Question about Honeywell Heating & Cooling
Can you help Me? I have a beckett honeywell R7184B oil furnace which just stopped running. Green LED light is NOT on. I have oil, electricity is going through, filter is not clogged. I just can't
  • Marie B Nov 03, 2012
    This was an issue with the Honeywell R7184B control and was replaced. Unfortuantely, I had to pay for service man to fix it. If I had known this was the issue, I could have fixed it myself. Hope this will be helpful to someone else.
4 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: my backett hell R7184B furnace is will not
You may still have air in the line. You will need to hold down the button again with a hose on the bleeder screw and open it. Do this until no bubbles come out of hose. Just keep holding the reset down for up to a minute.
Posted on Feb 21, 2010
  • 77 Answers
SOURCE: r7184b just got oil reset wont reset tried main
if the reset is a square button see if this will work. hold the button in, the green light will go out, count to 30 by 1000s, (1001-1002-1003 etc.) at around 1030 the green light should flash once. when it does release the reset and wait about 10 sec. the pump should start. if it runs for about 15 sec. and shuts off the pump needs to be bled. good luck, hope this helps.
Posted on Jan 22, 2010
  • 37 Answers
SOURCE: Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Posted on Nov 23, 2011
Why is my transformer not arcing at all when I know it is good?
it might be arcing inside itself thus shorting out. If it doesnt arc at least 1/2" spacing then u either have to dry it out or mmost likekely replace it.
Mar 02, 2016 | Heating & Cooling
Need wire diagram from the hot wires feeding a blue angel oil burner and blower motor
Dean,
What kind of primary control? Beckett?Honeywell? Carlin? Control model #?
Oct 18, 2013 | Peerless WV-DV-04, Oil Fired, Hot Water...
I have a r7184b furnice will not reignite after 3 days since basement had 2ft of water in it. green light will not came on and does not respond with the red reset
well it could well still be damp in the furnace you may well need to dry this out , then call a heating company to check it out .
Sep 05, 2011 | Honeywell Heating & Cooling
Our oil tank ran out of oil. We just had it
On the burner unit near where the inlet line enters the unit you will find a little bleeder screw It should require a small 1/4 or 5/16" wrench to open it DO NOT remove it just open it a full turn or 2
Fuel and air will come out of the top of this fitting Once no more air comes out close the bleeder, clean up any spilled fuel and restart the furnace
You may have to do this a couple of times to get all the air out of your lines
Mar 08, 2010 | Heating & Cooling
My backett hell R7184B furnace is will not reignite when I hold the reset button down. I had run out of oil yesterday and believe I've bled all the air out of the lines. I held the reset button down for 30...
Feb 21, 2010 | Honeywell Heating & Cooling
R7184b just got oil reset wont reset tried main furnace reset same thing green light still keeps flashing any ideas????
Jan 17, 2010 | Heating & Cooling
Honeywell Beckett Oil burner locked out.....just
how do you reset a beckett oil burner when your locked out ?
Nov 04, 2009 | Heating & Cooling
3 year old Beckett AFG with Clean-Cut system. New inline filter new strainer, new nozzle, flame looks correct in pattern always. Flame does not sputter prior to shut-off. I did notice that when it shut off...
Called Beckett at 1-800-OIL-BURN and explained the problem. They told me that the solenoid on the oil pump (Clean Cut) was the cause. I purchased a new pump for $50 at the local plumbing supply and installed it. Problem solved.
Nov 20, 2008 | Heating & Cooling
Heating & Cooling Logo
1,798 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
