Question about Samsung SIR-T160 DTV Receiver
Cannot receive HD signal
My antenna is a standard rabbit-ear model capable of HD reception. I live in Scottsdale, Az, on the second floor of an apartment complex that only has 2 story apartments. All of the broadcasting antennas are located approximately 18.3 miles directly south of my apartment on South Mountain, with nothing in the way except for urban structures. The only urban structures imbetween me and the receivers are apartments and businesses that are approximately the same height. I get 0% reception when using the HD box diagnostic tool. When switched to analog mode, almost every channel is fuzzy except for 1 which is fairly clear and uninhibited. I tried even moving my antenna outside; the analog channel for fox 10 was clear but I still couldn't receive any digital broadcasts with a channel scan. I also tried manually inputting the digital equivelant for this station, which said it was up and running with no problems. Still can't receive anything. I realize an outdoor channel master would be best, but because I live in an apartment I cannot post one. Would an outdoor directional antenna work even if I can't see over the buildings across the courtyard? If not, what antenna model would be best? I've tried reading reviews but cannot seem to find a helpful one.
  • 68 Answers
TERK HDTVa is a good amplified indoor antenna.
Posted on Jan 05, 2009
No signal on set top box im using rabbit ears and
The problem is that rabbit ears aren't that sensitive. They don't pick up enough signal quality before the amplifier stage to get decent reception. They only work well if you're in a location where the signal strength is very high.
There are some general tips for using these indoor antenna/aerials such as getting close to a window. But if you live in a building constructed from the mid 80's onwards then there's a good chance it has foil-lined in-wall insulation which is great at blocking external TV and radio signals.
If you can get an external aerial put up then do that. Alternatively, can you tap in to someone elses external aerial feed? (With their permission, of course).
Sep 08, 2014 | Televison & Video
I can't get FOX on my converter box--what is the channel # for FOX?
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Apr 07, 2010 | Televison & Video
TV picture freezing
digital signals do not fade out and get snowy like signals used to do ... if the signal gets too weak then it just freezes .. you might say its either perfect or frozen .. sometimes it gets blocky .. where some sections of the screen freeze while other sections continue .. what that means if you are using an antenna is .. you need a better antenna or better aim for the one you have .. outside is much better than inside but just rabbit ears are ok for strong signal areas .. you can aim the antenna based on a signal strength meter usually provided in HD receivers in the setup menu .. you can also get an antenna map from "www.antennaweb.org" .. that will show you what direction to point the thing for each channel and how strong each channel should be ... if you are using Cable instead of an antenna then you should have good signal strength but there is a problem called "Crest Factor" .. that becomes an issue when they put too many signals on a given cable .. the cable handles it ok as long as there is no damage (bad ends, water inside, animal chews, corrosion) but the cable box or receiver may be overloaded as thousands of signals drift in and out of phase ... thats a cable company problem that might be getting worse as more channels are added .. the results are that periodically the picture will freeze or pixelate .. you probably have to accept a little of that but more than a little gets really irritating ....off the air reception with an inside antenna (like rabbit ears) you will find that moving around the room can effect the signal for channels in the UHF range (most are) .. aiming the antenna and getting it as high as possible will minimize that problem.. make sure whatever antenna you use is designed for UHF as well as VHF .. the little circle often found between the two "rabbit ears" is actually the UHF part of the antenna .. it can be rotated for UHF channels while the big ears are aimed and adjusted for VHF .. antennaweb.org will tell you which is UHF and VHF ..
Dec 28, 2009 | Televison & Video
I've just hooked up my converter box. I can get most channels with decent reception. However, I can't get my NBC affiliate. I've been told that I need a new indoor directional antenna. What kind shoul
Totally depends on how far you live from the station you want. I sell antennas, converter boxes, the whole shebang at my retail store, and you're not alone in your confusion :-) My best advice to you is this:
www.antennaweb.org
If you live closer than 15 miles, rabbit ears
If you live closer than 20 miles, omnidirectional
If you live closer than 50 miles, midrange outdoor (oldschool arial w/ rotator)
Further than 80 miles, you'll need a long range with rotator, perhaps even an amplifier to go with it. Print off what your results were on antenna web and bring it to a RadioShack or a local antenna store and they should be able to point you to the right antenna for your particular location.
May 22, 2009 | Toshiba 13A25 13" TV
Is this TV digital ready
According to http://www.dtv.gov/consumercorner.html#faq9
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Recoton Advent Advent TS2066A TV
Does a CT-27614A need a digital converter for antenna?
I hope this soultion is helpful.
Feb 12, 2009 | Panasonic Televison & Video
Sanyo model HT27547 installed to Dishnetwork satellite.
the model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
Dec 26, 2008 | Sanyo HT27546 TV
I have a digital TV with an outside antenna and rotor.I rcv analog channels w/o any problem.I can rcv channel 19.1 on my TV and on my old TV with a converter box. I have gone to antennaweb.com to get the...
the frequency catcher of the antenna may be weaker then required.to receive the digital channels u can attach a network booster which will solve the problem.
Dec 04, 2008 | Televison & Video
Switching to digital
No. The change only effects people that use rabbit ears or a rooftop antenna. If you receive cable now, no change is necessary. You will not be able to receive the HD channels, but you can't receive thiose now either. An HD set will show you the HD signals that your current Standard Def set can not show. Please note that your current set has a digital tuner but processes analog signals. The "digital" tuner that is requried for rooftop reception is to process digital broadcasts as the analog signals will no longer be broadcast.
I hope this helps,
Dan
Nov 13, 2008 | Orion Televison & Video
Over air reception
Unfortunately, I'm in Australia and not familiar with New York TV transmissions, however, the reception principals are the same.
Your signals are most likely bouncing off walls etc in your apartment with several 'reflections' being picked up by your indoor antenna.
This 'multipath' reception causes errors in the digital signals.
Your receiver can correct a certain amount of errors, but if there are too many, your picture will pixelate and the sound will make loud noises and then you will lose reception altogether.
The fix for this problem is connecting to a roof-mounted antenna and signal distribution system. Most apartment buildings have one, however some only distribute cable channels.
There is a possibility of a fault with your TV, but from what you describe, it sounds like a signal issue.
Have a chat to your building manager and ask what system they use for FTA reception in your building.. perhaps there's a fault that they are not aware of.
Sorry I can't be of more help.
Good luck.
Apr 22, 2008 | Televison & Video
Samsung SIR-T160 DTV Receiver Logo
602 people viewed this question
Henry  Thomas
Henry Thomas
