Brother printer how reset after changing ink absorber pads
    Sergeant:
  • 241 Answers
We have written a series of articles and videos on this very subject. You can read the most common reset here. There are however different resets for different kinds of printer, but these are also linked from this article.
Posted on Nov 02, 2012
SOURCE: How to open Canon iP3000 and remove absorber pads?
my computer see the printer as ip3100 & ican`t load my driver
Posted on Mar 12, 2008
CAM THE MAN
  • 20 Answers
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Posted on May 27, 2008
  • 49 Answers
SOURCE: Ink Absorber Replacement for Canon i70 Printer
Not easy for most people to replace or clean ink pads, but this will reset
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Posted on Jul 06, 2008
SOURCE: MP760 - how to disassemble? (waste ink absorber almost full)
You really don't have to disassemble it. What would be helpful tho is some sort of long needle-nose forceps. Tho I bet you could get by with a pointy chop-stick in a pinch. There are two waste-ink absorbers on the right, and one spongy thing on the left. With the 'hood' open, allowing you access to the cartridges, you should be able to see the pads. Get a Petzl light on your forehead, you'll need a lot of light! The sponge on the left is covered by a small clear plastic trough that channels the ink into the sponge below. With enough poking and prodding you should be able to get all these out, rinse with water, dry with a hair dryer, blot out the pad areas with a kleenex, and pop them back in. Good Luck!
Posted on Nov 14, 2009
pineworks
  • 4041 Answers
SOURCE: Where can I buy the waste ink absorber pads for both printers?
Hi
The waste ink are in the inside of your printer you need to get at it to clean out, but after this you got to reset it after you cleaned it or it will still not work, you may not have to get inside to clean it try this first to reset it.
Reset CANON PIXMA IP5000 printer To reset the counter or to find out about it’s reading you have to use the service mode.
Turn off the printer, push the resume button and keep on pushing.
Press the power button and keep on pushing. Now let go off the resume button,
but not the power button. Push the resume button twice, then let go off all buttons.
You are now in service mode.
To leave the service mode, give the power button one push.
Push the resume buttons once, after that the power button once.
The first information page appears.
Push resume twice, then power once: You get the second page.
Newer PIXMA-printers print the first page as a test for the nozzles.
The second page contains a lot of information.
Our advice: Print the second page before and after reset of the waste ink counter.
Only then can you be sure that the reset was a success.
To reset the waste ink counter right now, push resume four times and after that power once.
Important: Before starting with normal printing again, switch off the printer.
That gets you out of service mode.
Then switch on the printer again and print, as you like
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
Brother MCF-J4710DW says ink absorber almost full and won't print? Never heard of ink absorber. Where can I purchase replacement and how do I do it
Many ink-jet printers have a pad in the case to absorb the ink from cleaning cycles. Often these show "full" long before they are actually full, and you can reset the counter and continue using them. I found your answer here:
How To Reset Purge Counter on brother mfc j4710dw
Nov 02, 2014 | Brother MFC-J4710DW 35ppm 6000 x 1200 dpi...
Ink absorber full
This video shows you how to reset the counter so your printer will work again. However, it doesn't solve the problem of your absorber being full of waste ink. I recommend placing the printer on a towel in the event that the absorber overflows. This will avoid ruining the table your printer is sitting on.
http://www.youtube.com/watch?v=1NzJwuCpVOc
Here is the parts list if you wish to order the pad. It will take most of an afternoon and be very messy. Not for the novice. Your best bet is to reset the printer and use it until ink physically leaks out of the machine - then replace it.
http://support.brother-usa.com/ModelDocuments/Technical/Parts%20Manual/PM_DCP_J125_MFC_J220_J265w_J270w_J410w_J415w_J615W_J630W_EN_5179.PDF
If you do fix it yourself. You will need the following:
http://www.sparepartswarehouse.com/Brother,Printer,Part,LS4699001.aspx
http://www.sparepartswarehouse.com/Brother,Printer,Part,LS5136001.aspx
I have no experience with this vendor. It's just the first one that came up in Google that wasn't in the UK.
Apr 19, 2014 | Brother DCP-J315W Inkjet Multifunction...
Ink absorber is full
Here is a link to our purge counter reset guide. Please use this guide with caution as your ink absorbers may well be full and need replacing not just resetting.
http://www.refreshcartridges.co.uk/igloo/how-to-the-reset-purge-counter-on-a-brother-printer-with-a-numerical-pad/
I hope this helps solve your issue. If however you have any further questions please feel free to Tweet us @RefreshCarts or post on our Facebook pagehttp://www.facebook.com/RefreshCartridges
Aug 22, 2013 | Brother MultiFunction Center MFC-440CN...
Ink absorber is full and must be changed. Waste ink absorber is to be changed
You might want to try just resetting your printer rather than changing the ink pad. The warning is based on a count of how much printing is done, not a measure of full the ink pad has become. Consequences of not changing the ink pad, if truly filled to capacity, could be ink leaking from the bottom of the printer.
The following video show how to perform a reset that should work for your printer. The second video will give you an appreciation for how to change an ink pad and help you to decise whether you wish to attempt.
Trust this is helpful.
Dec 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber pad is full
You need to replace the waste ink absorber and then reset the counter. These can be obtained from some suppliers of ink and spares etc, otherwise you will need to contact Brother in your country or take the unit to a service engineer.
Generally when these errors occur the waste ink absorber needs replacing, if not your images will start to degrade in quality and you will start to see ink splays / splodges appearing as well as random spots and ink patches. In the mean time press RESUME /CANCEL to continue printing.
Oct 02, 2009 | Brother MFC-5440CN All-In-One InkJet...
What is a The waste ink absorberves
The waste ink absorbers on a Canon are a set of pads underneath the entire printer engine, they cover just about the whole bottom of the machine, on a Brother it's a replaceable box filled with absorber pads. Both have to be replaced by a shop to reset the counters and clear the error.
Aug 11, 2009 | Office Equipment & Supplies
Brother dcp-150c Clean Unable 46
If you actually changed the flushing box, you should know how to go to the maintenance mode and reset the waste ink counter. Info. that is only available to Brother techs.
Jul 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
Canon pixma MP110 waste ink absorber full
1 - Turn on the printer
2 - press MENù SCAN COPY SCAN (it will enter in service mode)
3 - select TEST MODE
4 - Select PRINTER TEST in TEST MODE
5 - Select EPROOM CLEAR
6 - Select INK COUNT
7 - Press OK
8 - Press the STOP/RESET key and then press the ON/OFF key
9 - Change the waste ink absorber in the printer
Oct 24, 2008 | Office Equipment & Supplies
Error 46 on a Brother MFc-8840DN
According to the Brother MFC 8840DN manual:
Machine error code xx: MFC has a mechanical problem
Solution: Call Brother customer service and tell them the error number
USA 800-284-4329
Remember to rate users who offer their expertise to you at no cost :)
Sep 29, 2008 | Brother Office Equipment & Supplies
15 people viewed this question
jasbo
jasbo
