Question about NCR Computers & Internet
3Err on NCR-2114-1708
3Err will not go away and till won't work
98 Pontiac Bonneville intermitanly stalls & won't restart.
If you have a vats system (anti-theft) it needs to be reset
May 05, 2017 | 1998 Pontiac Bonneville
2008 Altima won't start or turn over till after 5 or more tries
may need to replace both the camshaft sensor, & crankshaft sensors, I believe that both are located near distributor/ & timing belt cover & top of engine.
Jan 30, 2013 | Nissan Altima Cars & Trucks
I cannot get my buttonhole function to work can you help?
check to see if you have a button hole lever to the left of the needle
the button hole won't work till it's pulled down
here's a link for a free manual to download
http://www.singerco.com/uploads/download/1228_3323s_talent_esf.pdf
Sep 08, 2012 | Singer 3323S Sewing Machine
No heat till you start driving and then fan will kick on and not shut off but it doesnt overheat
You won't get heat right away. The heat has to have time to reach the heater core. That's where you get the heat for the passenger compartment. But if the fan isn't turning off, then I would have it checked for an electrical problem.
May 05, 2012 | 1999 Dodge Caravan
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
Ncr cash register model 2114 3Err code
error 3 code on model NCR 2114 is a printer error meaning the printer cannot complete a print cycle caused by various issues concerning the condition of the printer
Nov 16, 2011 | Computers & Internet
I need USB drivers to allow communication between a pc running Windows XP and an NCR 7875-1000 flatbed scanner/scale. Please copy me at my work email address of james.clark@csi-posdata.com.
First I'd like to thank you for selecting my services. I've located the software for your NRC Scanner scale 7875. You can obtain firmware and related tools from http://www5.ncr.com/support/support_drivers_patches.asp?Class=retail_RealScan
As for the windows drivers they are available for you here http://www.digi.com/support/productdetl.jsp?pid=2628&osvid=57&tp=1&s=0&tp2=0
Select windows xp from the drop down list and then the 4002537_h is the one your looking for, version 5.3
I'll send a copy to your email address.
Let me know if you need further assistance.
Thanks,
Ekse (Niko Ohtonen)
Oct 07, 2011 | NCR 7875
How to replace points in distributer
Not sure what engine you are working with but to replace the points, just remove the screw(s) that hold them in the distributor and put the new ones in exactly where the old ones were. After putting them in, turn the engine by hand 'till the small rubbing block on the points is contacting one of the high spots of any of the bumps on the rotor shaft. Move the points till there is a 16 thousandths gap at the points contacts. (that number varies with each engine but 16 should get the engine started). It's good to put a small dab of grease on the side of the rubbing block that is away from the actual contacts to prevent the rubbing block from wearing and you should replace the condenser also. Make sure the leads don't touch the mount plate and ground or it won't work.
Jun 17, 2011 | Ford F-100 Cars & Trucks
Need to add an NCR 7837 to an NCR 7875
i lost my scanner installation disk for model NCR-7837, how can i get it to install?
Jan 15, 2009 | NCR RealScan 7872 (787220509090) Fixed...
Computers & Internet Logo
Top NCR Computers & Internet Experts
John Hong
John Hong
Are you a NCR Computer and Internet Expert? Answer questions, earn points and help others
