment & Supplies
Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
May 19, 2008 | Lexmark Wheelwriter 15 Series II...
Make sure the ribbon is a correctable (yellow or orange core) not a multi strick (blue core)
Sep 13, 2007 | Brother GX-6750 Typewriter
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
