Question about OfficeMax Office Equipment & Supplies
Where can I oreder parts for my model OM96144 shredder?
3 Suggested Answers
  • 45 Answers
SOURCE: OM96144, The Door Open light will not turn off, so
It sounds like the safety switch on the door has failed.
You will need to have the safety switch on the door replaced.
There is another option but it is not recommended as it will bypass the doors safety mechanism and requires the switch wires to be cut and connected to complete the circuit.
You should never play with anything electrical as it can cause serious harm and / or death.
So I would recommend you have a qualified repairer look at it.
I hope this helps.
If you have any further questions please let me know.
Best regards,
Dave
Posted on Nov 23, 2010
Testimonial: "Thanks. I'll just replace the whole unit."
dcramer531
  • 1654 Answers
SOURCE: I have an OfficeMax paper
Do you have any lights? If not then you will need to replace a blown fuse on the circuit board. The fuse is soldered into the circuit board. Check the fuse with an OHM meter for continuity. The fuse is 6.3 A miniature pigtail, You have to solder in a fuse holder and regular size fuse unless you have a source for the pigtails. If you have lights and can hear a motor then chances are, the overfeed caused the teeth of the gear that operates off of the motor to break which is not uncommon. How old is the shredder, is it possible to return it under warranty? Have you made sure that all the paper is out of the teeth and not blocking the sensor? sometimes it can get quite hard to remove all the jammed paper. You will have to take the cover off the shredder hear to acces the circuit board, might get lucky and find this model ahs an easy change fuse but most do not. Also have you checked it with another outlet to make sure the outlet fuse did not blow?
Pigtail fuses should look like the ones in the picture provided.
Posted on Aug 18, 2011
Source for gear for fellowes 301101 DS-1 paper shredder
Replacement Parts - Paper Shredders Can I get my Fellowes paper shredder repaired or purchase parts for it?
The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
*** Please note: If your shredder is still within the warranty period, we ask that you do not open your shredder until speaking with a Fellowes Representative, as opening the unit may void your warranty.***
Fellowes office/commercial shredders (large shredders that cannot fit under a desk) are repairable and parts will most likely be available. Please do not try to repair the shredder yourself or you will void your warranty. Models included in the office shredder line are 125i Series, 225i series, 325i series, 380 series, 420 Series, and 480 series.
If you would prefer to have a local servicing dealer provide repair service to your office shredder, and would like to find a dealer in your area, please see the below link to search for a dealer by zip code.
http://www.fellowes.com/Fellowes/site/support/support_authorizeddealers.aspx
To order replacement parts, or if your model shredder is not listed, please click the "Ask a Question" tab above to ask us about your shredder. *** Please be sure to include your serial number from your shredder for the fastest service ***
Our office hours are 7:00 AM to 7:00 PM, Monday through Friday Central Standard time.
Jan 22, 2015 | Fellowes Office Equipment & Supplies
Spare parts for a fellows p45-c shredder
Can I get my Fellowes paper shredder repaired or purchase parts for it? The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
Go to
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=176&fml=0&brd=mine&thid=24364827
and 'Ask a Question' give personal details, and that will give you details if spares are available
May 08, 2014 | Fellowes PS8C Shredder
I NEED INTERIOR MACHINE PARTS TO MAKE REPAIRS ON MODEL # AS501X-MS. CAN I ORDER REPLACEMENT PARTS? I NEED A PARTS LIST.
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. Don't open your shredder to repair it yourself because it will void your warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Mar 02, 2011 | Aurora Global AS501X-MS Shredder
OM96144, The Door Open light will not turn off, so shredder will not run. The door is closed tightly.
I hope this helps.
Best regards,
Dave
Nov 23, 2010 | OfficeMax 0M96431 Shredder
I need a parts and owners manuel for a Super Tomahak Wood chipper made by Garden Way Mfg. Co. where do I go to get one?
Hi and welcome to FixYa. I am Kelly.
Go to this site:
http://www.brentchalmers.com/
I note your looking for the Super Tomahawk. If you can come up with a model number I think I can find your parts manual for sure. (or at least an on-line parts list.) Also.... If you can come up with an engine number like OH120 or L90 off of the engine I can find you a manual for the engine also.
This is the list of Manuals available there:
  • 1983 W-W Grinder Inc. Manual and Parts List Super Tomahawk 5-8-2G/C and Tomahawk 5-8-2G/M Chipper/Shredder (40 Pages)
  • 1989 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1989 Troy-Bilt Technical Manual 4HP, 5HP, & 8HP Models Tomahawk Chipper/Shredder (12 Pages)
  • 1991 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1991 Troy-Bilt Knife Kit number 1772231 (1 Page)
  • 1992 Troy-Bilt 5HP Model Service Kit (Part Nos. 1901153 and 1901804) For Chipper/Vac (1 Page)
  • 1992 Troy-Bilt Owner/Operator Manual 47260, 47261, 47271, 47272 Chipper/Vac (60 Pages)
  • 1993 Troy-Bilt Sales Brochure Chipper/Vac (4 Pages)
  • 1993 Troy-Bilt Owner/Operator Manual 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (44 Pages)
  • 1993 Troy-Bilt Parts Catalog 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (16 Pages)
  • 1994 Troy-Bilt PTO Chipper/Shredder Owners Dog Clutch Kit 1902404 (1 Page)
  • Hopefully your model is one of the above.
    Here is link to the Parts manuals:
    http://www.partsandservice.com/html/TroyBilt/cs/
    There are 90 parts manuals there.
    Again with a good model and engine number I can probably come up with your exact manuals.
    Thanks for chosing FixYa,
    Kelly
    Oct 20, 2010 | Troy-Bilt Chipper Shredder
    Looking for spare parts for a Challenge Paper Shredder model S213
    Hi there. I've got the same shredder which I purchased couple of months ago so maybe it's not that olod model after all :) The problem with mine is that the small thing that sits inside and "feels" when you feed the paper and which triggers shredder to operate, has broken in to two. My hubby tried to glue but I don't see any success there. Any chances to get that spare part any where?
    Jan 18, 2010 | Office Equipment & Supplies
    Shredder knive are all bent up
    Heres a few sites that have gears and parts another that has manuals you may have to call or email as not all parts are listed on website
    http://www.compax.com/shredders/parts.html
    http://wheelermachines.com/manufacturer.html
    http://www.manualsonline.com/ex/thread/view/idThread/1735067
    May 23, 2009 | OfficeMax 0M96431 Shredder
    Can not find owner manual for shredder bagger model number 1435R
    http://www.searspartsdirect.com/partsdirect/index.action?lid=sears_parts_direct_h&sid=PEMx20080205x00003
    Oct 24, 2008 | Heavy Machinery
    81 people viewed this question
    Top OfficeMax Office Equipment & Supplies Experts
    ROCKIT957
    Randy Schumann
    Randy Schumann
    Colin Stickland
    Colin Stickland
    Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
