Question about Mini Tools & Hardware - Others
I am trying to inflate flat tire and can't get it to inflate with air master air compressor 59008. what am I doing wrong?
I have it plugged into cigarette lighter and the truck motor is running. I connected it to the tire and have the quick release nozzzle lever down. Still the tire is not inflating.
Jack the car up on the side you want to inflate to get the weight off of it. No compressor that i know of that plugs into a cigarette lighter is strong enough to inflate a flat tire under that much weight.
Posted on Dec 19, 2012
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: not producing much air volume
I have checked on t his tool before and they don't offer replacement parts as of that date. I would suggest going to Dewaltservicenet.com and typing in your model number for a copy of the owners manual and they also have a toll free number that you can call for assistance.
Posted on Sep 09, 2009
rowdy45176
  • 2176 Answers
SOURCE: i have a black and
could be a bad valve in the tire or a bad valve stem. It should seal shut when the hose is removed.
Posted on Aug 08, 2011
Left rear tire is flat and not seated on the rim
If the tire is not damaged and will hold air then you may be able to reseat the tire. One method if you do not have proper tools or do not want to go to a tire shop is to lubricate the sine of rim with a dish soap solution to make it slippery. Take a ratchet holddown strap and run it around the tire and tighten it to force the beads of the tire onto the rim. Then use a compressor to inflate the tire and the beads should snap back onto the rim. Once that is done, remove the strap, remount the tire on the tractor and inflate to the proper level.
Oct 02, 2016 | Garden
MY COMPESSOR GAGE SHOWS 135 PSI AND 135 ON THE OUT PUT GAGE BUT I CAN,T INFLATE MY MOTORHOME TIRES TO THE REQUIRED 110#.DO I NEED A LARGER COMPRESSOR?I CAN,T FIND ANY LEAKS.
It is possible that the compressor psi as it is running drops below the tire psi creating a standoff. You must maintain air compressor psi over 110 to fill a tire to 110psi. Add air to your tire but stop when the compressor motor starts to run. When the motor stops then continue to add air until the compressor motor starts and again stop airing up the tire. Repeat as needed.
Dec 25, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Mt tire in the front poped and I can not inflate it?
Do you have a tube it the tire? if you don't, pull the wheel off and lay in flat on the ground, put pressure around the tire at the rim edge and begin to pump with a compressor. A regular hand pump is hardly sufficient. You may even try standing on the tire edge while pumping if you can't get enough of pressure with the hands. The point is to push the tire inward to prevent air bypassing while pumping.
Oct 03, 2010 | Garden
Can't get a bead on tire
Hey mate,
The problem in you are not getting enough air flow past the valve its restricting all the flow into the tyre!!!
With your valve stem, remove the valve with a valve removal tool, then you will get no restriction of air flow also use a hand air gun instead of tyre inflator this should pop the bead on then it will go down again, reinstall the valve (you can put some spit/saliva on the valve for a good seal) then use a tyre inflator and pump it up to the desired pressure...
Regards
Brad:)
Sep 22, 2009 | SK Garden
Air preassure in victory scooter
Most electric mobility scooters with inflatable tires require a tire pressure of 30-35 psi (be sure to check the manual of your scooter for the correct tire pressure). Do not allow the tires to become under-inflated or over-inflated. Under-inflated tires could make the scooter unstable and over-inflated tires can burst under pressure. Also, you should manually inspect the tires periodically to make sure they haven't taken any serious damage that could lead to a flat.
Jun 15, 2009 | Pride Mobility Victory 3 Wheel Electric...
Craftsman 30'' mower front tire off rim can't put back on
hello...is the tire loose but still on the rim...the sidewalls no longer engage the rim tight to hold air but still aroung the rim loose....If that's the case, get a jack, can of fix a flat, and a small ratcheting hold down strap.....jact the tire off the ground.....wrap the strap around the tire and ratchet it tight to get the beads of the tire to touch the rim....then commect the fix a flat or, if you have ,,,air from compressor to inflate the tire,,,,might have to work it a little to get the tire to reseat on the rim....this should work for you....once the tire is seated on the rim....stop inflating the tire until you remove the strap or you migh have a problem getting it to release from the tire if fully inflated....
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tire maintenance
Check your tire air pressure at least once a week and before long trips. Be sure to use an accurate pressure gauge. -Check your air pressure when the tires are cold. The tires are cold when your motorcycle has been ridden less than a mile at moderate speed or after being stopped for three or more hours. -If you must add air when your tires are hot, add four pounds per square inch (4 psi)(28 kPa) above the recommended cold inflation pressure. Recheck the inflation pressure when the tire is cold. -Never release air from a hot tire in order to reach the recommended cold tire pressure. -Normal riding causes tires to run hotter and inflation pressure to increase. If you release air when your tires are hot, you may dangerously under inflate your tires. -If your tires lose more than two pounds per square inch (2 psi)(14 kPa) per month, the tire, the valve, or wheel may be damaged. Consult your local dealer for an inspection. -Use valve caps to keep valve cores clean, clear of debris and to help guard against air leakage.
Nov 10, 2008 | 2006 TN'G TS 250
Tools & Hardware - Others Logo
76 people viewed this question
Top Mini Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Mini Tool and Hardware - Other Expert? Answer questions, earn points and help others
