Question about IBM Wheelwriter 3500
Beeping when I type
I can't stop the beeping when I type. It starts at the same spot each time.
  • IBM Master
  • 3,594 Answers
If it beeps on every key depression try code s. If it beeps at the end of a word code 1. if it beeps at the same spot space to the right end and press R. MAR key.
DickyO
Posted on Nov 06, 2012
My Whirpool Duet front loader will begin a wash cycle, but stops when cycle switches to rinse with water in the drum. Door remains locked & light by the 'wash' flashes 9 times...
when the machine is stopped can you empty the residue water that remains by the programme selector? if not check for blockage in the pump(coin), the hose internal blockage ,or at the outlet under sink. I hope this help
Jan 15, 2015 | Whirlpool duet Washing Machines
Have a Fisher & Paykel two drawer built in, each drawer will start running, but stops many times thru the cycle and starts beeping.
The dishdrawer is a very sophisticated dishwasher and is very sensitive to dirt collecting inside and in the drain hoses. My suggestion would be to first clean the drawers from inside with damp cloth, especially around the top panel. Buy Finish dishwasher cleaning kit (one for each drawer) from the supermarket. Select longest cycel on dishwasher and run each drawer with the cleaning kit inside as per instructions on the kit.
See if this makes any difference.
Dec 11, 2012 | Fisher and Paykel Dishwashers
Mercury mother bord not loding satup manu with all f key and 'del' stop in start screen
1) Look at the bottom of the Mercury logo screen when it comes up.
2) Memorize or write down the -> enter BIOS Setup, or enter CMOS Setup key.
3) Restart the computer.
Let it go to Windows, then Start > Turn Off Computer > Restart.
Won't go to Windows? Hold down the CTRL and ALT and DELete keys AT THE SAME TIME. This will restart your computer.
AS SOON AS the monitor screen goes blank, (Windows is restarting), tap on the enter BIOS Setup key repeatedly.
Tap in 2 second intervals.
Hear a series of beeps? They are Stuck Key Error Code beeps, and you are causing them. Ignore the beeps.
Computer is off?
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup (CMOS Setup) key.
The enter BIOS Setup window goes by F-A-S-T. The above method/s will get you into BIOS Setup.
Regards, joecoolvette
Nov 05, 2012 | Computers & Internet
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Start sewing and starts beep say e2
try rethreading the machine top & bobbin
clean under the needle plate & in the bobbin area for loose threads or lint
try changing the needle
May 20, 2012 | Singer 7422
Running machines broken
Dear Sir:
Please adjust, clean very well, and tigh the connector from Reed switch see the diagram attached.
2) Tight the flexible cable from keypads + connector from display board vs lower board.
After your fix it RUN the software calibration for diagnosis +trouble
sincerely. God bless you
Apr 20, 2012 | Exercise & Fitness
Hello where can I find the error codes for a fisher and paykel smart drive 703? It stops usually during s pins cycle (well it looks like it's trying to spins and it won't start).so it stops and...
Hi - what would youlike to know - we are forbidden by contractual & copyright laws to provide what you seek..
Besides you are lucky if parts for the 703 is still in existence - only savvy techs could salvage those as you have to modify wiring & components for it to work. I have only done this once in the Pacific islands some years ago.
Jun 24, 2011 | Fisher and Paykel (IWL12)
I have a proform xp 550e trademill and i changed the motor control board because the motor start running and inmediadlly stops. after i installed the board the motor start running and stop some time after...
To calibrate the speed follow these steps.
Press stop and speed up and place the safety key in its spot.
release the stop and speed up.
Press stop again. The windows on the console (speed & time) will be all zeros.
Press speed up, the time window will increase. The belt should start to move. Increase this number to 85. This is maximum speed. Adjust the potentiometer to the correct maximum speed. The console will beep until the correct speed is adjusted (+ or - .2mph).
If the machine suddenly goes dead when in use, you may have a static electricity problem.
Check that the ground pin is present on the plug and check your outlet for a proper ground connection.
Dec 29, 2010 | Proform Exercise & Fitness
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
IBM Wheelwriter 3500 Logo
337 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
