Question about Frigidaire Dryers
I have a frigidare fse44ghso clothes keep getting caught and stained up into the edge of the drum. Can i fix this?
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
You will need to replace the "glides" and the "felt" on your dryer.Here are the glides to order.Here is the lower felt to order.Here is the upper felt to order.
You have to remove the top panel first and then the front panel. Remove the old felts and clean the metal surfaces from the old particles. Install both new felts using the glue included in the felt/glide assembly. Let it dry before reassembly.
Here is a video to show you how to do the upper felt.
Here is a video to show you how to do the lower felt.
Here is a video for the glide replacement.
The videos may be a little different in the model they show but the process is the same. Your dryer will be as good as new after this repair.
The parts comes with a 365 day, any part, any reason return.
Posted on Nov 02, 2012
4 Suggested Answers
wiringlunati
  • 576 Answers
SOURCE: clothing keeps getting caught
The felt seals probably need replacing. It's not too difficult and they should be available at
www.appliancepartspros.com
You'll probably find if you try to lift the front of the drum that it will move up and down a bit. That's another sure sign of bad felt seals. Good luck.
Posted on Mar 15, 2010
michiganfan9
  • 179 Answers
SOURCE: Clothes are getting caught on edges of drum
you need to replace the felt on the dryer
Posted on Dec 20, 2008
woodchuck789
  • 4070 Answers
SOURCE: Clothing getting caught on lint
Probably has extra space between drum because the front felt guides on the drum have worn. This can be accessed by removing the front panel.
Posted on Oct 05, 2010
My dryer is leaving rust stains on my clothes
you needto replace your dry drum .
Sep 30, 2015 | GE Dryers
Frigidaire Gallery dryer Model FSG447GHSO. Clothes and dryer sheets get caught between the drum and one of the three "bumps" inside the drum, causing burn marks on clothing. I can see the gap where it
There is a gasket that fits around the back side of the tumbler. Sounds like it needs replacing. It's job is to keep clothes inside the tumbler.
Oct 10, 2014 | Dryers
He5t tearing clothes
Are you sure that the clothes are not getting caught on exposed zips.
Why not load some things like towels sheets (without zips/buttons etc) in the washer and see if the issue repeats itself. You should also be able to see if there are any sharp edges or loose sharp items in the drum (mind your fingers)
Dec 14, 2013 | Kenmore Elite 45986 Front Load Washer
When I take my clothes out of the dryer some of them have blackish marks on them please help thanks
Make sure the drum is properly seated. If the drum sags, clothes can get caught in the gap on the bottom, then pinched when the gap closes on the top. This can cause grease stains on the clothes, or worse, can tear them.
If the drum sags, check the drive belt and drum support rollers.
Sep 13, 2013 | Whirlpool AWZ7303 Electric Dryer
My dryer is ten years old. A few months ago, some of the clothes would come out with rust stains on them. Some of the clothes would get caught in the seams which would cause staining, tearing and...
I would suggest replacing the front drum bearing. Sounds like the gap is now excessive, obviously allowing clothes to get caught up in there. Drum must be removed from the dryer to do this.
Good luck, hope this helps.
Aug 19, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Clothing keeps getting caught along the front edge of the drum, between the drum and the edge of the front opening.
Mar 14, 2010 | Dryers
Black stains on white dress shirts
The rollers, guides, or wheels that are used to support the clothes drum may be worn out. When this happens, it may cause the drum to drop down slightly in the front or rear. Clothes can get caught between the front or rear of the drum and the dryer interior. This can cause clothing to have marks and/or tears. Check out the rollers, guides, and wheels for excessive wear or damage. Sure hope this helped ya!
Jul 20, 2009 | Whirlpool WGD5900S Gas Dryer
Dec 19, 2008 | Dryers
GE dryer, black grease stain on cloth
I have the same problem, I haven't resolved it but it seems to be due to the drum of the dryer being able to move more than it's supposed to and things getting caught in between the drum and whatever it sits in, at the front of the dryer. I have found things caught in there before and when I've pulled them out they had a brown/yellow grease stain on them. Other times something in the dryer will have this same stain - although no longer caught it seems it must have been caught at some point then became free again, with the stain. I'm thinking something is loose or if the drum is supported at the back by a bearing of some sort, this bearing may be worn down and the drum isn't sitting right.
Dec 19, 2007 | Dryers
Dryer damaging clothes
Call repairman if you are not mechanically inclined it will be worth the money spent.
Oct 29, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
439 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
