Question about Refrigerators
I have a GE refrigerator model# PFS22S1SBSS. One day I noticed that my temp display was out. I called Ge and they said it was a bad motherboard and they sent me a new one at no charge. Now, the refrig started clicking, and the compressor makes a humming sound while taking 3-6 clicks to start. Everything else seems to work. GE sent me a second new motherboard that only lasted about 12 hours and the click is back again. I removed the lower rear panel and discoverd the click is coming from the small electrical box on the side of the compressor. Please help.
  • 4 more comments
  •  George Michael Smith
    George Michael Smith Nov 01, 2012
    Is your display panel still on?
  • JWKelly59
    JWKelly59 Nov 01, 2012
    Yes it is.
  • JWKelly59
    The display works, fan works, and lights work. The clicking did not start until after the first replacement motherboard was installed. GE then sent me a second motherboard and now the refrig is clicking again. But, the click does not come from the mother board, it comes from down by the compressor.
    The little black box is a relay. It is used to start the compressor. Sounds like its having a hard time starting the compressor. You should replace the relay
  • JWKelly59
    Yes and thank you. My research has led me to a: P.T.C. + OLP ASM GE part# WR07X10097 so I'm going to give that a try.
  • JWKelly59
    JWKelly59 Nov 03, 2012
    I have now replaced the P.T.C. + OLP ASM and the capacitor connected to it, located on the side of the compressor. The refrigerator is now working properly, and the clicking has stopped.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Replace Relay.
Posted on Nov 01, 2012
Testimonial: "Going to replace the P.T.C. + OLP ASM and hope that's all it is, and that my compressor isn't bad. Thanks George."
4 Suggested Answers
the dr
  • 447 Answers
SOURCE: Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Posted on Dec 02, 2007
SOURCE: GE MODEL GSH25JSRF-SS PROBLEM HELP PLEASE
I had the same problem back in March. First the water and ice dispensers stopped working, then the clicking started and the compressor wouldn't turn on. I replaced the circuit board and everything started working again, until today. This is a very common problem with the circuit board on these refrigerators. Do a search for "GE circuit board" and you'll see what I mean. GE issued a service bulletin to its technicians that this service should be provided free of charge, and anyone who already paid to have the circuit board replaced will be reimbursed. I wish I would've known about it 6 months ago. I will be calling GE Consumer Affairs on Monday to get this resolved.
Posted on Dec 13, 2008
bruce505
SOURCE: clicking sound - not cooling
The problem is most likely the condenser fan motor at the back-side/bottom/right of the unit. If this fan is not turning, unplug the connector to this fan (inside the protective cover on the wires near the fan)... if the clicking stops, then this fan needs to be replaced.
What is happening is that this fan has failed but continues to draw a heavy load from the circuit board... It draws enough power from the circuit board to drop the voltage on the circuit board to 5-6 volts and the relays on the board open up and disconnect the power to the fan. The the voltage jumps back up to 12-13 volts and the relays turn back on causing the voltage to drop again and the relays to open.... ON....OFF...ON...OFF..... thus the clicking!
The exact part number for this fan may vary depending on the model and serial number of your unit... My model is GBS22K-BRBBB and the fan part is WR84X10055 and should cost $60-$70 though I have seen it being sold for as much as$130.
Posted on Oct 01, 2009
GE Profile Refrigerator, Red Triangle on Display
Usually it means your temps are too high.. If you don't notice any cooling issues it could be just a glitch. Try unplugging your fridge for 15 minutes to reboot it..
Jul 31, 2017 | GE Refrigerators
Ge refrigerator won't hold set temp-gets too cold
Probably the motherboard - the weakest link in the system. They're made in China using the cheapest components the chinese can find. Expect it to fail early and often.
Same is true of every other so-called "smart" appliance on the market.
Apr 17, 2014 | GE Profile PFS22 33" Artica French Door...
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
My GE Mod# PDS22SBRBLSS quit working. the interior lights come on but nothing else works. no temp. display
hi this is a bad motherboard, depending on the age you might want to call GE they replacing some of these at a discounted price which is lower than just buying the board and putting it on yourself its very cheap, you will want to do it as soon as possible as prolonged use with bad board can damage sealed system unit which will totally ruin the refrigerator.
Sean
Mar 27, 2011 | GE PDS20SBPRSS Stainless Steel Bottom...
My GE Profile (PFS22SISBS) freezer not getting cold enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 18, 2010 | GE Energy Star PDS22SIS Stainless Steel...
I have a GE profile fridge model # PFS22S1SBSS. My food in the fridge was freezing so I emptied the fridge pulled the back panel observed that the electric flap was operating by holding all buttons on...
I am surprised you were able to do diagnostics without the service manual or do you have one? I think you need to test each thermistor per test point on the motherboard. If the damper door is electric controlled then you must locate the thermistor that appears to be whacking out on you. My manual is about the only copy I have of GE's Artica/Profiles and I see yours appears to be bottom freezer. I think the thermistor is not signaling correctly and may be located near the auto vent. BRB
Apr 10, 2010 | GE Refrigerators
Regarding GE french door model pfs221sbss, need
I would call your GE service company and give them the model number and serial number of your frig. They can look up which board fits your frig.
I hope this helps.
Feb 03, 2010 | GE PFS22SISSS Stainless Steel French Door...
GE Profile - model PDS22 - constant clicking noise
Yeah, same problem. There are two capacitors that seem to be prone to going out. You can replace the main board, or (if you can solder) replace the two capacitors with slightly larger ones (radio shack mdl number 272-1030 works) just remember to bend them away from the heat sink if you go that route.
May 29, 2009 | GE Refrigerators
Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Feb 02, 2008 | Refrigerators
Refrigerators Logo
452 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
