Question about Stihl HT101 Pole pruner
I CAN'T REMOVE THE SPLINED SHAFT FROM MY STIHL HT101 POLE PRUNER.
HOW DO I REMOVE THE SPLINED SHAFTFROM MY STIHL HT101 POLE PRUNER ?
    Sergeant:
  • 322 Answers
Take it to an authorized repair center. Not what you want to hear but its better that way. It is a complicated ordeal that if you aren't trained for you can do damage to the shafts
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Posted on Jan 18, 2013
STIHL pole saw 101
Hi Little Bird
Chances are that the clutch needs servicing or replacement.
Here's a link that explains:
http://www.lilredbarn.net/Stihl-HT-101-Pole-Pruner-Clutch-s/29554.htm
Cheers
Jun 06, 2016 | Stihl HT101 Pole pruner
Motor runs but everything above motor does not work. how do I take pole from motor?
Either the drive shaft has broken or come detached from the clutch drum at the motor end or the attachment end.
Here is the breakdown diagram http://www.mediafire.com/view/a33fr2038d5u1cr
Oct 16, 2015 | Stihl HT101 Pole pruner
Stihl ht101 blade stalls when slight pressure applied to bade
I'd say you have a fouled plug clean it up and regal it or replace
Feb 19, 2015 | Stihl HT101 Pole pruner
Greasing the drive shaft
yes grease the drive shafts. there is no greasing point, you have to remove the attachment and remove the inner shafts. Heres the manual, hope it helps
Feb 10, 2014 | Stihl HT101 Pole pruner
Changing drive shaft
You should be able to just pull it out, it just slides into the clutc drum. It be stuck from rust, speay some WD-40 on it an let it set for a while, also try tapping on the clutch drum lightly with a hammer as you pull on the shaft.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_a3dac712db4ca1a6
Jan 27, 2014 | Stihl HT101 Pole pruner
Stihl ht 101 spare parts list pdf
Stihl does not supply parts lists to the public. if you want one you will have to talk to a dealer in your area and see if they will be willing to allow you to look at one
Jan 20, 2014 | Stihl HT101 Pole pruner
Stihl pole saw trimmer is not pulling gas into the cylinder from the carburetor
could be a carb issue, a split in a fuel line, damaged intake boot or gasket
Nov 10, 2013 | Stihl HT101 Pole pruner
Stihl ht101bent pole
Replace bent pole, can cause serious vibration and can be a pain to extend. Send your email and i can send you the illustrated parts list. :)
Mar 02, 2013 | Stihl HT101 Pole pruner
Stihl HT101 Pole pruner Logo
429 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
