Question about Linksys Wireless-G WRT54G Router
Can't find my "wep" key so my laptop can access the security encripted house computer
Wireless network name is : ZY0678
  • 2,878 Answers
Posted on Nov 02, 2012
Testimonial: "The correct answer was to leave the username blank and use "admin" as the password. This did indeed enable me to access the page that allowed me to recover (or re-generate) a wep key that allowed my laptop access to the house desktop computer. Thanks so much!"
SOURCE: Network Key
try to access the set up page of your router... go first to the command prompt and type in IPCONFIG then if youll get a valid ip add type in on the address bar 192.168.1.1.. admin is the password. on teh set up page pls clink on wireless then security... just change your password but be sure to remember it,
Posted on Jan 21, 2008
  • 3 Answers
SOURCE: having trouble adding computer to wireless network
this is just easy.. what you should type is the encryption key only... if your security is wep, only the encryption key or key 1 is needed. if your security is wpa, only the passphrase is needed.. it is very CASE SENSITIVE.. but if you see that the name has changed to LINKYS_SES, then you have a problem there because your wireless settings has changed due to the button on your router which is the secure easy set-up on the upper left corner which is the cisco button.
Posted on Feb 21, 2008
  • 132 Answers
SOURCE: Can not remember or find network security key
You may need to access the router's setup page to check the security key or the network key you have set up to the router. To do this:
  1. Launch IE and type 192.168.1.1 on the address field using a computer that is wired to the router. It is the default IP address of the router. It will then ask for a username and password. By default, there is no username and the password is admin.
  2. Once you're in the router's user Interface, click Wireless tab. There is a sub-tab under Wireless which is called Wireless Security. Click on it.
  3. There you will find the type of wireless security you have enabled in your router as well as the network key.
Hope this helps!
Posted on Nov 22, 2008
ziraffa
  • 827 Answers
SOURCE: Not prompted for network security key
You could try just typing in www.routerlogin.com and entering your router password.. (my default is 'admin' for user and 'password' for password) and then go into the Wireless section, or the Security section and enable WEP with whatever password you will remember easily.
If in doubt, you can Restore Factory Settings and that'll clear any encryption or MAC filtering you might have set up, then you can start with a clean slate, and enter your new router username/passcode and your wireless encryption password and write it down somewhere safe!
Chris (ziraffa)
Posted on Jan 01, 2009
RickOz
  • 145 Answers
SOURCE: Cannot get a second computer on my secure wireless network
Have you set the properties on the second computer to match the security expected by the router? Since one computer works I would compare the settings for the network connection and set the second computer to the same.
Posted on Mar 15, 2009
Can't find WEP key for my Belkin router
The WEP key is in the router's wireless setting.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 01, 2013 | Computers & Internet
What is my SSID #
The SSID is the router's wireless network name.
Network security key
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Apr 27, 2012 | Westell Wirespeed Computers & Internet
I HAVE A IBM R40 WITH INTEL/R1 PRO WIRELESS LAN 2100 3B, IT CANNOT CONNECT TO MY ROUTER WITH WEP OR WPA ENCRIPTION
Check to see the wireless LAN card driver is enable and working, if not reinstall the wireless driver.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jul 01, 2011 | IBM ThinkPad R40 2897 Notebook
I got a new laptop and am trying to connect to the internet, but it is asking me for the Network Security Key. I don't know where to find it. Can you help??
Network security key is a encryption key.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Apr 16, 2011 | Belkin Computers & Internet
I have bought this equipment, and i wish to make a secure connection and add other laptops and computers. but everytime i do so, i loose the connection, i wish to use the wi-fi protected set up
If you want to use secure wireless connection just use WEP or WPA security encription for wireless. Protected set up does not do this. This is for in house laptop connections. In the wireless tap of your netgear choose manual set up or wireless security option and then choose WEP or WPA option. You will have to make a key and put this key in to every wireless device in house. Hope this helps.
This is a link to manual for your router.
http://www.upc.nl/pdf/upc-handleiding-netgear-wnr2000.pdf
Mar 13, 2011 | NetGear WNR2000 Wireless Router
How to secure my internet connection via smc router
If you plan to have a wireless network, you should set it up so that only people you choose can access it. Here are a few options for wireless network security.
Wired Equivalent Privacy (WEP)
WEP is a widely used network security method. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. The receiving computer needs the key to decode the information so that it's difficult for someone on another computer to get onto your network and access files without your permission.
Wi-Fi Protected Access (WPA)
WPA was created to improve the security of WEP. Like WEP, WPA encrypts information, but it also checks to make sure that the network security key has not been modified. WPA also authenticates users to help ensure that only authorized people can access the network. If your networking hardware works with both WEP and WPA security, we recommend that you use WPA.
There are two types of WPA authentication: WPA and WPA2. WPA is designed to work with all wireless network adapters, but it might not work with older routers or access points. WPA2 is more secure than WPA, but it will not work with some older network adapters. WPA is designed to be used with an 802.1X authentication server, which distributes different keys to each user. This is referred to as WPA-Enterprise or WPA2-Enterprise. It can also be used in a pre-shared key (PSK) mode, where every user is given the same passphrase. This is referred to as WPA-Personal or WPA2-Personal.
