Question about Delta Saws
Are there replacement gears available for the Delta 911611 DC Gear Motor
The motor jerks as it is moving the feed belt on my stationary drum sander. I suspect that the gears inside the motor assembly are partially stripped.
protek480
  • 1714 Answers
SOURCE: my delta 31-250 sander dc drive motor will not
Did the DC drive give you a fault code? It may have tripped on a current over load. Needs to be set to handle load.
Posted on Jun 30, 2009
  • 376 Answers
SOURCE: Huskee jerks while going forward
Go to... http://mtdparts.arinet.com/scripts/EmpartISAPI.dll?MF&App=MTD&TF=Empartweb&Lang=EN&searchDB=MTD&loginID=MTDCon&LoginPWD=&xmlPostDest=http://www.buymtdonline.com/webapp/wcs/stores/servlet/processShoppingCart_10101_19502_-1_19502 Enter the brand (Huskee) and model number, not the one you listed, but the one under the seat... hit search and click on illustrated parts, then click on Mower Deck. That will show you the routing and belt number.
Posted on Jul 06, 2009
  • 188 Answers
SOURCE: Motor runs but blade does not move. sounds like
It sounds like the spocket gear is stripped, the smaller gear drive may be stripped also. You will need to replace these parts. You can order them online at www.masterparts.net. The part should be listed in your owner's manual. If you do not have an owner's manual you can give your model number and I can try to find a copy for you. They also may have a parts break down Master Parts website. I hope this helps you!
Posted on Jul 17, 2009
  • 92 Answers
SOURCE: Gear after the motor is stripped
yes it can
Posted on Aug 28, 2009
  • 8404 Answers
SOURCE: Officemax OM96580 has a stripped gear tooth on the
If you expect to repair this, expect to spend weeks waiting for parts if you can get them at all, at least an hour to do the work and expect to spend 2/3 the price of a new one for the parts.
My advice, my friend, save the collection can, discard the shredder. On your new shredder, dont over feed it.
Thanks
Posted on Oct 14, 2009
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
How to fix motor delta belt disc sander
What is it doing or not doing, when u turn on the switch, either the switch or motor is probably bad or you have too much tension on the belt.
Aug 22, 2014 | Delta 31 695 6" Belt/9" Disc Sander
Delta 31-250 saander dc drive motor doesn't work
You have probably tripped the breaker for the drive motor. If you have the manual, it shows you the location of the reset button on pg. 20. The reset is a small white button above the drive switch. You can download the manual from this link: http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&ved=0CG8QFjAJ&url=http%3A%2F%2Fwww.redmond-machinery.com%2FManuals%2FDelta%2FDelta%252031-250%2520-%2520OM.pdf&ei=VfcfUba3FYeXyAHGrYFI&usg=AFQjCNGcOLvprmIo_af4ofEd10DBnJ7ocQ&bvm=bv.42553238,d.aWc
Dec 10, 2012 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
My delta sander stalls while sanding on the belt.
Mine was underpowered from the get go. I have since sold it. Keeping it well lubricated does help though.
Jan 23, 2010 | Delta Machinery 4x6 Belt/Disc Sander
Drive Belt broken
the part number for the poly v belt is 406131330004 and you should be able to buy it direct from Dewalt at their website or find a local dealer thru their locator and or service stations listed there.
Nov 15, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
31-255-x need brushes for belt drive motor cant find on internet any recomendations?
Go to toolpartsdirect.com they have your sander listed and all parts that are available for it.
Oct 12, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Motor runs but the drive drum that hold the sanding belt does not turn.
Instead of removing the drum, remove the belt and the cover over the gearbox. The gearbox cover is normaly fixed in place by screws around the drive pulley. There may be a couple of screws under the pulley, if so they can be accessed via holes in the pulley wheel itself. Check for worn or stripped gears. These gears can be replaced if need be, but if this is the case make sure you remove and clean out all the grease first and replace that aswell as it may contain bits of teeth that have come off the faulty gear. As far as I know belt sander drive rollers can not be removed without removing the drive inside the gearbox first.
Oct 27, 2008 | Dewalt Factory-Reconditioned DeWalt DW432R...
Saws Logo
138 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Delta Saw Expert? Answer questions, earn points and help others
