Question about GE Washing Machines
GE 315 washer will not fill
Will not fill in any cycle or for rinse
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Make sure the water is turned on. First I would check the water level switch. There is a tube that attaches to it and runs down to the drum. Sometimes these get clogged. You can take the tube off and inspect then clean.
Posted on Nov 01, 2012
  • 209 Answers
SOURCE: GE Washer overflows
washing machines of any make or shape have a level sensor, this normally consists of a thin pipe from the lower end of the machine (where there is water) normally enters the bottom of the outer drum casing, this thin rubber or thin plastic pipe goes up to the top of the machine just inside the casing, it leads into a "pressure switch" a circular disc object about 50 cms in diameter on average, also this has about 4 to 6 wires on it, this thin pipe becomes blocked not allowing air to be forced up the tube into the switch, not switching the machine water flow off when it gets to the correct level empty the machine, drain off the water, unplug the power supply, and clear out this pipe, normally its congealed old soap powder, place pipe back as it was, checking for any leak holes in it, if damaged, replace it with new, run machine again to test long winded but i hope i have explained it thoroughly
Posted on Sep 27, 2007
SOURCE: GE Front Load Washer
Removing the lower front panel (3 screws nearest floor), and opening the round, white water pump filter cap (be ready to catch about 2 gallons of water!) is the best place to start. All you need is a Phillips head screwdriver and a large, flat pan (deep turkey tray works well)!
YOU WILL NOT BELIEVE what I found in my filter housing this morning (see photo below)!
The washer is working fine now, although I may go back and remove the entire water pump so it can be dismantled, thoroughly cleaned, and reinstalled.
Posted on Sep 22, 2008
  • 65 Answers
SOURCE: Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Posted on Jan 27, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
I have a GE front loader washer and on the rinse cycle it stops and counts down.
Most washers now have a cold rinse only per government requirements. If you have the cold half of the inlet valve bad or sometimes blocked with sediment it will not fill for the rinse cycle causing the problem you have. The inlet valve is the part your house hoses hook to on the back of the machine.
Mar 07, 2015 | GE Washing Machines
Water fills at a trickle during rinse cycle and NEVER fills up.
check urt water inlet valve and urt water pressure swttich
Sep 20, 2014 | GE Washing Machines
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Feb 20, 2013 | Washing Machines
My washer initial had a rinse cycle problem where no rinsing occur after washing, now it spreads to the wash cycle where it is pausing at the this cycle, need urgent advice
The problem is you are not getting cold water fill. (rinse is all cold water fill) Check to see if the inlet screen is plugged by turning valve off that supplies cold to the hose attached to the machine, then removing the hose at the machine and checking the filter inside the water valve where the hose was just removed from. If screen is not blocked, replace water valve.
Nov 20, 2011 | GE Washing Machines
Top loading GE color profile washer (wpse4200a) won't fill
You may have a water supply problem. There is a mesh screen in the hoses where they hook to the washer. Make sure they aren't clogged up
Sep 19, 2009 | Washing Machines
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
WASHER LEAKING
DO YOU MEAN THE SPIN RINSE CYCLE OR FILL UP?THE FRONT COMES OFF FROM UNDER THE TOP SEAM,USE A PUTTY KNIFE ON EACH OF THE FRONT SIDES,PUSH IN ON THE CLIP AND PULL OUT ON THE FRONT PANEL,DO THIS ON BOTH FRONT SIDES,LET ME KNOW,THANKS-MIKE
Jun 23, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
22 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
