Crum Error - 094-330 Reseat Transfer Unit
Just received our new transfer unit for our Phaser 6180MFP Printer/Scanner/Fax Machine. I have installed the new Transfer Unit only of the display to show Crum Error - 094-330 Reseat Transfer Unit. After taking the Transfer Unit In and Out a couple of times plus I have turned the printer on and off a couple of times the message still appears. Please Help!!
SOURCE: Phaser Imaging Unit install error
Worked like a charm! Thank you for the detailed information. The step by step instructions were right on target.
Posted on May 20, 2008
SOURCE: Xerox Phaser 7300DN Laser - Transfer Unit issue
Hold down Back and Information and turn on the printer. You enter in service mode. Then you can reset CRU counters.
Posted on Sep 15, 2008
SOURCE: Imaging Unit Missing Error
Hi, I had the same problem. The following Cause and solution may help you fix your machine.
All refereces to left and right are facing the front of the machine as if for normal use.
The cause is due to the connector on thtop left rear of the imaging unit. this connector is mated with a coresponding, retractable connector in the body of the machine. When you open the cover over the top of the imaging unit, this connector retracts back into the body of the machine and when you close the lid it should re-engage with the imaging unit, The problem is that it dosen;t reconnect. I have asumed that it is due wear in the connector operating mechanism. This solution was effective for my printer.
Switch Off!!!
remove the topcover (after removing the colour catridges )and. remove the left hand side panel. You will see a nylon gear mechanism. Sqeeze together the nylon clip inthe centre of the gear wheel, and pull the gear about halfway off. This should allow you to move the vertical geared bar up 1 notch. .Push the gear wheel back on and try the machine to see if it works ok. All covers will need to be closed and if it works ok , reassemle the machine. Job done -about 10 to 15 mins. It tookme alot longer to find it,so some feedback would be appreciated.
Paul
pdouglasss
  • 125 Answers
SOURCE: phaser 6250 transfer roller
Hi clwest: I hope that this will help you.
Transfer Roller is at End of Life
■ Print the Supplies Usage page to verify the remaining life and Transfer
Roller install date.
■ Cycle printer power.
■ If the problem persists, follow the procedure below
Note
Look at the clear plastic window on the Transfer Roller. If toner is present in the
center of the window the Transfer Roller is at end of life and needs to be
replaced. If no toner is visible, try cleaning the CTD (ADC) Sensor.
The “Transfer Roller is at End of Life” is a warning. “Replace Transfer Roller” is
a hard stop.
Posted on Jan 10, 2009
  • 110 Answers
SOURCE: Transfer Life Low Error on Xerox Phaser 6180
That error is caused when your transfer roller is out of life.
The transfer roller should be in front of the machine when you open the front cover. It will look like film material it is held with two plastic locks one on the right and on the left .
They maybe be colored yellow or blue sometimes.
(800)367-4836 <-company sells refurb and brand new ones. hope this helps. They will also give you free tech support.
Posted on Dec 23, 2009
Dcp 7055 brother printer in error - print unable ec
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Note
    In order to transfer data from your fax machine to another, you must have the station ID programmed in your fax machine.
Step1: Transfer the Fax Journal Report
  1. Press Menu/Set on the Control Panel of the machine.
  2. Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set.
  3. Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set.
  4. The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Start.
Step2: Verify and Transfer faxes in memory
Step3: Reset the machine After the Fax Journal Report and faxes in memory are transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If the message continues to appear on the LCD, do the following based on your country:
<USA>If your unit is still within warranty, try to locate a Brother Authorized Service Center in your area or google to obtain contact information for the appropriate Brother Customer Service Center.
If you are out of warranty, use the link to locate a Brother Authorized Service Center in your area.
Aug 04, 2013 | Office Equipment & Supplies
Will not print in color
You can find answers to your Xerox questions at www.xerox.com/support
If the machine will copy in color it should print in color.
After verifying that it will copy in color, verify your driver is capable of being switched from black and white to color. If there are no color settings then you have the wrong driver. The link above will take you to the support page where you can download new drivers.
Mar 26, 2013 | XEROX MULTIFUNCTIONS Xerox Phaser...
We can find any information for the transfer roller for the Phaser 6180, 6280 keeps coming up. Is our machine obsolete?
