Question about Microsoft Word 2010
Table Caption Problems
I am trying to caption a set of tables that are in an Appendix. The format I need for the caption is: Table C5-1. Title of Table Here. I also need to sequentially number the tables after the first one as C5-2., C5-3., C5-4., etc. I can't figure out how to do this. Help!
Select the first table.
Right-click on it and choose: Insert Caption
In the Caption dialogue, Click on New Label...
Type in "CS - " (without the quotes)
Click OK
The caption should appear beneath the first table.
Select the second table.
The dialog should contain the same caption as the first, except the number will be incremented by one.
Repeat to the end of your tables.
Format captions as desired.
Posted on Jun 30, 2014
3 Suggested Answers
  • 20 Answers
SOURCE: Table of Contents TOC 4 appears with heading numbers in bold
Click on FORMAT, then STYLES AND FORMATTING. Select the TOC 4 style and un-select BOLD in the text option. This should solve this issue. :-)
Posted on Apr 30, 2010
ngwasuma
  • 75 Answers
SOURCE: Using Microsoft Access I'm creating a database to
The easiest way to achieve your goal, would be to use a second interfacing application to hand the database operations. I suggest VisualBasic.
Posted on Sep 07, 2010
Panasonic viera cc
Try identifying which caption is from the TV and which is from the cable box by turning the TV Closed Caption on and off while you have to sets of captioning. This will show you which closed caption never turns off.
Aug 08, 2013 | Televison & Video
How do I make the closed caption bigger. It has a black background and white letters that are too small. How do I fix it?
I suspect it depends on the TV. On my Viewsonic TV, I can select my CC font by choosing Menu > Option > Closed Caption. When the CC is set to On, go to Option and select Font Size.
On a Samsung TV, I use Menu > Setup > Caption. With the Caption set to on, then choose Digital Caption Option and Size.
Note if the captions are being provided by a set-top box, you may need to set the caption size on the box directly.
Please add a comment with your TV manufacturer and model; I'll try to find the specific directions for your TV.
I hope this helps.
Aug 12, 2011 | Televison & Video
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
I do not know how to turn off the closed captioning on my son's orion tv set. I do not know the model type. I do know that closed captioning options are not on the menu.
If you have the original remote look for a button labeled "CC" or "Caption/Text" press this button till the screen says caption off.
Jul 06, 2009 | Televison & Video
Black square in center of screen - no "closed caption" solution
Here are the steps from the owner's manual:
1. Display MAIN MENU. Press ACTION key on remote.
2. Display SET UP TV screen. Use arrow keys to select TV icon and press SET key.
3. Display CAPTION screen. Use arrow keys to select CAPTION and press SET.
4. Select CAPTION MODE. Use arrow keys to select CAPTION MODE. Press SET to cycle through caption settings until it says OFF.
5. Press ACTION key three times to return to normal screen.
You can download the manual from Panasonic here if you need a copy.
Apr 03, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
How to connect vb with ms access
se Adodc OR Even better.. ADODB. for this you need to get MDAC fromMicrosoft free download.(check under project_References- Microsoft DataActiveX objects.. the current no is 2.8. if it is not there download invb directory.
next, you can learn about creating a DSN from control panel, ODBC. onceyou learn this, connection becomes a piece of cake. get some free vbtutoriasl from WWW.
then
you need to use DAO or ADO to connect to the database. better study both but since ADO is current, i am showing that code.
under Menu Project_References, put a check mark on Microsoft ActiveXData Objects latest version (though it works for all, currently 2.8with sp pack 1 ).
at the general declarations:
dim conn as adodb.connection, rec as adodb.recordset, esql as string,esql1 as string
Private Function connect()
Set rec = New ADODB.Recordset
Set conn = New ADODB.Connection
esql = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & "D:VBDesigndhana2.mdb" & ";Persist Security Info=False"
'here you put the correct path of your mdb file. and check if you have jet 4.0
conn.Open (esql), , , 0
End Function
private sub form_Load()
connect
end sub
and for adding records:
say let us say you have 3 fields. then have 3 textboxes and 1 command button on the form.
private command1_click()
esql1="select * from Yourtablename"
rec.open(esql1),conn,, adOpenDynamic, adLockOptimistic
rec.AddNew
rec.Fields(0) = text1.Text
rec.Fields(1) = Text2.text
rec.Fields(2) = text3.text
' you need to check if in your access table design you have Allowed Zero length .. set it to Yes for all text fields.
rec.update
if not rec.eof then rec.movenext
rec.close
conn.close
set conn to nothing
end sub
this will add new records to access table from VB.
' for picture store the full path of the path and the picture file nameint the text field. and in the picturebox of VB form for viewingrecords again you need ADO or ADODC and here you code:picture1.picture=Loadpicture(rec.fields(3) ' depending on where thepicture field is located. you need to make a few trials.
End Function
connect
end sub
and for accessing records:
esql1="select * from Yourtablename where id =" & val(text1) ' for integers
esql1="select * from Yourtablename where name=" & "'" & text1 & "'" ' for string
rec.open(esql1),conn, adOpenstatic, adLockreadonly
label1.caption =rec.Fields(0)
label2.caption= rec.Fields(1)
label3.caption= rec.Fields(2)
rec.close
conn.close
set conn to nothing
end sub
' similarly there are routines to ADD, Delete, Edit, View etc.
Feb 26, 2009 | Computers & Internet
Close captioning is always on when playing DVDs.
I believe you have to turn the caption off on the DVD. Some dvd's automatically start with caption title. Check the manual for the DVD again.
Feb 15, 2009 | Insignia IS-LCDTV32 32 in. Television
Vb6 source code is not compiling.
What the heck are you compiling it with that doesn't give a line number for that error? Pay attention to the titles of messageboxes! Perhaps noting what lines you changed from the original will give a clue to narrow it down, but I expect you addressed an object with a property (object.property) in a context that can't be expected to generate or use that property as you gave it. Moreover there are spaces in object names, it seems....
Apr 13, 2008 | Computers & Internet
Close captioning
Well lets try the simple things first, Go to the TVs menu using the original TV remote and find the icon or menu that says Captions, in that menu turn all the closed captions OFF. Second there is a button on the original TV remote that says format, push this till you get to a screen that says FULL in the upper left corner. That should resolve your problems, If closed caption still comes through then we need to know if this set is hooked directly to cable or goes through a cable box. It sound like you simply had the closed caption turned on and the screen in one of the zoom formats this TV provides
Mar 07, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Microsoft Word 2010 Logo
97 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
