Question about Xerox Phaser Office Equipment & Supplies
Reseat transfer unit crum error 094-330
Just received our new transfer unit for our Phaser 6180MFP Printer/Scanner/Fax Machine. I have installed the new Transfer Unit only of the display to show Crum Error - 094-330 Reseat Transfer Unit. After taking the Transfer Unit In and Out a couple of times plus I have turned the printer on and off a couple of times the message still appears. Please Help!!
SOURCE: error message CRUM ID 093-693
please help with diagnosis of following error for Dell 5110CN CRUM ID -093-665
I tried everyting. I took the imaging drum out and poot it in, and notihng. This imaging drum worded before OK.
Tom
Posted on Mar 16, 2008
SOURCE: Phaser Imaging Unit install error
Worked like a charm! Thank you for the detailed information. The step by step instructions were right on target.
Posted on May 20, 2008
SOURCE: Imaging Unit Missing Error
Hi, I had the same problem. The following Cause and solution may help you fix your machine.
All refereces to left and right are facing the front of the machine as if for normal use.
The cause is due to the connector on thtop left rear of the imaging unit. this connector is mated with a coresponding, retractable connector in the body of the machine. When you open the cover over the top of the imaging unit, this connector retracts back into the body of the machine and when you close the lid it should re-engage with the imaging unit, The problem is that it dosen;t reconnect. I have asumed that it is due wear in the connector operating mechanism. This solution was effective for my printer.
Switch Off!!!
remove the topcover (after removing the colour catridges )and. remove the left hand side panel. You will see a nylon gear mechanism. Sqeeze together the nylon clip inthe centre of the gear wheel, and pull the gear about halfway off. This should allow you to move the vertical geared bar up 1 notch. .Push the gear wheel back on and try the machine to see if it works ok. All covers will need to be closed and if it works ok , reassemle the machine. Job done -about 10 to 15 mins. It tookme alot longer to find it,so some feedback would be appreciated.
Paul
Posted on Sep 15, 2008
SOURCE: Replaced Imaging Unit in Xerox Phaser 6200N
Do not know about not being able to remove the imaging unit but the problem with the printer wanting you to reinstall or reseat is a fairly common problem with this printer.
On the left hand side of the printer there is a nylon gear and rack that shoves the toner arms into the imaging unit. The rack and gear will sometimes strip and this causes the problem.
The solution is to take the left hand panel off the printer and realign the gear and rack. The gear pulls off and you can reposition the rack so that it is in the correct position.
Posted on Nov 09, 2010
MSG-CPC
  • 1325 Answers
SOURCE: Xerox Phaser 6180 doesn't like
hi
go to this link, you can view a video on hoe to install ink cartridge (near bottom of page after selecting link) .. also, you can search the same link to get some answer as to what the erro you experienced could be.
http://www.xerox.ca/office/printers/colour-printers/phaser-6180/sprt-enca.html
Posted on Jan 12, 2011
09-800 Invalid Toner Cartridge Message
Verify that you are using oem Xerox toner cartridge. If you're using an Oem Xerox cartridge and still getting this error it could also be the Crum Board, part number 140N63302.
Apr 11, 2013 | Xerox Phaser 3635MFP/X Multifunction...
Will not print in color
You can find answers to your Xerox questions at www.xerox.com/support
If the machine will copy in color it should print in color.
After verifying that it will copy in color, verify your driver is capable of being switched from black and white to color. If there are no color settings then you have the wrong driver. The link above will take you to the support page where you can download new drivers.
Mar 26, 2013 | XEROX MULTIFUNCTIONS Xerox Phaser...
Xerox phaser 6180 MFP displays errorr message and code BLK CRUM ERROR 093 925 restart printer problem occurred when a fax was being received
This error message points to either
1 A corrupted chip on the toner cartridge.
2 The wrong chip on the toner cartridge. There are several printers that take the same basic cartridge, the difference being the chip.
If you have just bought the cartridge, return it for replacement.
Oct 06, 2010 | Office Equipment & Supplies
Xerox phaser 7400 replaced yellow toner, but still getting replace toner error. I've reseated it twice, reseated the imagining unit and tried turning it off.
You can try do a NVRAM reset. If after that you still have the error message then I would tell you to contact the Xerox team as you might have a wrong consumable (defected/wrong CRUM) information.
NVRAM reset: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=36,E=0000000002092637520,K=9394,Sxi=5,Case=obj(3085)
May 16, 2010 | Xerox Phaser 7400/N Printer
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
Transfer Life Low Error on Xerox Phaser 6180
That error is caused when your transfer roller is out of life.
The transfer roller should be in front of the machine when you open the front cover. It will look like film material it is held with two plastic locks one on the right and on the left .
They maybe be colored yellow or blue sometimes.
(800)367-4836 <-company sells refurb and brand new ones. hope this helps. They will also give you free tech support.
Dec 23, 2009 | Xerox Phaser 6180N Laser Printer
Error code 117-363 printer starts machine is awake
only see error code 117-363 and not permited other option
Nov 26, 2009 | Xerox 6180MFP/N Printer
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
Xerox phaser 6250 NVRAM Failure
Cycle power, try cleaning the CTD (ADC) sensor and toner full sensor. This is what Xerox has to say about the NVRAM failure: On the front panel, press the key labeled i to view information about the error. Record the error code number. Turn off the printer. Reseat the fuser. Reseat the imaging unit. Reseat the toner cartridges. Turn on the printer. If the error continues to be displayed contact service. To be on the safe side you can follow the instructions here on the procedure to replace the transfer roler: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi Good luck
Mar 25, 2006 | Xerox Phaser 6250DP Laser Printer
127 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
