Question about Dell Dimension 4700 PC Desktop
Dell dimension 4700 power supply fan has gotten very loud
I replaced the CPU fan, because I couldn't tell which fan was so noisy all of a sudden. I did clean out inside the chassis, also. The air blowing out is not particularly hot. The pitch of the fan sound does rise and fall. Should I be worried about my power supply or anything else? Thanks for any advice.
  • marla978 Jan 04, 2009
    Yikes, two very different opinions. Can I even replace the power supply fan without replacing the whole power supply?? What do bad bearings sound like? It doesn't sound bad, reallly, just much louder than it has been in the past...
All the above answers are correct to some extent. Problem is that your fan hasn't stopped. It's hard to diagnose something that isn't broken.
Depending upon how critical the computer and your finances, your fix could be:
1: Do nothing and wait for it to stop working.
2. Spray fans with DW40 and wait for it to eventually stop working.
3. Replace first one, then the other fan.
4. Replace both fans at the same time.
5. Replace computer.
Posted on Jun 03, 2010
    Problem Solver:
  • 20 Answers
The best way to test to see what fan is noisy, is to turn on your computer and tap each fan in the middle lightly, if the nosie stops for a second, you've found your fan. The best way to clean a dirty fan is a can of compressed air, and follow directions carefully.
I wouldn't be worried about your power supply fan. Unless it has hair on it from any animals, than I would give it a couple quick sprays of air. It sounds like you did a good job. :)
Posted on Jan 04, 2009
  • Nathan B
    Nathan B Jan 04, 2009
    Yes, you can replace your power supply fan, I would check to see if there is a warranty on your power supply first before you take it apart.
    Scholar:
  • 97 Answers
On many Dell models the fan speed is controlled by the system. So it is normal to hear the fan speed up and then slow. If you feel warm air leaving the PC its likley in good shape. There is a fan in the powersupply too, and if its going out it will usually squeel or make a vibrating noise. if its just high speed fan noise, thats normal.
-FW
  • 56 Answers
I'm not sure whats wrong with it put it maybe that the bearings in the fan are bad i suggest that you get a new fan:)
  • Christoffer Petterson Jan 04, 2009
    yes you can make it more silent with out changing the unit, you just get a "new" fan that fits where the original one was at then you hook it up and screw everything back together then you shall get her in and get her done:)
Whining fan dell E520 computer
Replace the fan as soon as possible. If the noise suddenly stops, DON'T assume the problem corrected itself. More likely, the fan completely froze and stopped spinning entirely and you're at risk of overheating something inside. Generally, there are usually 3 fans in a desktop computer (cpu/heatsink, case, and power supply) and sometimes a 4th fan if the computer has a separate graphics card. Laptops usually only have one fan.
Apr 27, 2014 | Dell Dimension E520 PC Desktop
Nothing on monitor. orange power light on tower and monitor also loud fan??
Usually means the power supply in the case has failed. I'd start by replacing it.
Jul 06, 2011 | Dell Dimension 4700 PC Desktop
Loud noise from fan cpu not comin up
You probably should chek your fan
or you can look at your power supply it has a fan to
restart your computer go to setup mode "bios" and look at the temperature
Mar 15, 2011 | Dell Dimension 4700 PC Desktop
Have a dell dimension 4700 with orange steady light?
Turn the machine off and unplug the AC power then hold the power button in for about 30 seconds to drain any residual power. Plug it back in and turn it on, when you see the Blue DELL word press CRL+ALT+D and this should run a diagnostic on the hard drive. If it runs ok you will get a pass or fail on the hard drive. If you cannot get the diags to run you might have a bad power supply or motherboad/processor. I would find a known good power supply and try it before the motherboard.
Mar 09, 2010 | Dell Dimension 4700 PC Desktop
My dimension 4700 power supply gets noisy so i blow out the fan and it quiets down. this has happened several times. is my power supply starting to go bad?
Chances are it is just the fan in the power supply that is going bad. It either has dust in it, or the bearing is just wearing out. Either way, you could open it up and replace the fan with a similarly sized fan if you are careful. Power supplies contain large capacitors that can cause injury. If your case has adequate ventilation, a dead power supply fan may not cause any overheating, but it may decrease the life of the power supply.
Jul 14, 2009 | Dell Dimension 4700 Power Supply ** FREE...
Static with computer speakers pentium 4 dimension 4700 series
Dell 4700 Check the video card fan. Had one that was full of dust..Cleaned it and moved the sound card away from the video card.. this fixed my problem.
JZ
Jan 29, 2009 | Dell A425 Computer Speakers
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Loud Dell desktop
Any fan that is making noise you would need to replace. There is also never a need to use alcohol to clean a fan. Some computer air or a light wipe down will do just fine.
If you have any other questions let me know.
Thanks,
Lee
Jun 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 4700 PC Desktop Logo
2,295 people viewed this question
Alun Cox
