Question about Vizio VW37L 37 in. LCD HDTV
First off like to say thanks too everyone thats helps out,great job!! Received this tv with cracked screen,worked fine just bad screen.Ordered screen and installed,now when powered up,screen flickers a few times and goes blank.Can unplug for few mins. does the same thing.Has sound.Dont see any bad caps.Did notice when first turned on heard a low crackeling sound by the board at top center,think its called t-con,little square board 5x7
    Problem Solver:
  • 8 Answers
Its a bad t-con, or different t-con for new panel
Posted on Nov 09, 2012
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
phongnv
  • 56 Answers
SOURCE: HELP PLEASE Vizio Plasma tv broken again - possible driver board?
This could cause by the power supply or the mainboard.
- If the LED stay Green when you turn on the TV. But you can not turn it off, in this case the main board has failed. Replace the mainboard will fix the problem.
- If the LED light always stay at Orange, you can not turn on of off. In this case the mainboard also has failed.
- If you turn on the TV you will hear the power supply click on the LED is green then it click off the light turn Orange. In this case the power supply has failed.
Which boards did the repair shop replace?
Hope this will help.
Posted on Feb 18, 2009
  • 4234 Answers
SOURCE: Vizio GLV47 LCD HD TV No Picture No Sound?!?!?!?!?
Without seeing the set and takig some measurements, I can't say for sure where the problem is, but the part info is listed below. These can be purchased through tritronicsinc.com. Please note that these boards have a "core" cost. This means that the "core" amount will be refunded to you once the defecive board is returned.
Dan
Power board: 0500-0510-0340 Cost: $102.97 Core: $10.00
Main board: 3647-0072-0150 Cost: $202.68 Core: $40.00
Posted on May 01, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
  • 10 Answers
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
Posted on Oct 10, 2009
Sony Bravia screen looks cracked? Is this just a board problem or something more serious?
New screen required as it has been damaged. Probably cheaper to replace the set.
Jun 20, 2017 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
Just to thank you for your helpand the web site for my parts. I ordered the convergence parts and received them on the 25th, made the repairs on Thanksgiving day. The picture looks GREAT. Again Thank You,...
Just to thank you for your help and the web site for my parts. I ordered the convergence parts and received them on the 25th, made the repairs on Thanksgiving day. The picture looks GREAT.
Again Thank You,
Ralph Jenkins
PS and saved a lot of money
Nov 28, 2009 | Philips Televison & Video
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
Audio went out on philips tv, video fine
all set thanks, used your site to link to philips tv which answered the question, great job on your end, i will use your site in the future
Aug 03, 2009 | Philips 32PW6506 32" TV
LCT3201AD will not turn on . The red light flickers but wont come on
open up the tv and look at the power supply. On my tv there where a couple of capacitors that where bad. They most likely have a bulging top all you have to do is replace them and everything should work fine. cost me about $5
Jun 12, 2009 | Akai LCT3201AD 32 in. LCD Television
Broken glass on front of plasma tv
Some, but not many have the front glass as a replacement, give me the model number so I can check. Oh, pioneer is getting out of the tv business this year ( soon ) if it turns out that the glass cannot be replaced or even ordered you might not feel to bad. They are one of the best at car audio, they decided to go back to the core of there business---------great idea!!!
Jun 04, 2009 | Televison & Video
Vertical lines appear on screen...
You have a defective light engine. Contact RCA support. Sometimes they will warranty these even after the 1yr warranty has expired.
May 16, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Mitsubishi Model # is WD-62531 cracked screen!
HI, there are no replacement screens available for this model unfortunately. Sorry for the bad news there...
Apr 20, 2009 | Mitsubishi WD-62531 Projection Television
My Tomtom worked for a while then stopped working.
I have a TOMTOM 910. I suggest you call the company @
1-866-186-6866 or
1-866-486-6866.
The same thing happened to mine, TomTom was great about it. They sent me a replacement actually it wasn't until I received the 5th replacement that I got one that works right.) Everyone I've talked to @ the company has always been eager to make it right. BTW, now my TomTom works great, had it for 2 years now & wouldn't think of buying a different brand. If this helps plz rate this 'fixa', if you need more help leave a comment & I'll be happy to help you. Thank you kindly.
Feb 13, 2009 | Tomtom GPS
Norcent LT-3222 32" LCD HDTV SCREEN TURNS GREEN
I have the same problem and need help. Have this TV over 5 years and don't know what to do this it
Aug 29, 2008 | Norcent Technologies LT-3222 32 in. LCD...
Vizio VW37L 37 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
