Question about Frigidaire 5.8 Cu. Ft. Electric Dryer
Front Panel not working correctly
The front panel of my dryers is not responding, but when you close the dryer it turns on. It was heating up but now it's not. What did I do?
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 02, 2012
SOURCE: My dryer seems to be partially working.
gkfgk
Posted on Oct 23, 2007
thaurfen
  • 623 Answers
SOURCE: Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Posted on Jan 08, 2009
  • 104 Answers
SOURCE: Our four year old frigidaire gallery series dryer stopped drying.
knackered
Posted on Feb 01, 2009
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 423 Answers
SOURCE: Need to replace Start Switch/interupt on front panel
Unplug your dryer (seriously, don't forget to do this.)
Using a thin screwdriver or putty knife and a cloth (to protect the painted surface) insert the screwdriver between the lid on the front left, then right and pry the lid up. There are no screws to remove to get the lid up, just two spring clips. Lift the lid and allow it to lean back. It will stay there nicely, but be careful that the lid does not get pushed back down with your fingers in there.
On the right hand side, there are two (white) connectors that you need to pull apart. With good light, you will see where to press to open them. You can not re-connect them wrong.
Look down inside the front of the lid-less dryer on the left then right side, you will see one Philips screw on each side that needs to be removed.
With the screws removed, pull forward on the front panel untill some clips release and the panel leans forward.
The bottom of the front panel sit on clips that do not need to be removed. You simply list the whole front panel straight up and you can then turn it around to get at the switches.
Hey, while you have the front off, vacuum the inside and pull all the lint out of the area beneath the lint screen which is all located on the front panel.
Inspect the belt, looking for wear. You can turn the drum easily with your hands. Also, the drum light is probably burned out. They ship with a lame night light that burns out really fast. I went to Home Depot and found an LED replacement (with the proper size base) which I am confident will last a long time.
Hope this helps.
Posted on Oct 23, 2009
WHY DOES MY NEPTUNE MATAG DRYER MDE5500AYW NOT HEAT ...AND WHERE ARE THE THERMAL SWITCH, HI LIMIT THERMOSTAT, AND HEATING ELEMENT?
All those parts are in the bottom front. TURN off the power! then open the front door and remove the 4 screw's, 2 on the hindges and 2 on the other side. Then you can close the door, and pull from the top edges of the front panel(sometimes you need a thin screw driver to free the front) the front panel will tilt forward and then you can lift it off. You will need a Ohm meter to check those parts for continuity. Make sure you remove the wires from the part you are testing.
Sep 30, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Tip
Elite and Duet Dryer Heating Element Replacement
This advice explains how to replace the heating element on Whirlpool Duet, Kenmore Elite and Maytag Epic dryers.
1. UNPLUG the dryer before servicing. Dangerous voltage is still present inside the dryer even when it is turned off.
2. Open the door and remove the lint screen. IMPORTANT: You will not be able to remove the air blower cover with the lint screen in place.
3. Remove the lower toe panel directly below the door. The panel comes off by locating and removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off. NOTE: Propping the front feet of the dryer up can provide you better access to the screws (a 2x4 works well for this).
4. Disconnect the auto dry sensor plug (usually yellow wires with a white plug to the right of the blower assembly) and any ground wires that may be connected to the front panel.
5. Remove the air blower cover by locating and removing the mounting screws. NOTE: This is a good time to clean the blower fan housing, squirrel cage motor and dryer interior cabinet.
6. Remove the top panel of the dryer by locating and removing the screws holding the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then come off.
7. Locate the two screws that hold the operator console in place. There should be one on each side under the top panel. Remove the screws and carefully lift the panel straight up. NOTE: You do not need to disconnect the ribbon cables. Carefully lay the console across the top of the dryer out of the way.
8. Disconnect the door switch connector plug and remove the dryer front panel by locating the four screws that hold it in place. Loosen the two screws along the bottom of the panel and leave in place. Remove the top two screws and lift up and turn the whole front panel slightly counter-clockwise to release the drum supports from the dryer drum. NOTE: Make sure the dryer door is closed when removing the front panel to avoid damaging the door hinges.
9. Remove the dryer drum. Reach in behind the air blower with both hands and pull the idler pulley to the right with your right hand to release the tension and remove the dryer belt from the drive motor. With the belt still looped around the drum, you can use it like a handle to lift the entire drum up and out of the dryer.
10. With the drum removed, the heating components can easily be accessed. The TCO and Hi-Limit Thermostat is located on the outside of the heater box on the left hand side. The TCO is located at the back of the dryer, while the Hi-Limit Thermostat is located adjacent to the heating element terminals.
11. The entire heating assembly is removed by disconnecting all the components leads, followed by loosening the heater box mounting screw. With everything disconnected, the entire box and components will come free and lift out of the dryer. NOTE: Make sure you properly label all wiring to ensure they are reinstalled correctly.
