Question about Sewing Machines
Beldray sewing machine won't make a stitch
  • Sewing Machines Master
  • 7,365 Answers
Try changing the needle--make sure the needle is the right one for
the fabric being sewed, and also inserted the right way in the needle
holder and all the way up into the needle holder
try rethreading the machine top and bobbin--make sure every
thread guide is used
make sure the bobbin is turned the right way in the bobbin case
if none of these suggestion help then the machine needs to be
checked to see if there is a problem with the timing.
Posted on Nov 08, 2012
  • 980 Answers
SOURCE: Singer Golden Touch & Sew
Try a new needle first failing that you may need to retime the machine, you can email me for an attachment of instructions kendourof@yahoo.com
Posted on Aug 27, 2011
SOURCE: My Janome Harmony 1017 won't
when the fabric does not move then the feed dogs under the needle plate need to be checked to see if there up or down.
if the feed dogs are down then the lever or switch needs to be pushed up into the correct position
if the feed dogs are up & they are not moving the fabric like there suppose to, cause it's there job to move the fabric against the presser foot,, then they need to be check
the gears that do the zig zag stitches should be checked to make sure there not worn & weather they might need be be greased
Posted on Aug 30, 2011
SOURCE: Husqvarna Huskystar 207 Sewing Machine not
Be sure not to use Singer Needles. They are longer than standard needles. Don't know if this helps, but I did this once on my Huskystar 207 and that is what happened. It also damaged the bobbin thread.
Fairleigh
Posted on Sep 21, 2011
  • 539 Answers
SOURCE: brother exedra f-40 industrial sewing machine won't sew!!!
Check that you have a new needle inseted all the way UP in the needle bar shaft threaded front to back, flat side at back of needle bar and make sure presser foot in the up position BEFORE threading to open up the tension discs fully. Make sure you leave enough thread tail to accommodate turning the handwheel toward you so that the thread isn't falling out of the needle. I would oil and lube it too when you get the chance. Here's a web site to help you with that and the timing, tension, cleaning the race shuttle bobbin area, etc. on your machine: http://www.fixsewingmachine.com I hope this helps, Rachel.Jimmy
Posted on Apr 13, 2012
mizrach612
  • 102 Answers
SOURCE: Necchi 4825, cannot get machine to sew the different stitches - have tried adjusting width/length just all come out as some form of zig zag - arggh!
Since your machine is brand new, it is under warranty. Take it back to the dealer you purchased it from and have them repair it. If you try any repairs yourself, or by a 3rd party, that will probably void your warranty.
Posted on Sep 21, 2012
Beldray 12 stitch sewing machine manual
call or email these sites
sewvacdoctor.com
a1sewingmachines.com
Mar 04, 2014 | Sewing Machines
My husquavarna lily stitches are too big and won't respond to touch pad
it sounds like the machine needs to be serviced, you have to check
with a sewing machine shop in your area & call them to ask the
price for checking or servicing a sewing machine
Aug 04, 2012 | Husqvarna Sewing Machines
Sewing machine won't stitch
try changing the needle
rethread the machine top & bobbin
if the suggestions don't work, it's possible that the machine
may have jumped time,, taking it to a sewing machine shop
the technican can tell you for sure
Jul 27, 2012 | Sewing Machines
Bernina 1130 backstitch is not working
then you need to call the shop that serviced the machine & tell them
about the problem that the machine won't backstitch & see what they
say
Apr 29, 2012 | Bernina Sewing Machines
Need Manual for Beldray 0092 12 stitch sewing machine
try these sites you'll probably have to email about a manual
sewvacdoctor.com
Apr 22, 2012 | Sewing Machines
Serger won't chain off a stitch. Stitches won't chain and hold to fabric. Added new needle, rethreaded whole machine. Stitches won't connect to fabric or make a chain.
is it possible that the needles are in backwards?
it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
Apr 02, 2012 | Sewing Machines
Sewing machine speed it won't stay the same
if you have a speed control on the machine & you set it & the stitches are not staying constant, then the machine needs to be serviced
Mar 13, 2012 | Kenmore 19365 Computerized Sewing Machine
No manual for a beldray 12 stitch sewing machine
hello how does the beldray sewing machine works? please email on alysha678@gmail.com if you know please
Feb 10, 2012 | Sewing Machines
Skipped stitches. Also, won't transition
have you checked the needle to make sure it's in correctly--flat side of needle goes to the back of the machine
correct needle insertion is mandatory for the proper use in your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
place the new needle in the needle clamp with the flat side of the needle facing the back (or if using a round needle the groove in the needle should be facing away from the shaft.
push the needle all the way up to the stop, or as far as it will go, then tighten the needle clamp screw.
how to decide which needle is correct to sew with, it depends on the fabric & thread being used for the project.
like for example, I've been sewing for over 30 years, I'm sewing a stretchy fabric & regular needles won't work because they skip stitches & will pull the fabric thus damaging the fabric, the needle I have to use is a singer universal ball point needles, & I have no problem with the stitches they come out fine.
Sep 10, 2011 | Brother XL-2600
Singer Golden Touch & Sew Model 750 sewing machine. Machine won't straight stitch, won't pick up the bobbin thread.
Aug 27, 2011 | Sewing Machines
Sewing Machines Logo
210 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
