Question about Frigidaire Gallery Electric Washer/Dryer Laundry Center
How do i change a broken belt on frigidaire gallery dryer
Motor working but drum not turning
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 02, 2012
  • 38 Answers
SOURCE: Dryer drum has come loose, how do I tighten it?
These machines have a metal ball (like a small trailer hitch ball) mounted on the rear of the drum that rides in a plastic saddle mounted on the rear of the machine,
The parts that you need to replace would be the plastic glides mounted in the front of the drum that run on teflon pads glued to the rim around the door. When they get bad you start to notice dammaged clothing.
The drum is allowed to sag down enough that clothing can get into the gap at the bottom and as the drum turns upward the items get pinched when the gap closes at the top.
All these parts can be replaced but be prepared if you do it yourself, this is a tough machine to work on.
Good Luck
Quentin
Posted on Oct 04, 2009
  • 512 Answers
SOURCE: I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Posted on Sep 03, 2009
SOURCE: Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Posted on Dec 26, 2007
  • 89 Answers
SOURCE: FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
Posted on May 28, 2009
  • 22 Answers
SOURCE: model FWT449GFS1 Frigidaire Gallery problems: roaring
most likely transmission bearings are worn out (sounds like a jet plane taking off) unfortunately this requires replacing the transmission which is a costly job.
Posted on Sep 08, 2009
I have a minalta cs pro ep 1085..when I tried to take copy the paper jumed and errore code apeared (c0010) ,, any help will be greatfull
Sir/Mam the Drum Motor is failing to turn the drum it self mite be jammed. Not allowing the motor to turn . Remove the drum cartridge. And see if you can turn the drum with your fingers DO NOT TOUCH The color part of the drum turn by both thumbs on the edge of the drum TURN CLOCKWISE if you turn Counter clockwise you will flip the cleaning blade that is not good. The cleaning blade removes the old toner before the new image is placed on the drum if it looks yellow then get a new one and replace it. IF you think the drum is stuck to the cleaning blade then for about a half inch push the drum counter clockwise the then clockwise. Also might remove he drum to see if its jammed. Also the motor might be bad or the circuit board that replaces it. Hope this works for you
Hope this works for youH
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 23, 2013 | Minolta Office Equipment & Supplies
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
My ED56 won't start unless you turn the drum by hand why?
Apr 28, 2012 | Fisher and Paykel Dryers
Dryer works but drum will not go round also the belt is perfect so it is not that
is the belt a good tight fit on the drum??? is the motor turning? can you turn the drum by hand? if you cant turn the drum by hand its likley to be drum bearings stuck up or sezed up motor?
Aug 08, 2010 | Hotpoint Dryers
Creda T520VW is very noisy when drum is turning and then it keeps tripping the fusebox. What can be causing this?
this sounds more like two faults,, a motor fault and a bearing fault
if the bearings on the dryer drum have worn out and the drum is draging the sides of the dryer the poor old motor is working its hart out trying to turn the drum this is putting a lot of load on the motor and the motor is pulling a lot more amps to do the work,, this trips the trip in the fusebox good job too or the motor would catch fire! ,,,yes i did say "catch fire!!!" to test the drum bearings,
open the dryer door and see if you can lift the drum up if you can the bearings have worn out,,there should only be a small amount of lift in the drum
as for the motor,,,its had it now? its been cooked!
Aug 05, 2010 | Dryers
My Maytag dryer drum is not turning but it was earlier working.
The drum is turned by a large, flexible belt that runs all the way around the drum, and also through an electric motor that spins the drum. If the motor is turning and the drum isn't, the belt is either broken or off the motor pulley. If the motor is not turning, it's either a bad motor, a bad connection, or a bad circuit that is not providing current to the motor when it should. It's a pretty serious problem at that point.
There is one easy fix; Check to see if you have something messed up with the door closing sensor; I had a little plastic tab break off of mine one time, and it was a $2 replacement part and it worked fine for years after that. If the sensor isn't working, it thinks the door is open, and won't let anything happen.
Apr 08, 2010 | Maytag Dryers
Dryer will not turn. makes a low hum for a few seconds then nothing.
Hello, Unfortunatly your primary winding on the motor is bad. basically when the motor first starts the primary winding gets the drum turning and does the hard work. when this winding fails the motor is not able to do the hard work to get the drum turning. If you took the lid off your dryer and hit start while helping the drum turn by pushing it the drum would start. Some techs on here talk about drilling holes in the motor and spraying oil inside the motor. In 25 years I have never seen this work on a motor this big. Only safe way to repair this problem is install a new motor. if you have any further questions please feel free to comment. Good luck! Mike
Oct 20, 2009 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
Is it the capacitor or the motor that isn't working?
it's the motor to weak to jurn over,i see it all the time,replace the motor if you want(ebay)the model number is inside the door-mike
Jun 16, 2009 | Dryers
Drum not turning
If you are certain that the motor was turning, then the only things that come to mind are that:
  1. The belt is stretched or worn-Replace as there is no adjustment.
  2. The drum is stalled, either because it has seized, or there is something stuck in the drum.
  3. The motor brushes are worn, and will not cope with load of drum, check brushes.
Try running it on fast spin without the belt on , if it spins o/k, then that would indicate the motor is o/k.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dryer Motor won't always start Model FSE747GES
Too much drag on the Drum. Try lubricating the rollers that the drum turns on. Check the belt tensioner pully...lubricate that as necessary. If Drum still turns very hard after this then take belt off of motor and try turning drum. If drum turns easily then replace motor.
Nov 24, 2008 | Frigidaire FDE336RE Dryer
Frigidaire Gallery Electric Washer/Dryer Laundry Center Logo
203 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
