Question about Lands Phones
Instruction manual on a nortel network phone/ntmn33fb70
I need to know what each button mean
SOURCE: Changing time on Nortel networks Phone system
Sorry, the tester012 was an accident, so I wanted to repost in case there were more questions on this.
The answer still stands for most Nortel PBXs:
To set the time and date of your system you program in load 2:
Step 1) LD 02
Step 2) STAD "Day Month Year Hour Minute Second"
i.e. STAD "24 11 1976 15 41 49" =
November 24th 1976 3:41pm 49 seconds"
To test it...
Type: "TTAD" - (this tests time and date)
But I also wanted to clarify that it is in the manual, but since there are multiple manuals with a Nortel PBX, that you need to look in the LD (or Loads) in them. This particular one is found in LD 02.
Another site to check out for a crash course in LD for Nortel (in case you have similar issues that you need assistance on) is this one here:
http://www.pbxinfo.com/meridian-systems/16288-meridian-crash-course-programming-guide.html
I hope this has been helpful, again I am sorry for not having logged in properly to be notified on more explanation when I posted Solution #1.
Posted on Dec 02, 2008
SOURCE: How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Posted on Mar 12, 2009
Vit Avaya BP
  • 211 Answers
SOURCE: Norstar phones compatible with NEC phone system
This is simple.
The answer is no.
Each company uses its own voice encoding and technologies...
Nortel will only work on Nortel phone system.
Cheers
Posted on Jun 24, 2009
SOURCE: Nortel Meridian M5009 - reprogramming buttons on the phone
I am the new admin. How do I change the name displayed on the admin phone?
Posted on Mar 26, 2011
  • 277 Answers
SOURCE: How do I set up music (radio from my pc) using headphones on my Nortel Networks phone, model #NTDU91? Is there a feature for that? Thank you
You should call in your local vendor and have this done.
They will need to install a jack that matches your headphone jack and punch it down to a certain pair on the phone system, they will also need to go into configuration programming and set the feature.
Config password and knowledge of wiring and programming required. Note you need to purchase a license to "re-broadcast" music on phone systems, paging equipment etc.
Canada license - http://www.socan.ca/licensees/faq-licensing
USA license - http://www.ascap.com/licensing/
Penalties:
The Penalties
Under U.S.C. TITLE 17, the law allows copyright owners to receive as damages for infringement between $500 and $100,000 for each work infringed
Posted on Nov 06, 2012
How do you transfer a call on a Nortel t7208?
This is usually programmed as one of the 'soft' buttons down the right hand side of the device - subject to the programming of your phone / and the system.
Usually the T7208 is connected to the BCM range of PBX systems - in which case, to transfer a call, you'd use Feature 70. You could, of course, program this into one of the buttons yourself, so you only have to press one button to do so.
Hope this is of use to you. :)
Oct 29, 2013 | Nortel Lands Phones
Turn off the auto attendant for the Nortel Phone System
To turn off the auto attendant:
Press the program key. The display will indicate:
PLEASE SELECT
PNON ANSW OTHER
Press the key under ANSW. The display will indicate:
AUTO ATTND: ON
BACK CHANGE NEXT
Press the key under CHANGE. The display will indicate:
AUTO ATTND:OFF
BACK CHANGE NEXT
That's it. Now press the program key to finish. If you need more detailed instructions, please follow the user manual: Nortel pdf manual
Oct 28, 2013 | Nortel Computers & Internet
How do I reset my phone system? Nortel Norstar
It's simple.
On Vmail it's Ftr 983 -> pswd -> 1 -> reinstall -> yes
On MICS it's pull the power plug off and within 15 minutes -> Ftr** -> startup -> pswd
To be sure follow the users manual instructions. You can get the pdf user manual here: Nortel Norstar pdf manual
Sep 17, 2013 | Nortel Norstar Compact ICS 6.1 Software...
How do i program ip 2033 on nortel system
when you plug it in, and the Nortel logo appears on the screen, swipe the three buttons that are under the display, with your finger, and that will get you into programming.
you will select following
Manual DHCP config? yes
Partial? yes
enter the IP address of your system
for port #: enter: 7000
retries: enter 5
for the rest of the programming select "0" till the end
Aug 23, 2010 | Nortel Networks IP 2033 Audio Conference
This is simple.
The answer is no.
Cheers
Jun 23, 2009 | NEC Lands Phones
How do i set up a voice mail greeting on my nortel phone?
bodell,
The short version of getting to your greeting is:
Feature 981 or open voicemail key
your password
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
hope that helped.
Jan 15, 2009 | NorStar T7316E Corded Phone
Ringer
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Let me know if this works for you.
Sep 03, 2008 | Nortel T7316E 2-Line Corded Phone
Saeco Easy Expresso Maker Instruction Manual
You have it on e-mail:-)
have a nice day
/Mirran
Aug 19, 2008 | Saeco Easy Espresso Machine
Changing name in nortel T7316E handset
We would like to change the name displays on our phones
Mar 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Lands Phones Logo
48 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