No, your machine is not obsolete. You're probably not finding anything on the transfer roller because it is really part of the transfer unit (part# 675K47088 ) The transfer unit contains the transfer belt and roller. Here is a video that shows you how to replace it.
Apr 28, 2011 | Xerox Phaser 6180N Laser Printer
Xerox phaser 6303 printer shows "replace transfer unit" what does it mean,.
The transfer unit is the part of the printer which transfers the image created by the imaging drums onto the paper. After a certain amount of use it has to be replaced to maintain print quality. At that time, the printer is programmed to show the message you have received.
Aug 24, 2010 | Xerox Phaser 7300DN Laser Printer
I have a phaser 7300 that asks for a transfer unit about every 3 weeks. It prints good until it asks for unit and then it will not print until I install a new one. I am ready to install the 4th unit but...
I think you might have a Spring missing for the Waste Toner Full Sensor. The machine tolerates the sensor status for 2K pages and then shuts it down.
Truthfully, it is really hard to describe in a few sentences. It belongs in the frame wall under near where you have the white waste toner section of the Transfer Belt. This spring pushes a flag up that hits the Paper Entrance Sensor (yes, near the bypass tray)
The PN for the spring is 116-2050-00.
Whit
Item, Inc.
May 21, 2010 | Xerox Phaser 7300DN Laser Printer
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
What is error code b9 mean on the brother fax 1030?
Hello :
B9 Light emission intensity error of the LED array .
Check CIS unit (scanner device) or check main PCB .
According the error either one of these units can be faulty or a lose connection but getting to these would require you take apart most of your fax machine . Maybe it's time to purchase a new fax machine .
good luck .
rate please !
Mar 18, 2010 | Brother FAX-1030e Plain Paper Thermal...
Dec 23, 2009 | Xerox Phaser 6180N Laser Printer
Tranfer Unit
  1. Open the Top Cover on the printer.
    CAUTION: Do not leave the Top Cover open for more than 10 minutes without covering the Imaging Units as damage could result. Use the dark bag that came with the Imaging Unit or opaque paper as a cover.
  2. Remove all four Imaging Units (which includes removing the Toner (Dry Ink) Cartridges attached to the Imaging Units). To avoid Toner spills, hold the Imaging Unit in an upright position.
    CAUTION: Do not use warm water or cleaning solvents to remove Toner (Dry Ink) from your skin or clothing. This will set the Toner and make it difficult to remove. If any Toner gets on your skin or clothing, use a brush to remove the Toner, blow it off, or wash it off with cold water and mild soap. Do not attempt to use a standard shop vacuum or home vacuum to clean Toner spills in or near the machine. Shop and home vacuums are not equipped with correct filtration and will contaminate your environment.
  3. Raise the two gold colored latches (front and rear of printer) to unlock the Transfer Unit.
  4. Grasp both gold colored handles (center and right) to lift the Transfer Unit out of printer.
To install a new Transfer Unit:
  1. Remove the new Transfer Unit from its packaging or shipping materials.
  2. Grasp the two handles on the new Transfer Unit and place the left end into the frame alignment sockets.
  3. Lower the right end of the Transfer Unit down until it lays flat in the printer.
  4. Press down on both latches to secure the Transfer Unit into position.
  5. Make sure the Transfer Unit is latched into position. Lift up on the right handle to see if the Transfer Unit lifts up. If the unit does not lift it is latched correctly.
  6. Re-install the Imaging Units and Toner (Dry Ink) Cartridges.
  7. Lower the Top Cover.
  8. Dispose of the old Transfer Unit as normal office
Nov 20, 2007 | Xerox Phaser 7400DN Laser Printer
Xerox phaser 6250 NVRAM Failure
Cycle power, try cleaning the CTD (ADC) sensor and toner full sensor. This is what Xerox has to say about the NVRAM failure: On the front panel, press the key labeled i to view information about the error. Record the error code number. Turn off the printer. Reseat the fuser. Reseat the imaging unit. Reseat the toner cartridges. Turn on the printer. If the error continues to be displayed contact service. To be on the safe side you can follow the instructions here on the procedure to replace the transfer roler: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi Good luck
Mar 25, 2006 | Xerox Phaser 6250DP Laser Printer
192 people viewed this question
k24674
