Question about Epson Office Equipment & Supplies
Replace Ink Pad in Epson Discproducer pp-100AP
  • John Smith
    John Smith Jun 02, 2015
    For PP-100 waste ink pad reset use WIC utility.
    Problem Solver:
  • 8 Answers
Previous answer has no relation to PP-100.
It is for desctop printers.
But for Epson PP-100 reset you have to use WIC Reset Utility and reset Waste Ink Pad Counters in Epson PP-100 Disc producer by 3 clicks.
Here is video tutorial how to reset waste ink pad counters in PP-100 - http://pp-100.com/reset.shtml
Posted on Jul 11, 2015
    Sergeant:
  • 242 Answers
Here's 3 things you can do to get around this...depending if your printer is new and still under warranty or not (do NOT void your warranty!).
I have used all 3, but the third one was a lifesaver (AND money-saver!). About once a year I have to reset the printer using #2, but other than that....#3 is the greatest!!!
1. Try resetting it by, unplugging the power cord then while holding down the POWER STOP and MAINTENANCE buttons simultaneously while replugging the power cord caused a reset to zero on the counter. You will still have to replace the pads or redirect the waste ink tube to a receptacle on the outside of the printer, hope this helps?
2. If you go to inkjetprinterhelp.us there you will find the ssc service utility. Once you open the page click on the service utility and then choose the english version unless you can spk russian.If you then scroll to the bottom of the page and install the prog. Once you have installed the prog you will get the ssc utility logo in your bottom tray. Right click the icon and then select reset protection counter from the protection counter drop down. Once you have done this restart your computer and this should reset the system.
3. INSTALL AN EXTERNAL WASTE TANK and forget all about those gunky ink pads forever!
On the left rear of these printers is a small trapdoor held by a single screw.
Remove it, look inside (down and to your left) and you'll see the waste ink tube.
The tube is free at one end, and with a suitably curved piece of wire you can hook it and wangle the end out through the opening (you may dislodge a small piece of plastic in the process -- just put it back where it was, it's only a vibration damper.) I found the tube to be rather short....so I added an extension since I do not have room directly behind my printer for a container. I used the tubing you use with oxygen tanks or fish tank bubblers. They also make a little plastic connector so you can join the two together.
At this point, you're almost there.
All you need now is a suitable container for the waste ink, and I drilled a small hole in the trapdoor cover so you can put it back on without pinching the tube (or you could just leave it off.)
The container is a small square one with a snap-on lid, approx. 60mm square and holding about 150ml -- they're sold in sets of three for a few cents and are for making ice-blocks etc. in your freezer. Any small container will work.
Make a hole in the lid (slightly larger than the tube to let air escape) insert the tube and forget about the internal pads forever.
I've had mine in place for almost 2 yrs now and it works like a charm. If you need photos, let me know and I
Posted on Jun 02, 2015
  • Binoj Daniel
    Binoj Daniel Feb 26, 2018
    Can you post some pics for the step 3 fix?
Lonewolf1038
  • 6 Answers
SOURCE: epson stylus photo r320 ink pad relacement
I've had mine in place for almost 2 yrs now and it works like a charm. If you need photos, let me know and I have a couple I can send you.
Posted on Jul 01, 2008
jonniewalker
  • 1031 Answers
SOURCE: waste ink pad
to Reset Waste Ink Counter
  • RUN AdjProg.exe file Epson C90
  • choose Particular adjustment mode
  • select waste Ink pad counter
  • Klikinitialization
That’ all!
Posted on Jun 01, 2008
Nic61
  • 1073 Answers
SOURCE: Epson rx620-waste ink pad replacement Instructions
No Problems M8!
Here is the manual for your printer
http://files.support.epson.com/pdf/rx620_/rx620_qr.pdf
Good luck to you
If you find my answer helpfull, dont forget to vote!
Posted on Dec 18, 2008
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
websnail
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
How do you replace the ink pad on an Epson PP-100 printer
You just have to first open the cartridge point and then open it very calmly not in haste. After that you just know the procedure. If u still persist with the problem then connect at Epson Printer Support Number 1-800-243-0019 which is toll free.Get assisted for your issue within a short span of time.
Aug 30, 2017 | Epson Office Equipment & Supplies
How do I reset the waste ink pad on my Epson Discproducer PP-100
The most easy way to reset Epson PP-100 Waste Ink Pads is to use WIC Reset Utility and reset waste ink counters by Yourself.
There is video tutorial on Youtube - How to reset Epson PP-100 Waste Ink Pads Counters:
Jul 03, 2014 | Epson Office Equipment & Supplies
How do I reset waste ink container in epson pp-100
To reset Epson PP-100 Waste ink pads - You have to use WIC utility. Watch the video tutorial how to reset Epson PP-100 waste ink pads by Yourself:
Reset counter on epson pp100
go to PP-100.com site - there is full solution for epson pp-100 reset
Feb 20, 2014 | Epson DiscProducer Disc Publishing System...
Ink pad counter reset
I'm not sure from your post exactly what the issue is? Please explain problem in more detail!
Jan 16, 2014 | Epson DiscProducer Disc Publishing System...
Epson discproducer pp-100 ink pad
If You want to reset Epson PP-100 Discproducer Waste Ink Counter You can use WIC Reset Utility and reset it in few clicks.
You can watch video how to reset PP-100 waste ink counters -
Jan 16, 2014 | Epson Office Equipment & Supplies
Epson Reset pp-100
You can use WIC utility to reset Epson PP-100 waste ink pads by Yourself.
Video tutorial:
Nov 17, 2013 | Office Equipment & Supplies
I have a new computer with windows 8 and I cannot get the Epson pp-100 software to load what is the problem
Highly likely the PP-100 software is not compatible with Windows 8.
You could try running it in compatibility mode so that it runs as if it's a Windows 7 application.
To do that you would need to:
  1. Right click on the program launch icon
  2. (left) Click on "properties"
  3. Choose the "Compatibility" tab
  4. Tick the "Run in compatibilty mode" box
  5. Choose the appropriate operating system
  6. Tick "Run as an administrator" if the option is available
  7. Click "Apply" and then "Ok"
Then try running the program.
If it still doesn't work you'll need to contact Epson support to find out if there is a hotfix or new release for the software that will provide compatibility.
Aug 06, 2013 | Epson PP-100 Discproducer Disc Publisher...
3,159 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
