Question about Beko Washing Machines
How do you change the carbon brushes on a beko washing machine?
    Sergeant:
  • 264 Answers
Fist turn machine off then pull machine out becarefull there is still two pipes you can turn the water off to the macine then undo it and undo the wast pipe under your sink some times once you have pulled the machine out you can see the back plate undo the screws and take it off then you are looking at the back of the machine you will see the silver wheel and belt at the bottom where the belt is is the motor take the belt off the sound be star or bolts holding the motor on undo them there might me two or for bolts or screws ok once there out you can pull motor off onece motor is off you will see two black plastic caps thats the bruchers holding on by two screws or little bolts dont for get two check what way the brush go's back in the way the carbo is when you take it out is the same way you put the new one in ok hope i have helped
Posted on Nov 03, 2012
SOURCE: samsung washing machine carbon brushes (b1215j)
yes i have this carbon brush
how can i send u this carbon brushes .
where u live and from?
my e-mail address is
identity_ahsan@yahoo.com
Posted on Jan 30, 2008
gittos73
  • 244 Answers
SOURCE: remove carbon brushes from bosch washing machine
u can sometimes tip the washer backwards and with a torch u should be able to see the carbon brushes and the 2 star screws which hold them in undue these screws and the carbon brushes will pop out very easily for u to change them m8
Posted on Feb 25, 2008
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
barkencoa
  • 3463 Answers
SOURCE: how to change brushes on beko washing machine
remove rear cover of washer, locate and remove belt.
Unfasten motor ,disconnet motor lead, and remove motor.
Brushes are located at opp end to motor pulley.
Replace if less than 5mm long.
Thanks
Posted on Jan 21, 2009
  • 42 Answers
SOURCE: changing the brushes on a beko washing machine
Its been a while since I changed beko but here goes.......... Put the machine on its side (soapbox side down, This prevents excess water from the soapbox dribbling into the PCB and creating a further problem). There is an opening at the bottom of the machine in which you will see the motor. On each side of the motor will be the brushes each with a connecting spay-tag, gently take of the spay tag with long nose pliers (not grabbing the wire) and change the brush. VERY IMPORTANT.....each brush is angled and it is important you replace the correct brush eg. left hand brush to left hand etc. or else when you goto wash the next time you will simply hear a bang and have to price a new motor. I highly recommend when you take each brush off do it slowly noting its angle and replace the new one at the same angle. Wfen done replace the spay tag. I am presuming you know to do this when the machine is fully powered off and plugged out. Happy Fixing.
Posted on May 07, 2009
My washer wont spin
Hi if your Beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor more Beko WME7247W test videos at site
Aug 08, 2014 | Beko WME7247W Washing Machine
Why wont it spin fast
Hi if your Beko washing machine has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
My washing machine wont spin
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Apr 12, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Water control valve washer
Hi carl if your Beko WM5140W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Mar 11, 2014 | Beko WM5140W
Beko wm5100 w won't agitate but is filling and empting
A week ago I had similar problem with beko wm3552m model (~ 10 years old). In may case was enough to replace the carbon brushes of the engine. It took me some time to figure out where they are locates, so I put some pictures on the net:
how to replace carbon brushes beko washing machine wm3552m
Jan 26, 2014 | Washing Machines
BEKO eco care WMA W10, replaced brushes still wont wash or spin,pls help
Hi if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Apr 08, 2013 | Beko Washing Machines
Beko wma 10w wont spin how do i change the brushes
Hi if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first. these videos should solve all your problems
Jan 21, 2013 | Washing Machines
Beko washing machine wont go into full spin
Carbon brushes on motor need renewing. Not terribly difficult job. Be sure to disconnect from power before attempting.
Feb 28, 2010 | Washing Machines
Drum does a small turn then stops but wont empty -wont wash either beko 1000 rpm
Hi if your beko 1000 spin washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Aug 23, 2009 | Washing Machines
Washing Machines Logo
132 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
