Question about HP LaserJet 4 plus Printer
Ghost images the pages have a ghost image down the middle of the page. it appears to be from the beginning of the page. i have changed toner carts, but i get the same results.
  • steve poeling May 21, 2007
    It does appear to be from the current page. I have not forced any prints through without paper. I would not know how. I will check the drum/roller for any obvious problems.
    Scholar:
  • 121 Answers
Is it from the most recently printed page, or is it the same image avery time regardless of what you print? It sounds like your drum or roller (I'm not sure about the exqact term in english) might be the issue. Have you somehow managed to "force" a printing without paper in the printer?
Posted on May 18, 2007
  • Christian Ramsvik May 22, 2007
    You might try printing a blank page to see if it gets the ghost impage. If it does, you might try printing several blank pages to see if the ghost will fade away.
    I am not an expert in laser printing technology, but I think it minht be a problem with the part that fuses the toner to the paper, or the part that transfers the toner from the drum to the paper. If either doesn't do it's job properly it might result in the kind of problem you have.
    Any error messages on the display, btw? You might try to print a self dignostics page to see if there are any messages about the roller or anything. If it has been frequently used parts might need to be changed.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
HP LaserJet 1020 PATCHES ON PRINT OUT
if the patches are random, and not ghost images duplicating down the page, you may need to take out the toner and gently shake it - tilt it right 90 degrees, then left 90 degrees, etc a few times to redistribute the toner...
failing that, the toner could be almost empty.
otherwise, check and see if they are duplicating down the page.. ie the same image defect 3 or 4 times down the page, if so, it is probably one of the drums.. toner or fuser drum...
Hope this info helps.
May 15, 2012 | HP LaserJet 2550L Printer
Ghost images of the same printing repeated down the page
Run a half test. While printing a few pages, open the cover, pull out the toner and look down at the paper. If you see the ghost images replace the toner. If you don't see the ghost images, replace the fuser.
Sep 11, 2010 | HP LaserJet 1020 Printer
My printer is leaving faint marks of other words down the side of the page...any way to fix that?
Yes, It sounds like a ghosting issue. Several components can cause a ghosting issue. The distance between the first occurance(the one on purpose) and the second occurance(ghost image) can determine the part of the machine causing the image problem
56.6mm - Fuser
54.5mm - Transfer Belt
75.4mm - Drum unit (1 of toner carts)
Dec 11, 2009 | HP Color LaserJet 2600n Printer
Changed toner cart. do to void in middle of print
My whole day, today, was filled with dealing with bad toner carts.
Even new genuine ones from HP
6 service calls., 6 bad carts.
Aug 19, 2009 | HP LaserJet 5p Printer
The document prints but leaves ghost images on the page also
A laserjet is different than a inkjet.
Ghosting is either the toner or the fuser:
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 25, 2009 | HP LaserJet 1020 Printer
Previous image repeats on next page
The problem is likely the fusing assm.
Print a test page
Hope this helps
Mar 24, 2009 | HP LaserJet 4200tn Printer
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
HP LaserJet 1012 Printer prints ghost images
I ran the hp toolbox "cleaning" mode too and it did not help the problem at all. I still have a dark smear concentrated in the middle of the page, and ghost images repeated lighter all the way down the page.
Aug 21, 2008 | HP LaserJet 1012 Printer
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
HP LaserJet 4 plus Printer Logo
260 people viewed this question
Clive
Clive