802.1X authentication can help enhance security for 802.11 wireless networks and wired Ethernet networks. 802.1X uses an authentication server to validate users and provide network access. On wireless networks, 802.1X can work with Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) keys. This type of authentication is typically used when connecting to a workplace network.
IF THIS ALL DOSEN'T WORK TRY THE FOLLOWING:
Wireless network security recommendations
If you have a wireless network, there are some additional security precautions that you should take.
Use a network security key
If you have a wireless network, you should set up a network security key, which turns on encryption. With encryption, people can't connect to your network without the security key. Also, any information that is sent across your network is encrypted so that only computers that have the key to decrypt the information can read it. This can help avert attempts to access your network and files without your permission. Common wireless network encryption methods are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA) and WPA-2.
Change the default administrator name and password on your router or access point
If you have a router or access point, you probably used a default name and password to set up the equipment. Most manufacturers use the same default name and password for all of their equipment, which someone could use to access your router or access point without you knowing it. To avoid that risk, change the default administrator user name and password for your router. Check the information that came with your device for instructions about how to change the name and password.
Change the default SSID
Routers and access points use a wireless network name called a service set identifier (SSID). Most manufacturers use the same SSID for all of their routers and access points. We recommend that you change the default SSID to keep your wireless network from overlapping with other wireless networks that might be using the default SSID. It makes it easier for you to identify which wireless network is yours, if there is more than one nearby, because the SSID is typically shown in the list of available networks. Check the information that came with your device for instructions about how to change the default SSID.
Position your router or access point carefully
Wireless signals can transmit a few hundred feet, so the signal from your network could be broadcast outside of your home. You can help limit the area that your wireless signal reaches by positioning your router or access point close to the center of your home rather than near an outside wall or window.
Aug 03, 2010 | SMC Barricade 7004VWBR Wireless Router
My wireless network is currently unsecure. how do
If you have a PC connected to your router through an Ethernet cable (i.e. wired), make the changes through it, because, if you do it through a wireless device, you would loose access as soon as you set your wireless secturity parameters. Anyway, start a browser (e.g. Internet Explorer) and go to 'http://192.168.0.1' (this is the default IP address for this router. If you have changed it, replace it with yours). An authentication screen will come up, Enter 'admin' as 'User name', leave the 'Password' field empty, and click on 'OK'. The web interface will come up. Click on the 'Wireless' icon (on the left side of the screen) and the 'Home' tab. On 'WEP', click the 'Enabled' checkbox. On 'WEP Encryption', if you choose '64bit' you must enter exactly 5 characters as your wireless passphrase. Otherwise, if you choose '128bit' (more secure, of course), your wireless password must be exactly 13 characters long. To make it easier for your, select 'ASCII' under 'Key Type', and enter either your 5-char long or 13-char long passphrase under 'Key1' (make sure its checkbox is ticked). Then, click 'Apply' (the green icon with a check mark). Your router is now secured. Now, make these same changes (i.e. WEP encryption method and the passphrase you've chosen) on all devices (computers and/or smartphones), in order to allow them to connect to your router through Wi-Fi.
Hope it works for you.
Cheers! Carlos
May 21, 2010 | D-Link AirPlus DI-524 Wireless Router
I have a DI 614+ and enabled WEP 64 bit encription. How do I know the wireless network is secure? thanks
If you already enable WEP on the router the wireless network is already secure , to double check use a wireless computer and if you view available wireless network it should display your wireless name with a lock on it and when you try to connect that should be asking you for the WEP key.....
Dec 06, 2009 | D-Link AirPlus DI-614+ Wireless Router
Where is the SSID on my at&t router and what is the WEP Key? I am trying to connect my PS3 wireless up.
ssid is service set identifier usually sniffer software will find them. the wep wirless encription protocall is a key number usually found on a sticker on the bottom of the wirless modem, router .
Jul 09, 2009 | Acer Computers & Internet
How do I secure the wireless router with a pass word
in esence what you do is:
1. go into configuration page (check your router manual or documentation)
2. go into wireless
3. change the defaul SSID (that is the network name or Access point name or your router name)
4. make a note of the SSID you have defined (you needed when setting up your client computer)
5. if you want you can stop broadcasting the SSID (recommeded.. that's why you noted that on previous step
4. set up your encription method (wep, wpa, wpa2).. wp2 is recommeded or wpa if wpa2 is not avaliable or wep if that's the only option as it is better than nothing.
5. configure and note you passphrase/key (you need this to configure your client computer)
this is a good article that will give you some fundaments
http://technicallyeasy.net/2007/07/securing-wireless-network/
and this is a walk through securing a router with an example for a popular linksys router:
http://technicallyeasy.net/2007/09/securing-linksys-wrt54g-wireless-router/
and this is a wlak through securing a router with an example for a polar d-link router:
http://technicallyeasy.net/2007/09/securing-d-link-di-524-wireless-router/
other routers may be different but in esence is the same.
let us know how it went!! good luck!!
Oct 08, 2008 | Belkin Computers & Internet
Linksys Wireless-G WRT54G Router Logo
187 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
