What is a t-con board - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,424 Answers
T'Con board, otherwise called as Timing Control Board is one which converts digital signals from the main board to analogue signals that use to display picture in an LCD TV. Actually it is the driver board to LCD display. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 02, 2012
Jimmy shop.ccom has T-con board part #T500HVD0.0 500t10-C02 at the bottom in the description it list model PLDED5030A CRk my model is PLDED5066A-E since the parts # the same will it work in my tv?
If you see an image with a flashlight the T con board and power supply board are good. The back light controller board is the culprit.
Dec 18, 2015 | Televison & Video
The color is pink and green and blurred
either t con board or the lcd panel is faulty. Only can confirm which on by replacing the t con board.normally the t con board is a separate board in almost all the tvs. in some models its integrated to the panel , if so you have to go fora new panel.
check the links bellow to know more about t con faults .
http://electro-medical.blogspot.in/2015/11/lcd-tv-t-con-board-troubleshooting.html
Nov 11, 2015 | Coby Televison & Video
My TV has vertical lines
hi,
Probably the t con board is faulty. first you have to check is there is any bad contact in the connections on the t con board. Remove and reconnect all the connections on the con broad. if the problem exist even after that you have to go for a new t con board . in some tvs 32 the t con board is not replaceable as it is integrated to the lcd panel.
check the video it will help you to identify the t con board
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
www.electro-medical.blogspot.com
Sep 25, 2015 | RCA Televison & Video
My sanyo dp42849 screen still has a picture but it has turned white. What is the problem and how do I fix it?
Sep 25, 2015 | Sanyo Televison & Video
Vertical colored lines on entire screen, sound ok
Hi.
Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly.
Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad.
RCA L32WD22 T-CON BOARD UT-5531T03088-76J
Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to...
Sep 09, 2015 | RCA L32WD22 32 in. LCD HDTV
I have a 46" Sony Bravia TV that has colored verticle lines about 2-3" wide just left of center.
Yor tv have problem with T con board. T con board is one which drives the pixels of the LCD panel. If any of the driver satge in the T con board is faulty then this problem can occur.
Some times bad contacts on the connections of the t con board can cause same problem. Remove the tv and find out the t con bard. Remove the connections to it and the reconnect the connections. Then check, if the problem remains the same then the tv need a new T con board.
You have didn't mentaioned any model number of your tv. So it is not possible to show you exactly how T con board looks.
Normally in all lcd tvs the tcon board is place on the bottom or top middile position. Which will be cover with metal cover or aluminium foil.
Here I have added a link which will lead you to the picture of T con board for toshiba.( Not exact one)
T con
Apr 29, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How does a T-con Board works?
It is difficult to type in all here by this window, as it is too much. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 18, 2014 | Samsung UE40B7020 40 in. LED TV
Coloured vertical lines on right hand side of screne
T con
Ajin
Apr 01, 2012 | Toshiba Televison & Video
Left half my my screen has different color bars running vertically down it
Your tv have problem with the T con board. T con board is one wich drives the pixels in the LCD panel. There is no repair possible with these boards. You have to replace the T con board. Normally you can find the t con board in the top centre or the bottom centre of the tv covered with metal cover or aluminium foil.
Here i have added the link for T con board you can fin the picture of the board in the link
Ajin
http://www.ebay.com/itm/Vizio-M550NV-T-Con-3655-0022-0147-4A-0170-2372-0024-/280719517500?pt=LH_DefaultDomain_0&hash=item415c2fe73c
Feb 09, 2012 | Vizio M550NV 55 in LCD HDTV
My 42 inch LG tv keeps going very dark on 1 side of screeen. Any solutions?
This problem is most likely caused by the T-CON board. It could be a bad connection of the cable from the LCD to the T-CON board. or the T-CON board could be bad. Sometimes you can disconnect and reconnect the flat cable(s) to the T-CON board and solve the problem. Else you can replace the T-CON board.
The T-CON board is the board that drives the picture to the LCD screen.
Mar 01, 2011 | LG Televison & Video
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