12. There are a couple of mounting screws on the side of the heater box that holds the heating element in place. With the screws removed, the heating element will slide out of the box. NOTE: Make sure you take any resistance readings with the component disconnected from the circuit to ensure accuracy. The TCO and Hi-Limit Thermostat will read something close to 0 ohms if GOOD. The Heating Element should read 9 to 13 ohms.
13. Insert new heating element into the heater box and align the screw holes. Replace any other defective components and reinstall heater box.
14. Reinstall dryer drum ensuring the back rim of the drum rests on the rear dryer drum supports. Make sure the belt is looped on to the drum with the ribbed side towards the drum.
15. Reinstall the dryer belt by releasing the belt tension pulley as listed above, then, with your left hand loop the belt over the drive motor pulley. Release the idler pulley making sure the belt rests on the drive motor pulley. You should feel the belt tighten with tension. If you need further clarification on how to properly route the dryer belt you can go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the Special Features section. Refer to diagram K.
16. Reinstall the front panel by turning it slightly counter-clockwise and aligning the front drum supports under the front of the drum. Once the supports are under the drum, turn the front panel clockwise and lift up, placing it on the bottom two screws. Reinstall and tighten the top two screws.
17. Reinstall the door switch connector plug and reinstall the operator console. Use caution not to put too much stress on the ribbon cables.
18. Reinstall dryer top panel.
19. Reinstall air blower cover and reconnect the auto dry sensor and ground wire.
20. Reinstall toe panel by inserting the top portion first and pushing up. Push lower portion of the panel in place and reinstall screws.
I know this may seem like a lot, but its actually fairly simple if you follow the steps provided. Read through everything before attempting any repairs. If you have any questions, please let me know. I hope this helps you.
on Dec 20, 2009 | Dryers
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
Heater not functioning
Hello, does the dryer drum spins? If so, then replace the heating element in your dryer. Look on the back of the dryer, if there is inspection plate about 10"x10". First, unplug your dryer, this is very important to your life. Once the dryer has been unpluged then remove the inspection plate.
Now, if there isn't an inspection plate on the back of your dryer. The the front of the dryer will need to come off. Just leave the dryer door on. Turn the dryer on it side---Remember to unplug your dryer--- On the bottom of the front dryer panel with the door is three or 4 screws just remove these screws. Now, pull the bottom the dryer front panel out about 2" or 3" and pull the front panel down. There is two snap locks that are hooked in the top of dryer cover. Pull the dryer panel out and reach in aroun the door to unplug door switch. I hope this work out for you. GB...stewbison
Sep 23, 2011 | Dryers
I don't have a repair manual for White Westinghouse dryer. Need to replace heating element. Not sure how to get to the element
Instructions
    • Disconnect the power cord from the electrical outlet before servicing the Westinghouse dryer.
    • Insert the putty knife into the gap above the front panel and below the top panel. Lift the putty knife handle up to unfasten the internal locking clips.
    • Lift the top panel from the dryer cabinet. Rest the panel on the wall behind the dryer.
    • Remove the two screws on the top border of the front panel. Lift the front panel straight up to unhook it from the dryer cabinet. Unplug the connector leading into the front panel. Set the front panel aside.
    • Move the idler pulley arm toward the front of the dryer cabinet to loosen the belt. Remove the belt from the drum and pulleys.
    • Lift the drum out of the dryer cabinet.
    • Disconnect the electrical plugs leading into the heating element. Unfasten the screws securing the element to the inside of the cabinet. Lift the element out of the cabinet.
    • Place the new heating element inside the dryer. Connect the screws holding the element to the cabinet. Plug the electrical connectors into the element.
    • Reposition the front panel. Plug the door switch connector into its socket on the front panel. Press the panel straight down into the base. Reinstall the screws along the top of the panel.
    • Lower the top panel onto the dryer. Press down on the panel to lock it into place
May 12, 2011 | Dryers
I have a Kenmore Elite dryer model #11087872602 that would not start or light up the panel on the front of the dryer. I had a general appliance repair man come out to look at it. He took both computer...
the start switch needs replaced, as far as the front panel light not lighting you will need to open the back top panel of the dryer and find the wiring diagram and trace it out, it may something as simple as the connector is unplugged. Hope this helps Tim
May 03, 2011 | Dryers
Dryer turns on and acts normal, but does not get hot. Product is barely 1 year old.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 18, 2010 | Samsung DV219AE Dryer
Dryer works only on high heat; will not respond to touch pad.
Replace the gas valve coils. They have gotten weak and do not open on the next call for heat.
Aug 30, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Removing front panel on kenmore dryer
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
Mar 09, 2008 | Dryers
DRYER HEATS ,BUT DOESN'T TURN
FIRST UNPLUG UNIT!!
Remove 2 screws by filter area on main top.
Grab back of dryer and pull top forward while holding dryer in place with knees. Do this to pop up top on front left then front right. Remove 2 screws holding front panel 2 side panels. They are at top front of side panels, inside.
Pull front panel out at top and pull up to remove front panel. Put belt around drum with grooved side toward drum.
Nov 11, 2007 | Whirlpool LGR3624JQ Gas Dryer
Frigidaire 5.8 Cu. Ft. Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
